3D Printed Threads
Roderick Jenkins10/09/2017 10:53:17
2376 forum posts
800 photos
The Dremel nose thread is pretty slack. 3/4 BSF (55 degrees rather than 60) works well enough if you happen to have a tap.
Rod
Neil Wyatt10/09/2017 11:08:32
19226 forum posts
749 photos
86 articles
Posted by Michael Gilligan on 10/09/2017 08:57:56:
Sorry, Neil; but I thought it worth mentioning before you go into production.
The same thread pitch [3/4mm] is used on filters, of course; which might add some frisson to that ever-popular 'decimal vs fractional' debate.
Just checked my 3D model and.... I used 0.75mm NOT 0.7mm, it's my memory that's wrong, not my design.... Phew!
Michael Gilligan10/09/2017 11:14:12
23121 forum posts
1360 photos
yes
Robin10/09/2017 11:36:41
678 forum posts
So it sounds like I have bought the Chinese knock off, metric threaded, Dremel clone from the Lucky Monkey Productorium in Guang Dong Province while you all have the pukka Yankee threaded, Imperial Dutch original.
Well, I am not going to let it bother me, but if I ever wanted to get one of these posh Dremels, like what you have, what do I look for? Where do I go?
Journeyman10/09/2017 11:56:27
1257 forum posts
264 photos
Just out of interest my various tables show 3/4" UNC as 10 pitch. This makes it practically interchangeable with an M19 2.5mm thread bar the crest and root shape. All the tables I looked at cunningly omit M19 showing just M18 and M20 which also have 2.5mm pitch. Of course I could be wrong, usually am frown
Neil Wyatt10/09/2017 12:49:04
19226 forum posts
749 photos
86 articles
The difference is about 0.3% on diameter and 1.5% on pitch.
The only way to be certain if the Dremel thread is metric or imperial would be to ask Bosch...
But I guess 3/4" is more likely than 19mm.
JasonB10/09/2017 13:19:14
25215 forum posts
3105 photos
1 articles
Checked my taps down in the shed and as Rod says 3/4 x 12 BSF will fit as that is what I used to make a router plate for someone.
Rod Ashton10/09/2017 13:46:26
344 forum posts
12 photos
Just got a 3/4 UNC tap off the bay at £6. That should clear my crappy Dremel printed router accessory. Thanks guys.
