WARCO WM-250 lathe family and WM16 mill
Discussiona about the warco etc WM-250, 280 & 290 lathes and the WM series mills
JasonB02/08/2014 13:06:50
25215 forum posts
3105 photos
1 articles
Copied the "direct link" from Photobucket
Typed the word "here" then highlighted it with the mouse
Clicked the link icon ( globe with a chain link under it)
Pasted the URL in the box.
J
mechman4805/08/2014 22:37:15
2947 forum posts
468 photos
Jason;
Thanks for the tip.thumbs up
George
Half centre08/08/2014 18:28:24
32 forum posts
1 photos
I was wondering if anyone had any useful tips when tramming the WM16. I find that when tightening the 2 head lock nuts it pulls the head around spoiling the setting. I end up trying to compensate for this ‘pull’ by setting the tram over to one side by the amount the head will pull. The whole process can be frustrating as it is difficult to guess the amount to offset the tram. It can take quite a few attempts before you get it right.
I made and fitted an extra steady for the left hand side of the head to match the one supplied on the right – this helps a little.
Any ideas gratefully received
Martin
32 forum posts
1 photos
Martin
Ed Duffner14/09/2014 07:47:18
863 forum posts
104 photos
Hi Martin, sorry for the delayed reply. When I'm tramming my WM16 and the head is ready to tighten, I use the small Allen screw on the right hand side of the head, near the top and adjust it to where it's just bearing against the head. This will help prevent the head rotating as you tighten the main securing nuts. I also tend to go back and fore between the two, tightening a bit at a time on each.
Ed.
Rik Shaw15/09/2014 16:42:15
1494 forum posts
403 photos
I am in the throes of relocating to a bigger workshop and I am at the measuring up stage. Could someone who has a WM16 mill tell me how high (approx.) the machine is with the Z wound up as far as it will go. I would do it myself but I have a shelf above it which restricts me height wise and I am not yet ready to move it. Thanks
Rik
Ed Duffner15/09/2014 20:53:34
863 forum posts
104 photos
Rik,
On its base stand It's 1750mm (~ 69 inches) from floor to top of the Z at full height. It's 940mm (~ 37 inches) from base of the mill to the top of the Z at full height.
Cheers,
Ed.
Ed Duffner16/09/2014 08:09:33
863 forum posts
104 photos
Rik,
I got that slightly wrong for a standard setup sorry. My machine has 0.5" rubber pads in between the floor and cabinet and again underneath the machine so correct dimensions would be:
Full height = 1725mm (~ 68.0" )
Machine height only = 927.5mm (~ 36.5" ) (Warco list it as 930mm)
Ed.
Edited By Ed Duffner on 16/09/2014 08:10:16
Edited By Ed Duffner on 16/09/2014 08:17:09
Rik Shaw16/09/2014 17:45:04
1494 forum posts
403 photos
Thanks Ed, most helpful of you. The mill will fit just where I want it to go in its new home.smile
Rik
mechman4816/09/2014 19:54:12
2947 forum posts
468 photos
Hi Martin
Look in my album under the workshop 'misc.' tab & you'll see a pic of one of the two little blocks made to align head when I trammed mine, adjusting ea. to centralise with dti, once aligned to dti just lock the locking nut & that should be it.
George
Ed Duffner03/03/2015 15:15:16
863 forum posts
104 photos
George,
May I ask what power source you used for your X axis auto-feed please?
I've received a used electric window motor today (Peugot 307) with a PWM controller somewhere en-route from Ebay with similar specs to yours and I'm thinking about load current and start current etc.
Thank you,
Ed.
mechman4803/03/2015 17:02:19
2947 forum posts
468 photos
Like you I used a window winder from a scrap car, can't remember which, but without removing the drive & checking with a multimeter ( if I can remember how to do it ) I can't give you any figures re. load & start current, 'nuff to say that the fuse supplied in the PWM ( 3A ) hasn't blown yet & the motor runs quite cool all the time.
I'm sure one of our more electrickery savvy members would proffer meter set up to check current, & remind me too.
Have found the description of the PWM...
Descriptions:
  • This CCM2NJ motor speed controller adopts a high power MOSFET with a heat sink and can easily provide a continuous current of 3A to your DC motor or other DC load, high power, high efficiency, large torque, with switch function.
  • Onboard 10A fuse, with Reverse power,Overvoltage, high current protection function, power on LED indicator
George
Edited By mechman48 on 03/03/2015 17:13:45
Ed Duffner03/03/2015 20:51:28
863 forum posts
104 photos
Thank you George, most appreciated.
Michael Gilligan03/03/2015 23:06:12
23121 forum posts
1360 photos
Posted by Ed Duffner on 01/08/2014 17:06:27:.
I'm curious to understand how a two wire motor can be operated by a PWM control. I thought the motor had to have some sort of additional wiring to send EMF back to the electronics.
Ed,
PWM = Pulse Width Modulation
Works very well indeed on ordinary permanent magnet DC motors.
Here is a reasonable introduction.
Edited By Michael Gilligan on 03/03/2015 23:07:09
Ed Duffner03/03/2015 23:54:35
863 forum posts
104 photos
Thank you for the link Michael, I'll have a good read of that as I've wondered how PWM works across 2 wires and how back EMF is detected etc
I was a sparky for 10 years but I think I only installed one DC motor starter in all that time so my knowledge of DC motors is limited.
I'm trying to determine what kind of power supply would be ok to drive the motor I have. There are a couple I've found today:
Switch mode PSU
Adaptor PSU
Measuring across the motor's 2-pin connector ( I assume the armature) I get 4.5 ohms which would work out at 2.6amps for a 12VDC supply and the PWM controller I have on order can supply a constant 3amps, similar to George's unit.
I know that in AC inductive loads there is an initial start current and as a rule of thumb was generally accepted as 1.8 times the running current. I'm unsure if DC has the same start current (inrush current is it?) characteristics hence the thoughts about, will the 3amp constant load of the PWM controller I'm getting be high enough to cope with any DC start current and would the switch mode or Adaptor type power supply be suitable.
I'm not expecting an answer (I probably ask too many questions on the forum) just sharing my thoughts.
Kind regards,
Ed.
Michael Gilligan04/03/2015 08:52:19
23121 forum posts
1360 photos
Posted by Ed Duffner on 03/03/2015 23:54:35:
Thank you for the link Michael, I'll have a good read of that as I've wondered how PWM works ...
Ed,
Responding in reverse order:
  • Of course you should expect an answer [from me and hopefully from others who are better-informed] ... that's what the forum is for!
  • The matter using switch mode power supplies to drive PWM controllers is an interesting one ... in theory, there could be a problem of 'beats' occurring between the two operating frequencies; but I have never seen this in [my limited] practice. I would just try it.
  • Yes, DC motors also have a higher inrush current, and if full voltage is applied at start-up you will see it. BUT one of the beauties of PWM is that you can gradually increase the effective voltage. ... As you will hopefully have understood from the link that I posted; the peak voltage is always "full" but the effective voltage changes with the mark:space raio of the pulse wave.
Hope that all makes sense.
Edited By Michael Gilligan on 04/03/2015 08:53:48
Edited By Michael Gilligan on 04/03/2015 08:54:53
Les Jones 104/03/2015 09:13:08
2292 forum posts
159 photos
Hi Ed,
A PWM controller is not a closed loop speed control system so it does not need a separate feedback signal. For the IDEAL permenant motor the speed is proportional to the voltage and the torque proportional to the current. So under no load the back emf (This is from the motor working as a generator. Not from any inductive effect.) is equal to the supply voltage. In a real motor the windings have resistance so the speed will drop due to the voltage developed across this resistance means that the motor slows down until the back emf is equal to the supply voltage minus the voltage drop across this resistance. On you motor the stall current (Back emf = 0) will be 2.6 amps A simplified explanation of a PWM controller is that it provides an average voltage output that means that the speed will be roughly proportional to this average voltage. Normaly the winding resistance is quite low so that the voltage drop across the winding resistance is also quite low when the motor is running at its rated current. As the winding resistance of your motor is 4.5 ohms I suspect it will not be powerfull enough for your purpose.
Les.
Ed Duffner04/03/2015 10:12:23
863 forum posts
104 photos
Thanks again Michael and Les for your expertise
I think with the PWM reference I may have been confusing myself with multi phase stepper motor speed control which I've also been reading about recently.
Ed.
Rik Shaw08/03/2015 18:29:30
1494 forum posts
403 photos
My WM250 VF lathe has always had a problem with the on/off switch pop popping until eventually it gets going and until now I have put up with it. However, having moved into the new workshop the lathes power now comes from a different consumer unit located in the new place and they don't like each other.
The lathe is now unusable as every time I press the ON button it trips the breaker. So today I removed the four screws holding the front switch panel in place and squirted some contact cleaner where I thought it would do its best, worked the switch on and of a dozen times or so and replaced the panel.
Turned power back on and hit the ON button - 'nuffing! Machine would not power up. Removed panel again and could see that a brown (live) wire had come adrift but from where?
Maybe the switch cleaner has done its work and maybe it hasn't but until I know where that wire should go I'll not know. The only clue is that one of the empty terminal clamping screws on the forward/reverse knob is loose but without knowing for sure I am reluctant to avoid total meltdown in case I get it wrong.
I know there is a circuit diagram on the rear of the headstock which I took a photo of when the lathe was being relocated but it is so blurred as to be unreadable. I am able - with difficulty - to move the lathe for another pic of the circuit diagram but there is a lot of weight involved and spinal surgery with a further slipped disc since is not exactly the incentive I need. Anyway, I am not a genius in the "sparks" department so maybe even a clearer schematic would have been wasted on me.
All in all I think it has to be a replacement switch but I STILL need to know where the loose wire goes.
Pulling the panel out it looks like this from above:
From underneath it looks like this: (note the rogue loose wire).
Any help would be much appreciated.
Rik
Rik Shaw15/03/2015 17:23:37
1494 forum posts
403 photos
I am still having major issues getting my dead WM250-VF going. Its blowing fuses (front and back) and tripping the MCB (16A). Despite advice from WARCO and a selection (their choice) of various ON/OFF switches which differ from the original along with a replacement forward/reverse switch the lathe stubbornly refuses to run.
They have promised delivery of yet another switch tomorrow which they assure me will be identical to the original fitted to my machine. I just hope that all this messing about with different switches has not caused collateral damage to other circuits/controllers.
In the mean time though, if you have one of these lathes and can get to the rear of it would you be able to snap a close-up of the circuit diagram on the rear of the headstock? I would like to do it myself but due to health reasons moving my lathe away from the wall, for the time being, is not an option.
BTW the machine is eight months out of warranty.
As I said, moving this lot would hurt like 'ell:
