First Project
Start machining the model lathe at last
Thomas Staubo31/07/2017 20:50:18
54 forum posts
Aah, that's the same size as the one I linked to. I don't think you can buy any smaller than that.
That means that you have to make your own tailstock chuck from scratch too! laugh
Harry Wilkes31/07/2017 21:48:59
1613 forum posts
72 photos
Nice work yes
H
Ian S C01/08/2017 03:51:39
7468 forum posts
230 photos
You could use the adjustable chuck from Dremel(or similar sized tool). i have a Jacobs Chuck that opens to 3/16".
Ian S C
Martin Kyte01/08/2017 15:14:18
3445 forum posts
62 photos
It does look nice and I hate to say but, but ,
Stuart Turner state that
The Stuart Engineering Lathe has been carefully designed by taking the most interesting elements from lathes in use at the end of the 19th century and combining them to produce an attractive model.
and . . .
The Jacobs Chuck was first Patented in 1902.
Personally I think it would look better with taper drills.
However it is your model and I say this only for information and not at all from a sense of criticism.
regards Martin
David George 110/08/2017 21:42:07
2110 forum posts
565 photos
Machining 4 jaw chuck body.
David
Neil Wyatt10/08/2017 21:54:12
19226 forum posts
749 photos
86 articles
Excellent! Makes me want to make a micro-chuck even without the lathe!
geoff walker 111/08/2017 08:17:02
521 forum posts
217 photos
Yes, top work David, keep the pictures coming and "zoom in" on the finished chuck.
Geoff
David George 122/08/2017 18:17:21
2110 forum posts
565 photos
Just got the lathe going. Started facing and boring some collets I am making for it.
David
David George 110/09/2017 13:47:47
2110 forum posts
565 photos
Nearly finished! chuck works. Fastened lathe to a board and motor mounted and working. I made the 4 jaw chuck from one piece of steel for the body, as Bert suggested, and it worked out well having made a cutter from a end mill relived in the middle to cut the jaws were made from gauge plate. I have made a collet set for the spindle and only have to split the collets to make them work. I am also having a 3D printed cover for the motor made as soon as I make the CAD drawing.
David
Neil Wyatt10/09/2017 14:17:10
19226 forum posts
749 photos
86 articles
I can't help thinking that Stuart never expected anyone to finish the lathe as a working model!
MW10/09/2017 14:33:29
2052 forum posts
56 photos
Wow, that's actually a lot bigger than I thought it would be. I have seen them on stuart before, but didn't think they were big enough to actually work.
Michael W
