Steve Skelton 1 | 08/05/2019 10:23:00 |
152 forum posts 6 photos | As a slight digression - I always buy the fluids in bulk liquid format not in a pressurised aerosol can. I find that to get the right quantity where I want it and not everywhere I don't is to modify an old Vicks nasal spray. Take the top off and pry out the insert which holds the dip tube, pull out the dip tube then drill out the insert from above slightly undersized to the dip tube and force it in to prevent leakage. Then drill the top oversized to allow the dip tube to pass through - fill the bottle with your preferred lubricant then hey presto a droplet control dispenser. I hope these photos show it better than I have described it. I find a kitchen roll sheet rolled up and wrapped around the dip tube keeps everything dry and clean. I have been using this for years and it works a treat.
Edited By Steve Skelton 1 on 08/05/2019 10:28:14 Edited By Steve Skelton 1 on 08/05/2019 10:31:56 |
Michael Gilligan | 08/05/2019 12:59:52 |
![]() 23121 forum posts 1360 photos | Penetrates, Lubricates, AND Decongests
Harry Wilkes | 08/05/2019 15:32:18 |
![]() 1613 forum posts 72 photos | Posted by Michael Gilligan on 08/05/2019 12:59:52:
Penetrates, Lubricates, AND Decongests I once asked an emplyee why they call one of the managers Vic ? He replied because he's a little squirt that gets up your nose H
Edited By Harry Wilkes on 08/05/2019 15:32:40 |
Grindstone Cowboy | 26/03/2023 20:02:49 |
1160 forum posts 73 photos | Just found this photo online and thought this thread would be the most appropriate place for it. Rob |
Nigel Graham 2 | 26/03/2023 22:53:09 |
3293 forum posts 112 photos | I wonder where Plus-Gas would score on that test? One flaw of course is how closely-matched the corrosion grip was, across the range of test-pieces. I don't doubt there "home brew" but I would think the acetone would evaporate rather than soak in, leaving the transmission fluid to do the real work, but I suppose it helped the oil to penetrate the joint. I wonder what the "local machinist group" was engaged in for all members to need share batches of the stuff, apparently regularly! Searching by the name on the photo revealed "Server not found". Perhaps dissolved in all that acetone. WD-40 is mainly white spirit, with some sort of thin oil dissolved in it. . In front of me is an "Otex" (ear un-blocker) dropper bottle with a little spout. it is very small but a candidate applicator for small spots of lubricant in tasks like tapping. |
Bazyle | 26/03/2023 23:44:04 |
![]() 6956 forum posts 229 photos | These results have been shown on a number of reports. The point is you want a very thin solvent to carry a tiny amount of oil into the finest gaps and then for the solvent to push-off, ie evaporate. There is only one thing to use for this because it fully meets the criteria and we've all got some knocking around. - 2 stroke fuel. |
derek hall 1 | 27/03/2023 07:11:51 |
322 forum posts | We used to use diesel fuel applied to rusted up or seized stuff, where I used to work, that used to work reasonably well |
Bountyboy | 27/03/2023 08:30:16 |
62 forum posts 8 photos | I bought this from Tool Station, less wasteful than an aerosol, better for the environment, cheaper as buying in bulk and comes with spray bottle. Must admit the price has gone up since I bought it a couple of years ago.
Andrew Tinsley | 27/03/2023 11:44:43 |
1817 forum posts 2 photos | Acetone and my regular ATF fluid are immiscible and separate out in seconds. So what brand of ATF fluid mixes with acetone? If you want 5 litres of WD40 clone, then Smith and Allan is the place to google. Excellent products and good value. Andrew.
Andrew Tinsley | 27/03/2023 11:44:44 |
Nick Wheeler | 27/03/2023 12:32:07 |
1227 forum posts 101 photos | Posted by Andrew Tinsley on 27/03/2023 11:44:43:
That was my experience when I tried it out of curiosity. Considering the cost of both ATF and acetone, I'm not convinced of the monetary saving either. I've only ever found penetrating fluid(of whatever type) to be of any use when the parts were only just past coming apart with the appropriate tool. In those circumstances it's used to get the screw/bolt/nut/pin out quickly so that more drastic methods aren't necessary. It's particularly irritating to be told after you've used heat, violence, hammers, swearing and grinders/drills to get out an already rounded off fastener that Scammer's Miracle Snot would have worked instantly. |
SillyOldDuffer | 27/03/2023 14:32:47 |
10668 forum posts 2415 photos | Posted by Andrew Tinsley on 27/03/2023 11:44:44:
Acetone and my regular ATF fluid are immiscible and separate out in seconds. So what brand of ATF fluid mixes with acetone? ...
Good question: problem of course is that ATF isn't a single straightforward item, it's shorthand for hundreds of different mixtures. Two fluids with the same specification (as an ATF), can even be made from completely different materials. Quite likely the customer has no idea what's in the can, and the only way to find out if Acetone mixes is to try it. About 10 years ago I mixed acetone with ATF successfully, so it's not impossible, and it worked OK. Can't find the can in my garage to confirm what it was! A generic brand bought from a motor factor for this purpose, so I can't link it to a particular car. I guess I got lucky. Can't say it worked better than Plus Gas. It does show how unreliable comparative tables of the 'Penetrating Oils Compared' type are. It says ATF and Acetone are best and that everybody uses it, whilst Andrew reports he can't get the two to mix at all. Like many folk remedies, the specification is inadequate. Worse, the methodology isn't explained, so we've no idea how fair the result is. Done properly, many thousands of different nuts and bolts have to be corroded together, the liquids applied by someone who doesn't know what they are, and undone by someone who doesn't know either. Small samples in comparisons like this are meaningless. And maybe the test ignores the possibility products are targetted at different types of problem: better at some, less effective on others. Amateurs love to believe unlikely mixes of cheap traditional products perform better than commercial products. Usually not! ATF containing a lubricant that will be carried deep into a corroded joint by a light spirit like Acetone certainly works, but the fumes and effect on skin may not be safe enough to sell the mix commercially. And what about shelf-life? Acetone is likely to evaporate quickly on the shelf, leaving pure ATF behind in the bottle that won't penetrate next time. Commercial products are safer, more reliable, and have longer shelf lives. And instructions... Dave |
mark costello 1 | 27/03/2023 18:32:50 |
![]() 800 forum posts 16 photos | Across the pond We have had at least 2 kinds of ATF, one Ford and one Chevy(naturally). It had to do with the type of clutches the transmissions used. Now a days probably every car maker has their own formula, of which Theirs is best. |
Grindstone Cowboy | 27/03/2023 19:05:01 |
1160 forum posts 73 photos | Apart from regretting posting the photo now (only kidding!), here's a story expanding a little on what Mark says about proprietary fluids, I recently changed the clutch on a Citroen C1 - which is the same car as a Toyota Aygo or Peugeot 106. You have to drain the gearbox oil as the driveshafts need to be removed. A quick check of the manual revealed there is only one approved oil - Mobil 75. Wanting to do it right, I started trying to find some (it takes 1.75 litres). According to the Mobil website, my local distributor is, surprisingly, Kwik-Fit. Phoned up and was met with the audio equivalent of a blank stare. "No idea what you're talking about, mate, just get 75W-90 from Euro Car Parts, that where we get ours." A while later, after trying a few other leads, I thought I'd try the Citroen dealer. A bit of confusion and a check on their computer later, they came up with "Oh, we can get it, it's something we'd need to order specially. It'll say Citroen on the label but it's the proper stuff. The price? £119.00 per litre" Needless to say, I just drained the old stuff into a clean container, and put it back in, topping up with the generic 75W-90. I wonder how many Citroen / Toyota / Peugeot dealers actually use the approved stuff when doing a clutch change? Comparing the specs of the proper stuff with the common or garden variety does reveal that the dynamic viscosity figures are quite different. Rob |
Nick Hughes | 27/03/2023 20:42:04 |
![]() 307 forum posts 150 photos | Just in case it's keeping you awake at night :- I've used Opie for quite a few years now, as they tend to stock some "out of the ordinary" oils and greases. Edited By Nick Hughes on 27/03/2023 20:46:04 |
Grindstone Cowboy | 27/03/2023 22:09:40 |
1160 forum posts 73 photos | Good grief! Thanks Nick, makes you wonder about the main dealers, doesn't it? Bookmarked for future reference. Rob |
