Hydrogen
Vehicles powered by what
Howard Lewis22/07/2021 18:37:43
7227 forum posts
21 photos
Vic
You are quite right about the sun shining, but on a practical level you won't need SPF30 at night or when it rains will you?
We need reliable generation of power, Hydroelectric, tidal or wave. (ideally minimal cost ) The last two are more reliable, because sometimes rivers dry up, and we have seen pictures of reservoirs drying out.
Speedy Builder522/07/2021 19:24:49
2878 forum posts
248 photos
Lets hope that if they make hydrogen from sea water that they don't increase the sodium and chloride mix, but I expect mankind will !
Bob
not done it yet22/07/2021 20:24:05
7517 forum posts
20 photos
Posted by Speedy Builder5 on 22/07/2021 19:24:49:
Bob
Why would it? Only if the hydrogen leaks (and is lost to the atmosphere) would this occur. The hydrogen, when burned, will simply be converted back to water and eventually return to earth (as rain) and end up back in the oceans.
Melting snow caps and glaciers is likely a much larger effect - diluting the sodium chloride in the oceans.
Edited By not done it yet on 22/07/2021 20:26:29
Steviegtr22/07/2021 23:15:38
2668 forum posts
352 photos
Lord Bamford did explain that the Electric battery idea is dead in the water. Not enough rare minerals to make it work worldwide. He also said it all began with the Elton Musk thing. Don't know him personally. Is he poor. MMn.
Digressing , i worked for 2 1/2 years at Olofines 6. Which was a ICI oil refinery at Redcar. The site was huge with over 2000 workmen & women. I worked on Electrical & Pnuematic instrument installation. The site was mainly to refine oil for Ethylene, with hundreds of side products. The site was completed & it was to be stored frozen underground in old pits. Basically the whole project went titties up because a foreign company could supply the same product for peanuts.
The moral here is, did the oil company go bust. No The oil companies will be the people who will develop any product that will eventually rein in the motor industry. Pistons at dawn.
Steve.
John Olsen23/07/2021 00:17:02
1294 forum posts
108 photos
1 articles
The reason I asked above about the hydrogen mines is because of course there aren't any. All hydrogen has to be manufactured, at present mostly from fossil fuel stocks, in the process releasing lots of carbon dioxide into the atmosphere, a thing we were supposed to be trying to avoid. The Germans used to use a different process of passing steam over red hot iron, the iron of course having been made by the usual process involving coal and lots of carbon dioxide.
The point is that hydrogen is not a source of energy, it is merely another way of storing energy and transporting it from place to place. The question them becomes is it a good and economical one? Hydrogen is tricky stuff, it is a small molecule and loves to escape out of containers, through the pores of the metal if necessary. It also ignites quite easily. It takes a lot of energy to make the hydrogen, so the electricity generating system will need upgrading whatever you do.
If you are going to burn the hydrogen in an IC engine, you need to consider that the efficiency will be quite low, so you will probably need to carry more fuel. For this technique you would probably be better to synthesise hydrocarbon fuels, using water and CO2 extracted from the atmosphere. The resulting fuel can then be distributed using the same networks as at present. Since the C02 is extracted from the atmosphere, the process is carbon neutral, and the only major technology change is at the refinery and the power plant providing it with the energy needed for the synthesis. But the overall efficiency remains low since IC engines are pretty abysmal at best.
If you decide to use hydrogen fuel cells, the efficiency will be much higher, since from what I hear the fuel cell can be up around 90% or so, and the electric motor that it runs can also be pretty high, much better overall than the IC option. But the fuel cell currently requires pure hydrogen although I believe there is work being done on cells that can accept hydrocarbons. So you tend to need a new fuel distribution system. The other thing to consider is that the cells tend to require rare and expensive catalysts inside, more so than batteries. It seems that it is possible to eliminate the rare metals from Lithium batteries, it is going to be much harder to eliminate the catalysts from fuel cells.
So long term I don't know what the best solution will turn out to be, but hydrogen is not a panacea. In the meantime, if a battery electric suits your needs then you should probably consider one...they are not suitable for every use case, but if everyone who could use one had one it would make a difference.
duncan webster23/07/2021 01:22:25
5307 forum posts
83 photos
Despite being called a rare earth, lithium is quite common. It is the 25th most abundant element. There is even talk of mining it in Cornwall, but then they keep on talking about cornish mining and nothing ever happens. Can you imagine the greens allowing it even for zero emmision technology
John Olsen23/07/2021 02:44:59
1294 forum posts
108 photos
1 articles
Yes, Lithium is not really a problem. There was concern about things like cobalt being needed for some of the Lithium battery types, but I think the need for that has been reduced or eliminated now.
I don't think Lithium is actually a rare earth anyway, at least not on my copy of the periodic table. Where the rare earths come in is for permanent magnets which may be in the electric motors, but then, they don't have to be used there either. Electric cars can use ordinary off the shelf AC induction motors, and I have driven one that did.
Funny thing about mining, once it has stopped it is romantic and a great tourist attraction.
Nigel Graham 223/07/2021 08:52:06
3293 forum posts
112 photos
The new "mining" for lithium proposed in Cornwall (in fact has work started) is not conventional rock-breaking.
It is extraction of lithium ore that has become dissolved naturally in deeply-circulating water, including that flooding old mines.
The brine is pumped out of boreholes, the minerals are extracted and the water returned (presumably down a different hole.)
Michael Gilligan23/07/2021 08:59:04
23121 forum posts
1360 photos
Posted by Howard Lewis on 22/07/2021 14:34:32:
The insuperable problem that everyone faces is that of folk, often politicians, who make wild promises without understanding just what is involved in bringing those promises to completion, if possible.
The need is to think things through completely. But that is a task for mere mortals, such as civil, electrical and mechanical Engineers. THEY are the people who actually find and apply solutions to problems.
It is all very well someone saying things like "By 2030 we shall be Zero carbon" without thinking about […]
There’s a splendid example of that, here: **LINK**
https://www.bbc.co.uk/news/uk-politics-57927389
pgk pgk23/07/2021 09:00:22
2661 forum posts
294 photos
There was a BBC news article re Cornwall lithium a while back. Presumably the concentration in water and whatever method is used to extract it is considered economic. One of my old school chemistry statistics was that there's 38lbs of gold in a cubic mile of seawater - just a matter of sorting it out from the 120 million tons of salt....
pgk
SillyOldDuffer23/07/2021 11:03:27
10668 forum posts
2415 photos
Posted by Steviegtr on 22/07/2021 23:15:38:
Lord Bamford did explain that the Electric battery idea is dead in the water. Not enough rare minerals to make it work worldwide. He also said it all began with the Elton Musk thing...
Steve.
With respect Steve, Lord Bamford said no such thing, or anything like 'Batteries are dead in the water'. No need to believe me, watch the video! See the tag line 'Is hydrogen, rather than electric, the future for big-engined machinery?'
Lord Bamford is clear about the context, for instance he refers to: 'Issues with our type of product', and the requirement being 'a different thing from saloon cars'. The video has a nice graph showing where JCB think the boundary between batteries and Hydrogen IC is. Basically, batteries are OK for small earthmovers used for up to 6 hours at a time, but no good for heavy earth movers run round the clock, or the kind of American truck supplied with two drivers who work shifts in order to cover more than 1000 miles per day. The video also explains batteries are good for urban and short range motoring. He makes a good point about the cost of converting to electric cars : at the moment they are expensive and there is no second-hand market pushing prices down. However, he didn't explain (why should he) that the total cost of ownership of electric cars is already lower than the total cost of owning an IC vehicle. It's because electric vehicles are cheaper per mile and they require much less maintenance. From now on, electric cars will get cheaper, while IC cars get more expensive.
Most arguments in favour of petrol and diesel assume the price of oil at the pump will stay the same forever. Oh dear, it's not! There are about 30 million cars on the road in the UK; the Chinese market for new cars is about 25 million per year : lots of new customers are chasing a dwindling natural resource, so guess what will happen to the price.
I don't expect IC engines to be replaced by a single technology; there's no reason why it should. At the moment batteries look to be the best bet for commuter motoring, but they're not suitable for heavy duty. Storing Hydrogen is likely too dangerous for domestic use, but the risk could be managed in a commercial vehicle, in which case no objection to Hydrogen IC.
Matching different technologies to the job in hand has always been a feature of engineering. Imagine it's 1944 and we're considering how best to power a ship. Choices are reciprocating steam with saturated or superheated steam, reciprocating steam with a turbine driven by the exhaust, turbo-electric, geared turbine, diesel electric, geared diesel, and direct diesel. The debate is interesting as a man-in-pub discussion, but in 1944 the professional engineer had to carefully balance several factors. The speed and size of the ship, reliability, maintenance and personnel costs, fuel cost & availability, fuel efficiency, weight, space, relative cost, vibration and noise, the effect on powering auxiliaries and fuel consumption at fractional powers. (Gas turbines have the best fuel efficiency provided they are run flat out but efficiency at reduced power is dreadful. Good choice for cruising, rubbish for stop-start work.)
This graph, which is one of several ways of comparing maritime choices in 1944, illustrates the need to look closely at all the alternatives:
For example, ignoring poor fuel efficiency, in 1944 saturated steam was a poor choice for a big ship requiring more than 5000SHP because reciprocating steam maxes out below that power.. Another graph shows reciprocating engines are also overweight while a third shows they're high maintenance. But they were reliable, burned widely available cheap coal, and are good at stop-start work. However, in 1944 they were on the way out because super-heated engines were cheaper to run overall, and their clock was ticking because diesel is even better. However, the rise of Diesel depended on improving the purity of cheap diesel oil, which the chemists did during the 1950s.
At the moment diesel is king at sea. But it too will have to change... Technology and engineering never stand still.
As to the power of big oil, it's fading. Quite interesting that they are now being sued across the US because documentary evidence has emerged that oil companies knew decades ago that their product is damaging, and they've persistently lied about it.
Good for JCB I say - we need ways of powering large machines without burning carbon. The engine part of the problem is relatively easy and the difficulties weren't tackled by the video: how exactly do you distribute large quantities of Hydrogen safely? An unfortunate feature of Hydrogen is that small leaks form explosive mixes; wouldn't be difficult to demolish a garage if the car sprang a tiny leak!
Edited By SillyOldDuffer on 23/07/2021 11:06:26
Jon Lawes23/07/2021 11:10:58
1078 forum posts
I like wild Promises. Volvo originally pledged that no-one would die in a Volvo car by 2020. They didn't succeed, but if an outrageous target means strong progress derived from it then I'm alright with it.
If we set a wildly high goal then even making progress towards it is better than sitting around saying "That will never work" about everything.
Bo'sun23/07/2021 11:19:12
754 forum posts
2 photos
While nothing to do with hydrogen powered vehicles, although I 'm sure the arguments are valid.
I'm not convinced this electric vehicle lark has been thought out properly. Just a couple of examples: My Father lives in a col-de-sac on a green. Is he expected to trail an extension lead across the path and green to charge his car? In 2030 we come home from work at 5 o'clock and plug-in our cars (because we're s**t scared of not having enough charge) and then the lights go out.
mgnbuk23/07/2021 12:07:34
1394 forum posts
103 photos
Where do you get that information from, Dave ?
One of the car magazines (Car IIRC) ran a comparison test recently using an current IC car & the equivalent BEV from 3 manufacturers - in all cases the total cost of ownership of the electric version was higher than the IC version. Considerably higher in some cases.
This may change in future, but right now BEVs appear to be an indulgance - those who can afford them do so & then crow about their supposedly "green" credentials. For some they are a genuine alternative, but for many not so. The only electric car I have seen so far that I may actually consider buying (and could afford to do so) is the Citroen Ami - a very different solution to urban mobility than just trying to replicate the performace of an IC car. Very basic, limited performance (28mph max) and range (5.5KwH battery gives around 30-35 miles & recharges overnight form a 13A socket) ) but cheap (around £6K in France - not available here yet) and made to suit a licence-free category of vehicles in France that makes driving one available to 14 year olds after limited instruction. As my weekly shopping trip is around 20 miles, mostly in built-up areas, such a vehicle would work for me there.
I don't think that is the case. There is more to our use of oil than just burning it for fuel. One of the ingredients of lithium batteries is needle coke - an oil refining by product. Needle coke & pitch are the primary ingredients of manufactured graphite - used in many areas of manufacturing that you are probably unaware of (I know I was before I stared working with the stuff), particularly in metals manufacture (arc furnace electrodes etc.). Carbon black (oil product) used for rubber manufacture. Plastics for pretty much anything (mainly oil product). Carbon fibre starts out a s PAN yarn - oil product. Graphite felt insulation (used in vacuum & semiconductor furnaces) starts out as rayon fibre mixed with phenolic resin (oil products).
The list goes on - we are heavily dependant on oil at some point for virtually everything we make or use today & I don't hear much about finding "green", oil-free alternatives to those. There is a much bigger issue than what we use for a transportation energy source that does not appear to have been addressed by the "sound bite" politicians.
Nigel B.
Howard Lewis23/07/2021 16:45:53
7227 forum posts
21 photos
Nigel B is right.
Battery technology has long way to go match even a small IC engine vehicle.
My bottom of the range Euro 6 compliant 1 Litre, with a 35 litre petrol tank will, driven carefully, with a brimful tank, JUST cover 500 miles.
So I can brim the tank, drive to and from The WaterWorks Museum to volunteer, and arrive home with lots of range left. About the only BEV that cannot quite match that costs three times as much . So out of my price range, and even under winter conditions, with lights and heater in operation, my puddle jumper will still bring me home with mileage to spare.
Currently, the nearer cars in size to mine, without a time consuming recharge en route, would strand me before I got home..
On a commercial scale, a 44 ton truck would carry a lot less payload because of the weight of batteries, or gas cylinders.
Over 30 years ago, a friend was Chief Engineer on a large oil tanker. Propulsion? Steam turbine electric, fueled by bunker fuel (The stuff that has to be heated to make it flow). By modern standards, not green, but the best economically, at the time, presumably.!
The "Emma Maersk" and her sister ship are no longer the worlds largest container ships, but they are BIG, and powered by a huge .turbocharged two stroke diesel engine (100,000 + hp ) ,
Further development required in various fields before the internal combustion engine is sent for scrap, despite what the politicians say..
Bo'sun23/07/2021 17:01:03
754 forum posts
2 photos
Posted by mgnbuk on 23/07/2021 12:07:34:
Heard exactly the same some years ago when the Toyota Prius burst onto the scene. From the Society of Motor Manufacturers and Traders (SMMT) if I remember rightly.
As a small island on a vast planet, we're not going to save it until the big players come to the party. Too many politicians ticking green boxes and companies wanting to "cash in" on peoples consciences if you ask me.
Vic23/07/2021 17:24:10
3453 forum posts
23 photos
I’ve watched quite a few programmes involving the movement of very large bits of machinery. In many cases it was done with electric prime movers because of their compact size and tremendous power. Ironically they were fed by Diesel engines. I’m guessing size for size electric motors are far more powerful than ICE?
Roger Best23/07/2021 18:26:31
406 forum posts
56 photos
Another great thread. Pretty positive I would say.
Bamford's work is excellent, it should protect his share price enormously.
The graph showing when to use batteries was excellent. The position of the curve will move a bit as technology develops but it shows that Musk would be wise to look at Hydrogen for his semi tractor.
Another very good video about hydrogen cars is James May talking about his new car. What hit him was how much better the new car was, Toyota having shrunk the fuel cell and electrics to produce a car that was a vast improvement on the old model but with a reduced list price.
link
Toyota are famous for not embracing EV as hydrogen is better in their opinion. Japan is notable for not having its own fossil fuel supply so they invested heavily in nuclear and using hydrogen is seen to be better than importing oil, so a significant hydrogen distribution system has been built.
One point that I haven't noticed is that modern cars are very good. Our Honda Civic is 18 years old and is only just starting to need the TLC that other cars I have had needed well within ten years of duty. My 100,000 mile SMAX is not so well built but still drives very well and I am looking forward to several more years of use, there seems to be plenty of the early ones about and plenty that have done 150k so it should be good for at least 5 years more.
It is quite probable that many people will keep their cars on the road while they can afford the fuel rather than invest money and charging time in a BEV.
not done it yet24/07/2021 12:31:18
7517 forum posts
20 photos
I just watched that video.
Simply him comparing his new car with the old one? Yes. As a car journalist, would he provide all the down-sides? No. Not many of his profession would do that - they lose the ‘jollies’ they get from the car makers, wouldn’t they?
No mention of whether his hydrogen is ‘green’ or if it is simply produced from fossil fuels.
He could not really avoid the availability of re-fuelling points, but that does not affect Toyota.
Do Toyota not make battery only EVs? Oh yes they do!
’Orses for courses’? Definitely.
Fuel cells must refine the combustion air before use - or they become ‘poisoned’ (a bit like catalytic converters on cars if leaded petrol was used). There would not be any ‘vehicle engine emmission’ pollution to clean up if FF ICE cars were no longer running. But the fuel cells would still require cleaned combustion air, even if all other vehicles were BEVs (likewise with no ‘tail-pipe’ emissions).
We all need to watch/listen more carefully - and analyse/consider what is behind these videos. I’m quite sure of that.
J Hancock24/07/2021 12:49:35
869 forum posts
What 'they ' are not telling you about the Cumbrian coal-mine.
'British/Tata/Corus/Bejing Steel Scunthorpe has been/is being bought by the Chinese. A major consideration is cheap steel-making coal .
"Fine ", we say , we have loads in Cumbria , we'll build a mine for you.............................
