John Stevenson | 05/09/2016 17:05:50 |
![]() 5068 forum posts 3 photos | No I'm asking Why the Burnard system is designed / better for work holding ? I have read endless posts that says it is and ER's can't / are not designed for radial loads but so far no actual design criteria that supports this. Without this, this thread on a hobby forum is useless Edited By John Stevenson on 05/09/2016 17:07:38 |
Ajohnw | 05/09/2016 17:26:42 |
3631 forum posts 160 photos | Posted by John Stevenson on 05/09/2016 14:33:02:
Ok I'll have to conceed the point and accept that you know more than many companies in the UK alone. Anyone want to buy 45 BT40 /ER32 collet chucks, going cheap ? If I had a BT40 fitting I would. The problem with ER for work holding is simply the grip length as it is with the Bernard multi size actually. Jacobs rubber are a touch better as they do shorten it on some of them. The answer on ER is simple really. Have more than one size and use small for small and bigger where it's needed. Ok that means more than one collet chuck but given what many buy cost difference is unlikely to be that much. A full high precision set of ER40's is rather a lot of collets as well. Many probably wont get used and some will be used at larger sizes where a mm or so change of diameter wont make much difference to what ever is being made providing things are adjusted to suite. While ancient milling cutter chucks may seem rather twee they do have a bit of an advantage. Easy to get cutters in and out, relatively little loss of headroom and good ones also run true. There is also the morse and R8 collet solution if the fitting is suitable. Frankly I can't see how milling cutters can avoid being subject to both radial and axial heavy loads. ER still function with drills and slot drills in them. John - |
John Stevenson | 05/09/2016 17:37:44 |
![]() 5068 forum posts 3 photos | It was a serious question on the ER/BT40 holders. I'm currently scrapping a large Beaver CNC and have nothing else that needs 45 tool holders. I'm keeping a few INT40's back for the gear cutter but this will also get scrapped in 18 months or so. . The idea is too put about 2,000 Myford gears or so on stock then downsize the gear cutting. . . Just thought, does this count as production ? Gear hobber has ER 32 arbor to hold the hob and work head also has ER32 chuck fitted. ? Edited By John Stevenson on 05/09/2016 17:45:53 |
Raymond Anderson | 05/09/2016 17:53:10 |
![]() 785 forum posts 152 photos | First off John, Not being a designer I could'nt tell you how the Er's are at their best Axially and less so radially. I just know that is the case. You would need an "egghead " to give the calculations. And if the lad from Guhring mentioned it there must be something in it. Maybe all will be revealed once I hear back from Regofix. As far as the collet system goes I have already explained why I think there are better than ER's I am going to try find the info I got a while back from Albrecht as regards milling chucks. In it they conducted tests using a ground 20mm Ø high tensile pin with a 18mm thread on the end. They then marked each pin with a scribe line and inserted them into each of the chucks Albrecht milling chuck , shrink fit and the ER. They then proceeded to apply a torque with a Stahlwille Digital torque wrench The ER let go at such and such newton mts The shrink fit and the Albrecht exceeded the torque of the ER and went past it until the nut sheared off and the witness marks had never moved. I have it on a brochure from Albrecht I will rummage about and try to put it up on here. Failing that I will see if Albrecht can give me some more info. Like I said I wouldn't profess to understand the calculations, some folks on here might certainly not me,. but there has to be something in it. cheers.
Raymond Anderson | 05/09/2016 17:56:36 |
![]() 785 forum posts 152 photos | I would have taken a few from you for the K & T but alas they are ISO 50. what a bummer. Yes that I think would count as Production. |
Michael Horner | 05/09/2016 17:59:23 |
229 forum posts 63 photos | Hi Raymond Glad you like a debate. The middle picture in the **LINK** States for tools or materials, what ever that might be. We need M.G. to dig out the patent application that would stipulate what the original intention was. Happy debating, must get my tea and get into the garage and make or mend something! Cheers michael |
Raymond Anderson | 05/09/2016 17:59:41 |
![]() 785 forum posts 152 photos | Ajohnw, No one said the ER's didn't function. |
John Stevenson | 05/09/2016 18:15:11 |
![]() 5068 forum posts 3 photos | Posted by Raymond Anderson on 05/09/2016 17:53:10:
First off John, Not being a designer I could'nt tell you how the Er's are at their best Axially and less so radially. I just know that is the case. You would need an "egghead " to give the calculations. And if the lad from Guhring mentioned it there must be something in it. cheers. So until someone does I for one am ignoring all the chaff |
Raymond Anderson | 05/09/2016 18:21:32 |
![]() 785 forum posts 152 photos | Michael Who is M G? And with respect there is no need for sarcasm!! if you want to join in the discussion fine feel free, or if not then do as you said, go and make or mend something. I have already seen that brochure and it does not tell me anything I didnt already know. cheers |
Michael Gilligan | 05/09/2016 18:29:25 |
![]() 23121 forum posts 1360 photos | As a slight aside: In a previous thread, Raymond linked to the ISO standard ... from which I quote: ________________________________________ INTERNATIONAL STANDARD ISO 15488:2003(E) © ISO 2003 — All rights reserved 1 Collets with 8° setting angle for tool shanks — Collets, nuts and fitting dimensions 1 Scope This International Standard specifies the dimensions, materials and manufacturing requirements, and designation of collets (of form A or of form B) for tools with cylindrical shanks and their corresponding holders and nuts. For non-standardized clamping devices, such as clamping devices specified in drawings, these holders can be agreed upon between customer and supplier. Form A applies to milling and any other application where a hard collet bore is required, provided that the clamping range of h10 be sufficient. Form B applies for general purposes where an extended clamping range is required. __________________________________________ . With all the interest in ER collets, it is surprising how little interest has been expressed in the difference between the two forms. MichaelG. [just stirring the pot] Edited By Michael Gilligan on 05/09/2016 18:57:36 |
Raymond Anderson | 05/09/2016 18:29:49 |
![]() 785 forum posts 152 photos | Ahh, So Mr Guhring and Mr Albrecht are only talking chaff Well in the words of Johnny Nash "I can see clearly now" . and here's me thinking they surely must know what they are talking about. well well, we live and learn . cheers. |
Michael Gilligan | 05/09/2016 18:33:04 |
![]() 23121 forum posts 1360 photos | Posted by Michael Horner on 05/09/2016 17:59:23: We need M.G. to dig out the patent application that would stipulate what the original intention was. . I'm guessing that I would be M.G. ... In which case; what you actually need is to learn how to 'dig things out' for yourself. MichaelG. |
Raymond Anderson | 05/09/2016 18:34:28 |
![]() 785 forum posts 152 photos | Hi Michael, I clean forgot about that Document.. Thanks,. maybe folks never realised there were 2 types.. I certainly didn't until I read the document.. The pot is going "still " now cheers |
JasonB | 05/09/2016 18:56:28 |
![]() 25215 forum posts 3105 photos 1 articles | May be of interest, seems the hydralic chucks slip first, the SX single taper is better and there BC best, no ER in that test
This one is the same guy testing a ER40 which outperforms the hydralic ones in teh video above |
Raymond Anderson | 05/09/2016 19:00:50 |
![]() 785 forum posts 152 photos | Jason, thats an interesting video. It was tests similar to those that Albrecht did, although I got it in a brochure not on a video. I am going to try find the brochure and also more about the SCHUNK Sino R Milling chuck.. both of which outperform the ER's, although us hobbyists will never use them. or need them. It is interesting. cheers |
JasonB | 05/09/2016 19:03:12 |
![]() 25215 forum posts 3105 photos 1 articles | The makers of those chucks here |
Raymond Anderson | 05/09/2016 19:18:24 |
![]() 785 forum posts 152 photos | Some good looking gear there. I have never heard of that make.. Another query, why do most manufacturers that put videos up on you tube nearly always show their Vmc's / Hmc's using milling chucks of various types but very little using ER. I wonder how that can be. just wondering. cheers. |
blowlamp | 05/09/2016 19:43:03 |
![]() 1885 forum posts 111 photos | I would imagine the ER collets are just about as rigid as most other systems when used at their largest holding capacity. However, with the collet pulled further into its holder, as when gripping smaller tools or workpieces, the collets will have only line contact with the collet holder and the item being held, The first picture is of a simplified holder/collet/tool setup and the second picture is my attempt to show where the gaps would be between the holder, collet and tool. How much this affects accuracy or rigidity I don't know.
Martin.
Ian P | 05/09/2016 20:12:24 |
![]() 2747 forum posts 123 photos | Martin As you show, when the tool (or work) is smaller than the nominal size of the collet it will only make line (hopefully broad lines) contact with whatever it is gripping. The OD of the collet though should still make full contact as it is a cone within a cone. Ian |
Michael Gilligan | 05/09/2016 20:38:01 |
![]() 23121 forum posts 1360 photos | Posted by Ian Phillips on 05/09/2016 20:12:24:
... it will only make line (hopefully broad lines) contact with whatever it is gripping. . The breadth of the lines will be determined by the compressibility of the materials ... If both collet and 'whatever' are very stiff materials, then contact will closely approximate a true line. MichaelG. |
This thread is closed.
