Stub Mandrel | 18/12/2010 18:21:07 |
![]() 4318 forum posts 291 photos 1 articles | Hi Mike, This may seem a stupid question, but... what sort of work does/did a coppersmith do? I ask as my maternal grandfather was a coppersmith in the RAF, but he died while I was still a baby. The one bit of his work I saw was magnificent - a perfect little lost wax casting of a Spitfire, from a single old penny . Sadly it was not found when my Nan died; perhaps it just got junked ![]() Neil |
KWIL | 18/12/2010 18:51:45 |
3681 forum posts 70 photos | Coppersmiths, some of them made the copper tops for GWR chimneys and all the pipework. |
John Olsen | 18/12/2010 23:01:45 |
1294 forum posts 108 photos 1 articles | Coppersmiths work in general would be sheet metal work bent, beaten, rolled and otherwise formed, and fastened with rivets, or hard or soft soldered. Those gleaming copper kettles in the old fashioned farmyard kitchen would be the work of the coppersmith. A coppersmith would be a very handy fellow to have about if you were building a model locomotive boiler! There were also tinsmiths, who would have had much the same range of skills. My Great -great grandfather who came from near Trogstad in Norway was a tinsmith. regards John |
Nicholas Farr | 18/12/2010 23:26:26 |
![]() 3988 forum posts 1799 photos | Hi, yes coppersmiths, tinsmiths, silversmith, blacksmith, ect, usually specalise in the associated metals. Take the blacksmith for instance, which is what I started in when I first left school, worked mostly with wrought iron or black steel (although it was a blue coulor) which it was, more or less, as wrought iron was phased out when I first started work.
Regards Nick. |
Sam Stones | 18/12/2010 23:47:33 |
![]() 922 forum posts 332 photos |
Hi Nick, Apologies to Clive also! I know this is something of a digression from Silver Soldering, but . . . On his marriage certificate c1910, my grandfather’s occupation indicates that he was an Agricultural Engineer. I have admired this detail since I seem to have followed suit. However, in those days, would an agricultural engineer be more of a blacksmith? Regards to all, Sam |
Nicholas Farr | 19/12/2010 00:20:19 |
![]() 3988 forum posts 1799 photos | Hi Sam, yes I agree a little OT, but agricultural engineers were/are blacksmiths, which was one of the main source of work where I first started. Some blacksmiths also shod hoarses, which of course is part of a farrier's job. A farrier may not have made hoarse shoes though, but a blacksmith would, but the blacksmith wasn't always a farrier.
However both agricultural engineers/blacksmiths basic material is black iron/steel. Modern agricultural engineers are involved in a lot more technolegy, and probaly steer away from the blacksmith tag. The machines your granfather worked on were most likely hoarse drawn and low tech compaired with todays machines.
Regards Nick. Edited By Nicholas Farr on 19/12/2010 00:23:53 |
Sam Stones | 19/12/2010 03:08:13 |
![]() 922 forum posts 332 photos | Nick,
Now you've got me thinking. My grandfather married into a family of Cab Proprietors, but this is now getting too far from Silver Soldering. Perhaps we should continue this on a private basis? Sam |
Ian S C | 19/12/2010 10:25:05 |
![]() 7468 forum posts 230 photos | A Farrier also dressed the horses teeth, well i supose it was similar to fileing the horses hooves. Each in there age were the "hight Tech" engineers of there time, and worth following. Ian S C |
Michael Cox 1 | 19/12/2010 12:30:35 |
555 forum posts 27 photos | You can buy spirits of salt (hydrochloric acid) from Toolstation (www.toolstation.com). This is a very effective pickle for copper and steel when diluted 1 part spirits of salt to 5-10 parts water. Make sure you keep it in a well stoppered bottle since the fumes promote rapid rusting af any steel around.
Mike |
Stub Mandrel | 19/12/2010 12:35:05 |
![]() 4318 forum posts 291 photos 1 articles | Any ideas what sort of woork it would be in the RAF? Beating up intake manifolds? Neil |
Ian S C | 19/12/2010 13:31:07 |
![]() 7468 forum posts 230 photos | Perhaps wave guides, and other bits for radar, and other radio and electronic gear. Ian S C |
Michael Kilpatrick 1 | 19/12/2010 15:13:07 |
![]() 10 forum posts | @Stub Mandrel Shipyard Coppersmithing consisted mainly of pipe manufacture(Copper-CuNi) With some rather substantial thick walled (CuNi) pipe used on Hydraulic & High Pressure Air Systems. Connection of this pipework was facilitated with a Phosphor Bronze Fitting containing an "O" Seal grove. These fitting were Silver Soldered to the pipe. This process has now given way to welding pipes in situ. Regards Mike |
Stub Mandrel | 19/12/2010 17:05:35 |
![]() 4318 forum posts 291 photos 1 articles | Perhaps wave guides, and other bits for radar, and other radio and electronic gear. A bit early for that. I saw a photo of him in the Sudan or Egypt with a big biplane airliner (either Hengist or Horsa) in the background. My other grandfather worked on such things, and sonar, in all three services! Neil |
