Creating rectangular blind hole
JasonB16/04/2023 13:37:12
25215 forum posts
3105 photos
1 articles
Though Hurco say you can do a rectangular holesmiley
Rowan Sylvester-Bradley16/04/2023 16:17:58
88 forum posts
Posted by duncan webster on 15/04/2023 20:37:47:
Can't you redesign it away?#
I can't see how. It is a tool that has to fit an existing piece of machinery, so I can't change any of the dimensions. I made it a blind rather than a through hole because I think I need the additional strength that this will provide.
Rowan
Rowan Sylvester-Bradley16/04/2023 16:24:07
88 forum posts
If I am going to drill 2 mm dia holes 30 mm deep in mild steel, any hints on keeping the holes straight? If the drill wanders off, it will defeat the whole object. Should the drill be carbide, or HSS?
Thank you - Rowan
Jeff Dayman16/04/2023 17:07:04
2356 forum posts
47 photos
If I absolutely HAD to make a rectangular hole as you described, I would try to tackle it one of two ways. 1. make two pieces of steel one or both with a milled through slot, weld them together to make the part with an open slot. Then weld in a plate to make the slot blind again. 2. Build a simple EDM machine , maybe to the Ben Fleming plans like mine, and burn the slot into the steel. Corners with EDM can be square or radiused, but flushing during EDM will be better with radiused corners. (EDM is short for electrical discharge machining - not new, novel, or difficult to do)
The problem you will likely face with drilling 2 mm dia holes 30 mm deep is that they will likely wander all over and your slot will have wonky sides. You would be better off using an 8mm endmill two passes slightly apart to make the 10 mm width, and mill the slot thru, then file out the corners as needed. Afterward, weld or silver solder in a plate to make the slot blind.
As others have said, it is best to avoid blind slots especially rectangular ones, at the design stage, if possible.
bernard towers16/04/2023 18:46:11
1221 forum posts
161 photos
Is it possible to two 15mm slots from either end then silver or weld a cap on?
Huub16/04/2023 22:08:40
220 forum posts
20 photos
Posted by Rowan Sylvester-Bradley on 15/04/2023 14:52:02:
I need to machine a rectangular blind hole in mild steel. It needs to be about 10mm wide by 20mm long by 30mm deep. It doesn't matter if it has slightly rounded corners. Is this even possible? What is the best way to do it? My current plan is to use an end mill (say 5mm) to make the basic shape, then use a smaller end mill (say 2mm) to square off the corners (if I can get a 2mm end mill that's long enough and stiff enough to cut 30mm deep). Will this work? Is there a better way?
Thank you - Rowan
Rotary broaching a rectangular blind hole is not a problem. You can't get to the bottom all the way. The long cutting edges generates high cutting forces. You could mill the hole and rotary broach the round corners square. I expect you get to 1 mm off the bottom.
You can do the same with a square broach if you do the corners one by one.
Ronald Morrison17/04/2023 11:22:09
98 forum posts
4 photos
Posted by Rowan Sylvester-Bradley on 16/04/2023 16:17:58:
Rowan
Instead of making this a difficult project with the blind hole for strength, can you change the material to gain the extra strength with an open hole?
Dusty17/04/2023 12:17:19
498 forum posts
9 photos
Rowan
It would be helpful if you were to explain exactly what you are trying to do and why. In a previous life I was a toolmaker and worked in a special purpose machine dept for a while, there were several occasions when drawings came down from the drawing office and I needed to explain to the draftsman why a component could not be made in the way it was drawn. There're many on this forum who have a lot of experience and with all the information will be able to help, but all the information is needed.
HOWARDT17/04/2023 12:48:57
1081 forum posts
39 photos
As has been said all the information of what is intended use is really required. I used to drill or slot holes in the corners, actual placement of the holes depends on which sides your are trying to make a tolerances fit. By positioning the hole centres on the corners you shorten the contact lengths dependant on cutter size. If you align the radius of the cutter outside the rectangle you can produce a size slot on all sides. Clearing the corners like this allows you to use say a 8mm diameter cutter to finish all sides and give you a chance with the depth.
SillyOldDuffer17/04/2023 13:45:10
10668 forum posts
2415 photos
Posted by HOWARDT on 17/04/2023 12:48:57:
As has been said all the information of what is intended use is really required. I used to drill or slot holes in the corners, actual placement of the holes depends ...
+1 The difficulty increases with the sharpness of the corners, and these may not matter at all functionally. I've seen a real-world example like this, where there are no corners!
Most likely done this way to remove the need for tricky machining, but perhaps also to provide stress relief.
Rowan Sylvester-Bradley17/04/2023 15:10:53
88 forum posts
Yes, but I still need to drill small holes 30mm deep, and the problem of the drill wandering and not ending up in the correct position remains. I am gravitating towards milling the basic hole, and squaring up the corners with a specially ground cold chisel.
Rowan
peak417/04/2023 16:37:05
2207 forum posts
210 photos
Posted by JasonB on 16/04/2023 13:37:12:
So do Polygon Solutions
https://www.polygonsolutions.com/rotary-broaches/special-form-rotary-broaches/rectangle-rotary-broach/
I've not used it yet for various reasons, but I did recently buy a rotary broaching tool holder off ebay a little while ago.
I'll not link to it, as it was dispatched direct from the far east, and the price has risen dramatically now they only have one left.
Bill
not done it yet17/04/2023 16:43:14
7517 forum posts
20 photos
I usually keep away from difficult-to-do ideas and make a work-around.
Here is yet another option: Buy (or probably make) a square broach and make a through hole, filling the unwanted portion afterwards.
Tony Pratt 117/04/2023 16:56:17
2319 forum posts
13 photos
Posted by Rowan Sylvester-Bradley on 17/04/2023 15:10:53:
Rowan
Who says you have to drill small holes, 4/5 mm drilled hole should be fairly doable?
Tony
SillyOldDuffer17/04/2023 17:31:25
10668 forum posts
2415 photos
Posted by Tony Pratt 1 on 17/04/2023 16:56:17:
Rowan
Tony
Yes, indeed. Rule of thumb, a twist drill will stay straight for 5x diameter, so 30mm deep calls for a 6mm drill. Actual size (10 x 20 with 6mm corners, the result looks like this:
An advantage of oversized corner holes is they only have to be straight enough to accommodate the male corners, that is not critical at all. So safe enough to drill 5mm corner holes 6x deep, or even 4mm 7.5x deep. Beyond that, keeping a twist drill straight becomes ever more difficult.
As to cutting the hole, I would remove most of the metal by chain drilling, probably with a 9 mm drill, then mill a 10mm wide slot, before finishing the corners with a 6mm two-flute. (same diameter as the corner holes). Chain drilling saves wear on my precious end-mills. As the slot is deep, 6 and 10mm dia end-mills should be used for maximum stiffness - small diameter end-mills are likely to bend, even if long enough. (There's much to be said for chiselling, though it's not very accurate.)
All this assumes big corner holes are acceptable! If not, truly rectangular holes are hard to machine. Through holes are usually broached, but a precision blind hole calls for EDM or lasers.
I do my best to wimp out when faced with difficult machining jobs: with luck a compromise is just as good provided it's strong enough and not plug-ugly in public. Often fixed with paint and putty...
Edited By SillyOldDuffer on 17/04/2023 17:31:46
Rowan Sylvester-Bradley17/04/2023 17:43:20
88 forum posts
Thank you for your suggestions. Some of these sound as if they would work for my project.
As someone previously pointed out, the holes don't have to as far apart as you have shown them. They can be moved in so that they almost touch the corner of the rectangular piece that fits into this hole, plus a bit to allow for drill wander.
Rowan
John Doe 217/04/2023 17:44:00
441 forum posts
29 photos
Slight thread drift but just out of interest, how are the square holes in 1/4, 3/8, 1/2 " drive sockets made? Are they drop forged around a square former or do they have a square former pushed through them when they are hot and soft blanks?
Ditto allen bolt heads?
JasonB17/04/2023 18:16:19
25215 forum posts
3105 photos
1 articles
The small (2mm) holes were suggested as an alternative to the 1mm radius that the OP's thoughts on using a 2mm milling cutter would leave.
If you do decide to drill 2mm then spot drill first, then use a stub drill which will get the hole 10-12mm deep and is less likely to wander and should then help guide a standard length drill to complete the hole. Chances are a 2mm drilled hole will be straighter than the deflection from a 2mm milling cutter at those sort of depths.
bernard towers17/04/2023 19:32:05
1221 forum posts
161 photos
Most cheap Allen bolts are forged or pressed but if you really pay the money they will be broached especially for traceable kit.
vic francis17/04/2023 20:59:10
125 forum posts
21 photos
Hi Rowan the article by Mr Thorpe is in my pics folder here...!
