John Smith 47 | 21/04/2021 22:57:06 |
393 forum posts 12 photos | @Gerhard Novak - The Evolution R210SMS looks like this, yes? |
Peter Cook 6 | 21/04/2021 23:06:52 |
462 forum posts 113 photos | Posted by John Smith 47 on 21/04/2021 21:10:52:
@Peter Cook 6 - nice try but no, I'm not going to mess about building a special table for an angle-grinder. I don't have time, nor the inclination. Talking of inclination I would quite like to be able to do 45° cutting. OK your call. You are trying to do something very specialised, but don't want to put any effort into specialised tooling, or spend the sort of money that commercial solutions need. Good luck!! Edited By Peter Cook 6 on 21/04/2021 23:08:11 |
Stuart Munro 1 | 22/04/2021 07:03:17 |
108 forum posts | Posted by John Smith 47 on 21/04/2021 17:38:04:
Jim Byrnes's stuff certainly looks entirely wonderful. Good to see something better-made than Proxxon! It's certainly not cheap though, and by the time you have imported it, it will be eye-wateringly expensive. To be honest, I am now getting cold feet at the whole idea of trying to accuraaly SAW mild steel plate on a circular saw. I now think the only hope will be an extra thin (1mm) ferrous cutting disk, turned at a very high RPM (e.g. 20,000rpm). I am happy to be prove wrong though.
John, Jim came back promptly confirming that his saw (with slitting blade) will cut thin sheets of aluminium and brass but not steel. Stuart |
Stuart Munro 1 | 22/04/2021 07:07:37 |
108 forum posts | Posted by Martin Kyte on 21/04/2021 17:35:09:
Posted by Stuart Munro 1 on 21/04/2021 17:07:25:
John, and everyone else, This is a real problem for beginners at engineering like me. Cutting strips of material be it brass, steel or aluminium is essential yet challenging. So I too have gone through all the permutations. A Floridian called Jim Byrnes makes what is probably the best wood modellers table saw on the planet (certainly not the best beer on the planet if he hails from the USA! to misquote an old advert). It comes with a range of optional blades which I suspect but would need to confirm, include metal cutting blades. 2 problems - its hyper expensive top import, like twice the cost of a Proxxon FET - and I'm not sure it cuts metal, just suspect it does, but will enquire. If only there were a UK importer, I guess bulk buying would enable lower shipping costs which are half of the UK total for a 1 off! Stuart As I mentioned earlier maybe the little proxon bandaw would suit you better. Proxxon Micromot MBS 240/E Bandsaw. regards Martin Martin, I've gone to sheers for thin aly and brass, don't have a need to sheer steel sheet. With the aly and brass I then use a panel hammer to flatten it and put it into a vice betwen two bits of iron angle and file the edge the last half mil. Works for me. Stuart |
Gerhard Novak | 22/04/2021 09:55:00 |
![]() 109 forum posts 114 photos | Posted by John Smith 47 on 21/04/2021 22:57:06:
Yes, this is the machine. For me it is mainly to cut of materials from bars, of course if you want cut from flat material or sheet material it is not the one. Have you ever considered cutting by an oxygen cutter? (plasma cutter) I think a thin cutting disc should be the easiest think to do. |
John Smith 47 | 22/04/2021 10:09:33 |
2. Question: Have any of you ever tried fitting one of those thin black cutting disks (either aluminium oxide or corundum) into a mini table saw like the Proxxon FKS / FET Table Saw?
So the range in speeds is much less than we thought. And surely those cutting speeds are way to fast for steel?! Edited By John Smith 47 on 22/04/2021 10:17:08 |
Andrew Johnston | 22/04/2021 10:13:28 |
![]() 7061 forum posts 719 photos | Posted by Peter Cook 6 on 21/04/2021 23:06:52: .....but don't want to put any effort into specialised tooling, or spend the sort of money that commercial solutions need. Spot on analysis. Andrew |
Russell Eberhardt | 22/04/2021 10:15:03 |
![]() 2785 forum posts 87 photos | To cut sheet with a saw you ideally need at least two teeth in contact with the work at all times. The finest Swiss piercing saw blades available are 32 teeth per cm. so will just about do for your 0.1 mm. thickness but can only be used with a piercing saw frame. You could possibly adapt the blade holding on a scroll saw to take one but they are rather fragile. Watchmakers manage to cut accurately with them but it takes practice! A pair of good quality watchmaker's tin snips should do the job, followed by a small hammer against a flat surface is necessary. Russell |
JasonB | 22/04/2021 10:26:28 |
![]() 25215 forum posts 3105 photos 1 articles | Russel, not sure if you have that right, 32tpi is about 0.8mm, so a 0.1mm sheet will tend to catch unless the saw is tilted almost flat. I think it may be worth referring back to John's earlier posts where the sort of thing he wanted to cut was 16mm wide strips and then cut those up into 13mm lengths possible with one edge at 45deg. Things like rage chop saws would just pick up the work and throw it across the workshop with your finger closley following. Edited By JasonB on 22/04/2021 10:27:27 |
Michael Gilligan | 22/04/2021 10:31:18 |
![]() 23121 forum posts 1360 photos | Posted by Russell Eberhardt on 22/04/2021 10:15:03:
. … 32 teeth per cm. … . Jason, for info ^^^ MichaelG. |
John Smith 47 | 22/04/2021 10:34:31 |
393 forum posts 12 photos | Yes, I tried sawing with the finest saw that a jewellers could provide (32 teeth per cm) but the 0.1mm mild steel just bent. A small high speed spinning disk (c 20,000 rpm) was MUCH easier. |
Hollowpoint | 22/04/2021 11:16:16 |
550 forum posts 77 photos | Sandwich the metal sheet between 2 pieces of wood and then you can just cut through the whole lot with a scroll saw. 😉 |
JasonB | 22/04/2021 11:54:05 |
![]() 25215 forum posts 3105 photos 1 articles | Thanks for the 32 tooth correction. As Hollowpoint says often when cutting thin sheet the work needs fully supporting by laying on a board and cutting both or even sandwiching. Back to my point of doing it on a mill with a slitting saw this shows some 0.5mm brass being cut into thin strips, you can just see a bit of brass sticking out on the left and the saw marks in the back board where I have stepped down and made several cuts. The saw has cut right through the front board Not a good photo of the brass as its covered with flux and solder but all exactly the same width and with a good finished edge
Edited By JasonB on 22/04/2021 11:55:36 |
Russell Eberhardt | 22/04/2021 13:57:49 |
![]() 2785 forum posts 87 photos | Posted by JasonB on 22/04/2021 11:54:05:
Thanks for the 32 tooth correction. Yes you are right of course I must have shifted the decimal point. I claim old age Russell |
Roger B | 22/04/2021 14:13:49 |
![]() 244 forum posts 105 photos | I checked last night which saw blade I was using and it is actually the HSS version rather than the carbide one. If you choose the Proxxon FET you will have the possibility to use an abrasive disc or one of these small saw blades. 50mm diameter rather than 80mm will give a useful reduction in cutting speed for the saw blade.
John Smith 47 | 22/04/2021 16:50:29 |
393 forum posts 12 photos | **LINK** Given that it is tipped with Tungsten, how come it can't cut mild steel? I get that it can't but I am curious to know why it can't. I was thinking that if we could slow down the RPM, and increase the torque of the motor (e.g. by having a higher wattage motor running more slowly) maybe that would help Likewise I am also curious that solid carbide discs are no better.
e.g. Bosch GTS635-216 Cost: £335.99 But even if I have to settle for quite wide cuts, at least I would get my straight cuts... through steel. J |
Michael Gilligan | 22/04/2021 17:27:32 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 22/04/2021 16:50:29:
**LINK** Given that it is tipped with Tungsten, how come it can't cut mild steel? I get that it can't but I am curious to know why it can't. I was thinking that if we could slow down the RPM, and increase the torque of the motor (e.g. by having a higher wattage motor running more slowly) maybe that would help Likewise I am also curious that solid carbide discs are no better. . The blade is intended for an underpowered machine with an inadequate spindle Please see Peter’s post and my response, on page 1 The blades could almost certainly do your job: if suitably supported and adequately powered at an appropriate speed. ... but Proxxon needs to inform you in the context of its machines.
MichaelG. |
Roger B | 22/04/2021 18:49:42 |
![]() 244 forum posts 105 photos | In John Smith's milling machine thread I drilled a 3mm hole in steel with my MF70. 636 people looked at that video over 5 days. No one commented. I could make a spindle nose adaptor for my FD150 and make a sawing trial at 5000rpm with a 100w motor (I might anyway because it might be useful for me) but will it change anyone's opinions, probably not. I am a happy Proxxon user and I understand the limitations of their machines, I have in the past discussed price/performance balance with their technical department as I have with Sherline. That is why my FD150 has Sherline chucks. |
Pete. | 22/04/2021 18:54:18 |
![]() 910 forum posts 303 photos | Posted by John Smith 47 on 21/04/2021 12:15:56:
@Pete - I need the metal to stay absolutely flat after it has been cut. Rather than endless what ifs, I thought I'd demonstrate what I said. A simple table on my bench shear before I had machine tools at home, it would be made with dowels at various angles now. |
Michael Gilligan | 22/04/2021 20:23:26 |
![]() 23121 forum posts 1360 photos | Posted by Roger B on 22/04/2021 18:49:42:
[…] I am a happy Proxxon user and I understand the limitations of their machines, I have in the past discussed price/performance balance with their technical department as I have with Sherline. That is why my FD150 has Sherline chucks. . Roger, Please forgive me if my comment came across as ‘generally’ negative to Proxxon ... that was not my intention. I was simply trying to honestly answer John’s specific question relating to the use of that saw and/or its listed blades to cut steel. MichaelG. . Edit: ___ upon re-reading my earlier post: The statement ... but Proxxon needs to inform you in the context of its machines. Might better read: Proxxon has a general duty to inform purchasers of the ‘design envelope’ of its machines, and has done so: It has evidently determined that cutting ferrous material on that saw, with those blades would be outside that envelope. Edited By Michael Gilligan on 22/04/2021 20:47:24 |
