Andrew Johnston | 28/01/2013 23:10:36 |
![]() 7061 forum posts 719 photos |
Posted by alan smith 6 on 28/01/2013 21:03:55:
What`s wrong with tapping the work down with a lead hammer as has been done since the days of Josia Whitworth. OOPs, forgot that those flimsy Chinese mills would probably break in half if treated in that way.
Because it's a waste of time, quicker to use a vice that has minimal jaw lift instead. Andrew |
Andrew Johnston | 28/01/2013 23:28:13 |
Over the years I've acquired a few vices, but we won't go into that on a public forum. In terms of machine vices I've got an 8" Abwood on the shaper; looking at the vice I think it was originally intended for a shaper. It cost £25 on Ebay, and it's staying on the shaper because it is too heavy for me to lift. For some years I used a 6" vice for milling that came secondhand with my vertical mill, thrown in as a deal sweetener, now I know why. I thought it was an Abwood, but having just looked I can't see any makers name. It has a few drill holes in it, not by me I hasten to add. In the end I go so fed up with the jaw lift on it I put it to one side and bought a Kurt D688. Expensive but well worth it, although of course I would say that! I've also got one of those 'bolt to the mill table vices' for long parts; bought secondhand on Ebay. Actually I bought two, and sold the second one for comfortably more than half of what I paid. I also bought a small Soba universal swivelling vice for use on the Clarkson T&C grinder. It'd be nice to have an original Clarkson or J&S vice for the T&C grinder, but they're pretty rare, and go for silly money. After all it's only for grinding lathe tools, not precision surface grinding. I've also got a lovely toolmakers vice, made by the late father of a friend of mine, who happened to be a toolmaker. Regards, Andrew |
Andrew Johnston | 29/01/2013 10:59:37 |
Posted by alan smith 6 on 28/01/2013 23:33:06:
Ps. is that a tractor you`re driving? Alan, Close, it's actually a Pawnee 235, and I was about to tow a glider into the air. The Pawnee is an ex-crop sprayer, and is known as an aerial tractor; simple and basic, but gets the job done. Here's the whole thing: The picture was taken a while ago, the 'sharks teeth' no longer adorn the cowling. Neither does the engine at the moment, but that's another story. Regards, Andrew |
Andrew Johnston | 30/01/2013 11:06:20 |
![]() 7061 forum posts 719 photos | Michael, Thanks for the elucidation, there's always more to things than meet the eye. It would be interesting to know how many manufacturers take all these factors into account. My Kurt vice manual lists clamping forces of well over 7000lbs, depending upon the torque applied to the screw. Regards, Andrew |
Gray62 | 30/01/2013 14:04:51 |
1058 forum posts 16 photos |
Ahh happy memories Andrew, we had a pawnee at Bicester when I was in teh RAF, was the best tug on the field, although the Supermunk came a close second
The only problem we had with the Pawnee was that it tried to rip the wings of a K8 or K18. Great for towing out a Blanik though, would love to give one of those old tin tubs another rove around the skies CB |
Ian S C | 01/02/2013 08:40:18 |
![]() 7468 forum posts 230 photos | Interesting Andrew, the prop appears to be fixed pitch, is it metal, wood, or some other construction? Ian S C |
Andrew Johnston | 01/02/2013 22:11:10 |
![]() 7061 forum posts 719 photos | Ian, Yes, it is a fixed pitch prop; fairly fine pitch for towing, so good acceleration and climb performance but a bit slow in the cruise. As far as I'm aware it's a wooden prop with a fibreglass/paint protective layer. Primary reason for a four blade prop is that it is quieter than the normal two blade metal props originally found on Pawnees. Regards, Andrew |
Chris Trice | 02/02/2013 01:34:35 |
![]() 1376 forum posts 10 photos | Presumably a slightly smaller diameter too which gives it a bit more ground clearance? |
Ian S C | 02/02/2013 11:23:33 |
![]() 7468 forum posts 230 photos | Chris, if the prop dia is reduced, its not for extra clearance, the old two blade prop had enough clearance to opperate from rough farm airstrips in NZ. The reduction of dia reduces the tip speed of the prop, normally the tip speed is very near the speed of sound, and that is where the noise comes from. Even the early Spitfires and Hurricans had fixed pitch props, they had the opposite problem, very poor low speed, course pitch, high speed, from a two blade Watts wooden prop. Ian S C |
Andrew Johnston | 02/02/2013 11:44:40 |
![]() 7061 forum posts 719 photos | Chris, You are correct, the prop is smaller in diameter, so the ground clearance is better. However, as Ian says, this is not normally a problem with Pawnees. For some taildraggers it can be, like this:
This prop is variable pitch, so another lever to play with. I need to carry checklist cards when I fly this aircraft, in case I forget something. To a first approximation the power absorbed by a propellor is proportional to the area of the propellor disc versus the percentage of that area occupied by blades. So, if the power is constant, adding more blades means that the diameter can be smaller. Again, as Ian says, that means the tip speed is lower, and hence less noisy. Noise is a particular problem with tugging as we use full power from takeoff to the top of the tow. Regards, Andrew |
Chris Trice | 02/02/2013 13:36:19 |
![]() 1376 forum posts 10 photos | Ian, generally if you increase the number of blades, you decrease the diameter as the propellor is matched to the engine horsepower x the duty it's intended to perform. A fixed pitch propellor is like being in a car with only one gear. The number of blades on the aforementioned Spitfires and Hurricanes went up with the engine horsepower because they couldn't make the the propellor bigger in diameter without hitting the ground. Again, generally speaking, two blades are the most efficient because they're less likely to be in the prop wash of the preceeding blade although at high speed this becomes less of an issue.
Ian S C | 03/02/2013 10:21:27 |
![]() 7468 forum posts 230 photos | Yes Chris, thats it, there were all sorts of methods tried to get the power harnesed, 5 blades, contra props, the reason for the cranked wing on the Corsair was the extra large dia prop, even when they went to 4 blades. Andrew, you'v got to remember the shutters on the front of the engine cowling, I suppose the Russians need them in the winter. Ian S C |
Andrew Johnston | 04/02/2013 01:16:00 |
Posted by Ian S C on 03/02/2013 10:21:27:
Andrew, you'v got to remember the shutters on the front of the engine cowling, I suppose the Russians need them in the winter. The shutters are useful on the descent off tow to prevent engine cooling, but the golden rule is to make sure that they're open before take off, otherwise it gets stinky pretty quickly (burnt oil), followed by an overheated engine. Andrew |
Pete | 10/02/2013 20:20:38 |
128 forum posts | When is a precision vise not a precision vise? When it's exactly what you found. But advertising specializes in half truths if not direct lies. This is a fairly long thread, and I did read all but the OT posts. There seems to be a bit too much posted here where people don't seem to quite understand logic and basic thinking about economics though. There is and never will be any such thing as good, accurate, and cheap. To name just two people, I've been reading both John Stevenson's and Jasons posts for a long time. Both without fail always freely offer as much of their experience as possible. And both have a very large amount of that experience that anyone here with a lesser amount would do very well to pay close attention to what they have to say. You might even learn something if you ever get past your own personal biases. I certainly don't expect anyone here to embrace my way of doing things since everyone is of course different. But even with this being a hobby for most. Exactly why does that mean were under no need to do our own product research? I guess if you don't own a computer, then you'd have some reasons for not being able to do it as well as those who do. I doubt anyone here are managing to get their own thoughts posted here by or with a crystal ball. So......................................... I've slowly learned by a lot time, trial and error, and wasted money that there are areas where you DO NOT buy on price alone. Work holding would be just one of those. Shortly after buying my Taiwan built Bridgeport clone, I bought two 4" capacity Kurt style Chinese built mill vises. Due to my job at the time, it was over a year before I was even able to get them bolted down to the mill table. And I used one of those vises exactly once. The fixed jaw deflection, trueness of that fixed jaw, internal machining, or to be more honest, the lack of internal machining never mind accurate grinding, etc,etc. All of it added up to a pair of vises that were useless. Yes I can or I could remachine them to be much better than they are now. But I can't fix the basic bondo filled weak castings, or the quality of the cast iron that was used either. They look ok, it's when you start to actualy dig into them when you find out there not even a basic casting kit that can be reworked to be suitable. I then bought what I knew very well I should have but didn't to begin with. A matched pair of Glacern 615's. At $1,000 plus shipping for the pair of them, it really did hurt my wallet. But I won't ever need better no matter what work shows up given the accuracy an average Bridgeport type mill is capable of producing. These vices are fully able to match and exceed anything myself or this mill is capable of. But I bought them after a lot of research about what would get me the most performance for my money. That was also buying a nessisary product and using proper logic while doing so. Even at the hobby level, everything we do should be based on the bare minimum of using some logic. Yes I fully understand the problems that the entry level people are going through in regards to choosing tooling or even paying for it since there is so much that seems to be needed right away even to do the most basic of jobs. I can't help you with that problem. I can list some of my experience, and it's then up to them to pay attention to it or not. I've always made a point of buying the very best metrology equipment I can afford since if I can't depend on reliable readings and measurements, then I may as well just use a carpenters tape measure. So far that idea has worked well. But I've personally decided for myself after buying those worthless mill vises that I can no longer afford to buy cheap, or to word it a bit better? Poorly built tooling or cutting tools. And I've yet to buy anything at a cheap price for this hobby that was worthwhile. That was a hard and expensive lesson to finally learn, but it was a true one. Yes it does hurt a bit to make a point of buying proper industrial quality. But it hurts far more to buy junk to begin with and then replace it with what's really required. And those much higher cost cutting tools work out cheaper due to there dureability, faster metal removal rates, and much better finishes. Our usual lower horse power equipment can also stand all the help they can get by using tools that do come as proper and real high quality HSS or Carbide, and then they even come properly sharpened. And before you protest that you can't afford that industrial quality because this is after all just a hobby? If you haven't actually tested some of it, then just how do you know and exactly how do you think any of your points of view about them are even valid or logical? In fact, if you haven't tried any of it, then you don't have enough experience to say if I'm even right or wrong. Tooling is exactly the same. "It's only a hobby, better isn't needed" Uh huh, and when something shows up that does need better? All high quality tooling should list some specifications for accuracy, runouts, etc. A mill vise for example should list just how true the bed and fixed jaw is. But when tooling doesn't have any specifications listed. I just don't buy it. What are your complaints then? You have nothing measureable to check or judge it against. Pete |
John Stevenson | 11/02/2013 00:15:42 |
![]() 5068 forum posts 3 photos | Pete, well said.
The cheques in the post............. |
Brian Wood | 11/02/2013 09:33:44 |
2742 forum posts 39 photos | Like Pete I have followed this thread and in some places with concern or at least amazement. The common sense expressed by Pete was a refreshing change, long may it be so. I have made the same painful discoveries for myself and as a result have haunted bankrupt stock and industrial tool sales to be able to buy better quality at prices I can afford, usually with success. It is good to back your judgement at these events too, you quickly learn who is knowledgable and who is just a scrappy on the hunt.. Brian. |
Andrew Johnston | 11/02/2013 12:22:55 |
![]() 7061 forum posts 719 photos | Hmmmm, some valid points made by Pete, just a pity he felt the need to be condescending. Andrew
PS: Must remember to doff my cap and bow next time I meet JasonB |
Brian Warwick | 11/02/2013 12:52:10 |
![]() 30 forum posts |
Posted by Andrew Johnston on 11/02/2013 12:22:55:
I couldn’t agree more, I think this thread is just going around in circles, I doubt anyone could argue quality costs but not everyone needs Rolls Royce quality so if a person is happy with a lower spec because it fits their needs then that’s fine. But those that buy a piece of equipment for scrap value and with no specification don’t whinge when a heap of scrap arrives either return it or accept that’s what you bought. Bottom line is QUALITY is FIT FOR PURPOSE nothing more nothing less after all a spec could say +/- 1" and a prodcut would be classed as quality if it was within tolleance based on the spec.
jim' | 11/02/2013 14:23:49 |
72 forum posts 6 photos | Well said Pete |
Pete | 12/02/2013 04:28:44 |
128 forum posts | "Condescending"? No it wasn't typed or meant as such. I'm just very tired of the newer people making the exact same mistakes I did, and in turn wasting their money in the same way due to no good reason other than inexperience and bad judgement. And I said or meant nothing at all about "Rolls Royce" quality. A well built accurate vise strong enough to fixture the raw material in place, and it's designed and built to counteract the cutting forces built with proper materials has nothing to do with RR now does it. It's the bare minimums and certainly not optional of what is needed to get the damned job done now isn't it? Or are we going to waste time and argue that point also? What I tried to do was state some honest opinions that weren't subject to interpretation. Apparently for some, I failed at that. This thread isn't going around in circles, or it wouldn't be if the people who haven't decided that the bottom of the barrel dirt cheap tooling is worthless would just refrain from posting. Or at least just post something helpful, worthwhile, and logical that can and will help to educate those new people about what they really need to know. Gentlemen, you can argue all you'd like, that does not change the facts that work holding is one of the last places where you should try and pinch pennies. To imply otherwise does nothing to try and help to educate these newer people. In fact it does exactly the opposite. Good accurate tooling will always be expensive no matter where and who builds it. A whatever inaccuracy's that are built into your work holding will result in them being replicated into everything held and machined in that work holding system. I consider that I actually owe something to the vast amount of book authors, forum posters, and even a few real live people I've met over the years who have helped me learn the very little I have about this hobby. I do think I'm required to help pass that information along the same way they did and continue to do today. We owe these new people at least the bare minimum of providing factual, honest and logical information. If your not willing to do that? Then just maybe your points of view aren't factual, honest, and logical. I very much hate to quote myself, but. "If you haven't actually tested some of it, then just how do you know and how do you think any of your points of view about them are even valid". So at the risk of offending. Have you even bothered to do so? Talk is as they say, cheap. Your personal level of inexperience does not dictate my points are invalid or untrue.
Pete |
