Member postings for Half centre
Here is a list of all the postings Half centre has made in our forums. Click on a thread name to jump to the thread.
Thread: 3 inch Southworth engine
23/09/2021 17:18:57
That's quite some pump David - it looks great and it works. I think I have found the plans for it and if my Southworth pumps continue to be uncooperative I will definitely give it a go.
thank you
Martin
06/09/2021 16:32:19
Hi Noel - Thanks for your reply, I have heard that as well. I have DRO on the mill otherwise it would be well beyond my experience / ability to tackle. I think the basics must be correct because they go like the clappers on air, very frustrating they don't run on steam.
Hi Jon - Thanks for getting back to me. I fixed the shuttle valves at an early stage in the make, but you are right it is a key source of problems if you are not very careful. As for the clacks I did not follow the drawings, they looked very fiddly and rather delicate? I made ordinary type in line clacks with a Nitrile ball (its a cold water feed so Nitrile is OK). By ordinary I mean the type that have a deep groove in one face and the ball is pressed against it in the on position allowing the water to flow around it, through the groove and out. In the off positing the ball presses against a seating to stop water flow. They seem to work well and I have had no problems (yet!) with transient back flow - might be worth a try? However without a spring and with no pressure to close them they do let water through, but as they connect the water tank to the pump and then a boiler clack the whole feed water line can remain flooded. Hope that all makes some kind of sense?
Martin
06/09/2021 08:53:11
Hi Simon - Thank you for getting back to me - I am starting to realise that these things are a bit of a minority sport.
The rings come supplied in the bag of castings so I am not sure what they are made of, I will phone Blackgates. Your suggestion of rings expanding and tightening in the heat is an excellent explanation of why they run on air and not steam. I am sure you are right about their inefficiency. I am treating them as a bit of mechanical bling - an interesting feature rather then a serious water feed. They do look good perched on the front of the Pea (vanity, vanity!)
Its good to know they can potentially work so I will persevere.
thank you
Martin
05/09/2021 17:49:54
Hello everyone - I have built 2 of the Southworth 3 inch vertical pump engines, one for each side on the front plate of my Sweet Pea (I think they are also known as Weir pumps). They work beautifully on air and pump water at atmospheric pressure on my test rig. Both have a hydrostatic lubricator in line with the steam supply. When I put them onto the engine and try using steam its no go? The steam supply for each is an independent feed from an extended manifold and is copious. I have tried running them against boiler pressure, and with the water supply disconnected, the inputs and outputs open to the air. Still nothing. I sometimes get a slight down stroke then nothing. Steam and water jet out from the exhausts?
Has anyone got one of these engines to run and pump against boiler pressure on a 5 inch loco? If so would you have any hints (or magic spells!) you could share with me.
Thank you
Martin
Thread: 3 inch Weir engine
20/12/2020 15:49:41
Hello everybody.
Myself and a friend have both bought the castings for the 3 inch vertical Weir pump (originally Southworth engine design, now sold through Blackgates). We built them (in lock down) independently and when attempting to run on air they both suffered the same problem. The air was continuously vented through the exhaust port? The engines would not run. My friend is a very able and experienced model engineer, I less so, however between us we are puzzled what is happening. Both valves move freely past each other and seem loose enough on their spindles / piston to contact the valve plate and ports. Making a Perspex valve chest cover did not reveal anything obviously wrong in the valve chest. Have we both made the same error in our machining? We know these engines can work - we have seen them! Any suggestions very welcome
Martin
Thread: Separating front and back pressure gauge
27/08/2020 18:12:35
Just tried it and it worked a treat. Gentle tapping with a small hammer and an aluminium rod as a punch. Careful to move it around the circumference to get an even movement. Found 2 raised pips formed on the inner casing I presume deliberately to create grip. Sanded them a little flatter, grip still adequate but now far easier to separate.
Thanks again Zan
Martin
25/08/2020 18:52:03
Thanks Zan - That sounds an excellent idea - I will give it ago.
Martin
24/08/2020 17:02:07
Hi folks - I was wondering if anyone had any tips for separating the front and back of small pressure gauges. With the two I have the back slides into the front telescopically. This seems to be a very common fitting. The fit is very tight and I have yet to find an "easy" way to separate the two halves to enable me to mark the red line on the scale.
Any thoughts gratefully received
Martin
Thread: Blower pipe V blower ring.
15/07/2019 18:40:17
Many thanks chaps - I think the best thing is to make a ring, perhaps with nozzles which can be swapped and give it a try. Its not at all difficult to go back to the pipe if there is no obvious improvement. I will start with 1mm holes.
Martin
14/07/2019 20:11:57
I have noticed how some locos have a simple blower pipe (mine included), others a blower ring. I was wondering what the advantages and disadvantages of the two systems are? A few random thoughts come to mind.
Pipe is relatively easy to build?
Ring truer to prototype?
Pipe less prone to blockages (wider nozzle)?
Does a ring make more efficient use of steam, do you get more draught from a given steam volume?
Has anyone substituted one for the other, if so why, and was it an ‘improvement’?
Looking forward to the forums thoughts
Martin
Thread: Trolley wheel arrangment
14/04/2018 20:04:27
Interesting thought about the availability and cost of materials. It was the idea of spreading the load and stopping 'flange drag' the which sparked (my not particularly well thought through!) musings. It is also interesting to ponder how often ideas were implemented (or not) for less than fully logical reasons! Thank you for the ME lead – so off to the club library later in the week.
Martin
13/04/2018 18:04:04
Very interesting - thank you all. I was wondering why the Victorians thought it was worthwhile? It does sound rather complex and costly?
Martin
13/04/2018 08:11:18
Thank you chaps - makes perfect sense!
Martin
12/04/2018 19:30:41
I am going to build a slightly elongated drive trolley, long enough for myself and a couple of passengers (grandchildren!). First thoughts were to build a couple of sprung 4 wheeled bogies and have one at the front, the other at the rear – a conventional arrangement. I then wondered about making 4 x 2 wheeled sprung 'bogies' and distributing them along the length of the trolley. The 2 sketches show the alternatives, the X marks the centres of rotation. I would appreciate any opinions as to the advantages and disadvantages of the 2 designs. I have never seen the distributed arrangement so presumably it has significant problems?
Martin
Thread: modeng2000
16/07/2017 11:36:03
Hi - I would like to buy your Warco Mini Formit but can't find any contact details.
thanks
Martin
Thread: MEX Photos for those that stayed home
18/09/2016 17:33:39
Big enginnering, small engineering - all in one place - terrific!
Martin
Thread: Centre finding small holes
11/10/2015 17:13:38
Some terrific ideas. Spoilt for choice!
I think I will try the 60 degree cone method and then clamp the part down, Put a button / bar in and clock with my edge finder and DRO - should be interesting.
The hole edge might have a very slight amount of uneven wear on it - but using the cone should get me very quickly into more or less the correct position, the button/ bar should allow me to do any correction needed.
Many thanks folks.
Martin
10/10/2015 19:58:44
Hi Folks - I have a 5mm diameter hole in a 10mm thick flat mild steel part.
I Need to drill it out to 7mm. I have DRO on the mill and have often indicated larger holes (for centre finding) using my 4mm edge finder, however on such a small hole the finder virtually fills the hole and it is difficult to tell when it meets the edge as the hole constrains the throw. I am sure someone must know a cunning trick on how to centre small holes?
Martin
Thread: WARCO WM-250 lathe family and WM16 mill - 001
01/09/2014 17:27:40
Thank you very much George - certainly worth try
Martin
29/08/2014 17:28:11
I posted this earlier - I think in the wrong place, so I am trying it here –
I was wondering if anyone had any useful tips when tramming the WM16. After using the DTI and finding the correct head position, when you tightening the 2 head lock nuts it pulls the head around spoiling the setting. I end up trying to compensate for this ‘pull’ by setting the tram over to one side by the amount the head will pull. The whole process can be a little frustrating as it is difficult to guess the amount to offset the tram. It can take quite a few attempts before you get it right.
I made and fitted an extra steady for the left hand side of the head to match the one supplied on the right – this helps a little.
Any ideas gratefully received
Martin
