Pickling with Sulphuric
JA20/08/2016 14:16:25
1605 forum posts
83 photos
Posted by mark smith 20 on 20/08/2016 13:26:31:
I believe HF should be totally banned from use outside strict laboratory environments .
HF is a very important industrial reagent. Amongst other things it is used in the production of PTFE and as a flux for brazing high temperature alloys.
It was used at the zinc smelter at Avonmouth, Bristol, until its closure. Very occasionally hydrofluoric acid would escape into the atmosphere and etch the cars in local car parks including the smelter's. One local environmental group tried to start a campaign but, this was before the internet, could not find out very much about HF. The response of the local media was little better.
JA
Ajohnw20/08/2016 14:25:04
3631 forum posts
160 photos
I had a look around to see what it might be used for considering the other items on offer. No clues at all. He also offers phenol. I can imagine what that is used for.
Some uses are "interesting"
One thing I am pretty certain of this that various chemical substances have maximums that can be sent by post.
dont know Their comments on what to do when damaged packaging arrives are worth a read.
Edited By Ajohnw on 20/08/2016 14:25:21
Raymond Anderson20/08/2016 15:45:19
785 forum posts
152 photos
Just had a look at the site that Mark linked to, Something not right there !! had a quick look at some of the chemicals he is offering, and there is at least 3 that come under the "restricted " list, the aforementioned HF, Chloroform , and Phenol. He has 100 % feedback, so god knows how they manage to get that types of Chemicals delivered.
Raymond Anderson20/08/2016 15:56:21
785 forum posts
152 photos
Looking further into the list there is 96 % H2So4 and 67% HNO3. A lot of the items appear to do with cosmetics !!! The HF [or any of the other acids mentioned ] will certainly have an effect on the complexion. It certainly wont improve , it, but it will change it smiley
Sam Longley 120/08/2016 16:42:04
965 forum posts
34 photos
Years ago my father won a contract for the bata shoe factory in tilbury to renew the steel supporting the asbestos roof over their chromadising plant. The steel purlins had corroded due to acid fumes & had to be replaced so contract was to replace the steel. They thought he would also replace the roof but he saved money ( & made a tidy profit) by raising the roof & sliding the steel out bit by bit & replacing. Then lowering the roof onto the steel & re fixing the hook bolts.
All done by me and a gang over a holiday. So we worked over an asbestos roof over some 2ft deep tanks that had some 9mm ply sheets over them supported randomly by 3x2 timbers. We were 25 ft above on the asbestos a couple of hammers had dropped through & disappeared into the baths between the gaps in the unfixed plywood
After the job was done & the management were inspecting they started to have the covering removed. I asked what was in the tanks. "Oh they are the acid baths for dipping prior to chromadising"
So much for H & S 45 years ago
Edited By Sam Longley 1 on 20/08/2016 16:43:13
Muzzer20/08/2016 17:18:31
2904 forum posts
448 photos
IIRC, HF is used for frosting glass. Nowadays they often just use stick-on film, the name for which is "manifestation". You can only speculate how that name came about! God only knows?
Michael Gilligan20/08/2016 18:14:28
23121 forum posts
1360 photos
Posted by Muzzer on 20/08/2016 17:18:31:
... the name for which is "manifestation". You can only speculate how that name came about! God only knows?
I thought at first that it was a spellchecker error; for that fine old Jewish firm of window-fitters <Manny Fenestration>, but no; it's the real deal, enshrined in legislation.
http://www.windowfilm.co.uk/graphics/manifestation-legislation
angel MichaelG.
John Lintorn04/11/2016 18:08:23
66 forum posts
56 photos
Just to add my 10p. When doing my boiler I have found that kettle/dishwasher de scaler works well. It's great if you have a mate who can supply you a source of acid but for the average Joe it's not so easy. Whereas kettle design scaler is easily found in Tesco 😊
pgk pgk04/11/2016 18:40:42
2661 forum posts
294 photos
Acid is ridiculously easy to source... Brick acid (hydrochoric) from any builders merchant or sulphuric as drain unblocker (I bought mine from Wilco). Local hardware shop also has conc hydrochloric as their drain unblocker.
I'm following the book on my minnie build and went with sulphuric - it's quick but commonsense and taking care are important. Dropping a yellow hot lump of copper into a bucket of the stuff isn't the right time to have a panic attack or decide you need to take a deep breath or start fishing about in the bucket with bare hands. A second bucket of water is a good idea.
I've also handled nasty items in my time - a calm respectful approach with a contingency plan..
Clive Hartland04/11/2016 19:14:16
2929 forum posts
41 photos
Am I reading this right, mention of Sulphuric acid for pickling and suddenly talk of HF which i take to be Hydroflouric acid?
If so stay as far away as possible as it will be absorbed and enter your body via the skin, breathing the fumes is NOT good either. More clear detail of what is going on here please.  I only used it once to etch a graticlue, and was extremely wary of it. It was in a plastic bottle with the stopper off.
Edited By Clive Hartland on 04/11/2016 19:15:33
JA04/11/2016 19:51:34
1605 forum posts
83 photos
These normal acids (not HF) are safe if handled sensibly. However there are problems with them like do you want sulphuric acid fumes in a workshop or will you read the instructions for a brick cleaner.
I write this with thoughts of using caustic soda at above 100C.
JA
Clive Hartland04/11/2016 20:57:39
2929 forum posts
41 photos
I used Aqua Regia once to etch numbers onto hardened steel, it was viscious and acted fast but even the fumes burnt ones skin. It turned out that soldiers were mixing up the breech blocks of the new SLR and causing headspace problems and I got tasked with doing something about it. 400 breech blocks later I was willing to run away after the fumes etc. I used a wax coating and using a spring stylus in a three dimensional engraver to follow the curve of the block. Only a little acid from an eyedropper was needed.
As a young soldier in REME i went through all the sections including plating and de-rusting. The best was stuff called Magnus 577 I think, it took everything off metal. Then there was the Black Chrome plating bath where I had to copperplate the item first. Did all the nuts and bolts on my M/cycle FOC. You learn a lot very quickly.
Clive.
not done it yet04/11/2016 20:58:29
7517 forum posts
20 photos
As a chemist, steer clear of concentrated acids (and alkalis) unless you know what you are doing. Treat all dilute acids with great care (proper ppe and other appropriate precautions). As above, steer clear of hydroflouric acid as it is extremely dangerous (tanker drivers used to be issued with scalpels to cut away tissue if splashed with the stuff!). It may still be used in wheel cleaners (low %), but I would not even use those products on principle.
Reactions can be different. Nitric can set fire to sawdust, while sulphuric will remove water and leave it as charcoal
Yes, we used chromic acid to clean our glassware at school and work, we diluted our concentrated sulphuric acid, used fuming acids. Aqua regia (conc hydrochloric/nitric acid), for dissolving gold and other precious metals, by the 50l carboy. On the alkali side, siliceous products were dissolved in molten sodium or potassium hydroxide (and dumped in hot water soon after it solidified!)
Glacial ethanoic acid is used in soap making and bought by beekeepers (for fumigation with 70% acid). Drain cleaners, as stated, are readily available. All quite safe, but only if you know what you are doing. Kettle cleaner is formic acid (another strong acid and also used by beekeepers).
In particular, you only have one pair of eyes. Don't lose your sight!
SillyOldDuffer04/11/2016 21:16:27
10668 forum posts
2415 photos
Posted by not done it yet on 04/11/2016 20:58:29:
... by the 50l carboy.
Carboys! I'd forgotten about them. A giant glass bottle protected by some wire mesh and a handful of straw. I don't remember lots of accidents. Where they safer than they appeared to be?
Sam Longley 104/11/2016 22:26:22
965 forum posts
34 photos
Posted by SillyOldDuffer on 04/11/2016 21:16:27:
Although I did not see it myself I recall a teacher in our grammar school who had to fill some glass containers with acid from one of those for a class lesson. He rushed into the classroom where one was standing, grabbed the neck of the bottle & as he turned to carry it away the neck cracked & the bottle split splashing the contents all down his legs. he was seriously injured .
Cannot even imagine such a container being left in a classroom these days, yet we had several standing about in the science labs & dozens of jars with the glass stoppers of various acids on open shelves for lessons. Some were quite concentrated & we could only use them in the fume cupboards.
JA04/11/2016 22:56:06
1605 forum posts
83 photos
I remember teacher at school showing us what happened when you put red fuming nitric acid on warm dry sawdust. Nothing. We were told to leave the lab while he decided what to do next. Two days later he repeated the demonstration, a sudden very large violent flame that hit the ceiling.
There is worse, picric acid for example. After taking my A Levels two of us tried our hands at dying using synthetic dyes. It took me quite some time to get rid of picric acid burns. I think if any school now discovered the stuff in their store the bomb disposal squad would be called. It is still used for etching some fancy metals.
This obviously has nothing to do with the use of acids in the workshop.
JA
not done it yet05/11/2016 01:23:08
7517 forum posts
20 photos
Plastic carboys, not glass! It was only about 30 years ago, so moved on from the glass ones by then! Long lived because I still have two which are used to store diesel. Superceded by the IBC for chemicals, I suppose.
Clive Hartland05/11/2016 08:12:10
2929 forum posts
41 photos
Carboys, we carried two carboys of Sulphuric acid in our REME workshop lorry. This used for battery maintenance. Oh yes, frost and ice on the Autobahn and lorry skids and turns over. Two carboys smashed all over the road and an Acetyline gas bottle securely stuck in between the two rails between the dual road.
The acid soon was spread by cars going past and was stinging my face and obviously getting on my clothes. Was given instructions to clear up the mess and set to. Got the vehicle righted and luckily all the glass was in the box that the carboys were in. The gas bottle was retrieved by spreading the barrier with some wood. All the while cars going past. Got to our location and asked the cook for Soda and put all my gear in it and had a shower but no serious problems.
