Wandering mill table
Steve35522/10/2021 21:55:24
321 forum posts
235 photos
Hi
Now trying to learn to set up my Dore Westbury mill (got from eBay and refurbed)
I trammed the head yesterday and got it to .001 - happy with that.
I need to make some jaws for the vise, and I have some gauge plate for that. Before I cut the gauge plate I thought I’d indicate in the vise so I can mill the end of the gauge plate square. But I find that when I put the DTI on the vise and wind the table from left to right, the table wanders by about .005 on each turn of the wheel. I have tightened up the gibs but it seemed to make no difference. I had the table apart, nothing is obviously worn and everything seems in very good condition. I cleaned and oiled it and put it back together.
it seems to happen more when the table is at either extremity.
Is there something I don’t know about tightening gibs? When I tighten the gibs on the lathe carriage, I can’t move it. But on the mill, it still runs smoothly. Something doesn’t seem quite right.
Any ideas?
Steve
Andrew Johnston22/10/2021 23:06:24
7061 forum posts
719 photos
How do you know that it's the table and not the vice that is off?
Dalboy22/10/2021 23:08:59
1009 forum posts
305 photos
Have you checked the Y axis
Steve35522/10/2021 23:23:24
321 forum posts
235 photos
Posted by Andrew Johnston on 22/10/2021 23:06:24:
before I took it to bits, I was getting about .010 movement. I could see the corner of the table wandering, also, it corresponded with a stiffness at a particular point when I turned the wheel.
I also used some gauge plate for the DTI. I wasn’t sure if the “outer jaws” of the vise were flat enough, they have some grinding marks on them,
So I’m pretty sure it’s the table and something to do with the gibs/feed screw
Steve
Edited By JasonB on 23/10/2021 07:10:58
Clive Foster22/10/2021 23:26:54
3630 forum posts
128 photos
If its a regular cyclic error as you turn the feed handle then +1 for Y axis slack as suggested by Derek.
Moving the handle creates a couple that will take up any cleasrances in the Y-axis generating the shift.
More of an issue with smaller amchines with, inevitably, lighter slides and smaller bearing areas but my Bridgeport is pretty decent yet the glass scale DRO is sensitive enough to pick up a similar tenth thou / micron level shifts. Such errors are academic of course.
Steve35522/10/2021 23:50:21
321 forum posts
235 photos
Posted by Clive Foster on 22/10/2021 23:26:54:
I’m pretty sure I locked the Y axis but I will have a closer look in the morning
Thanks for the thoughts
Steve
Michael Gilligan23/10/2021 04:50:51
23121 forum posts
1360 photos
Posted by Steve355 on 22/10/2021 23:23:24:
dont know
That looks like you have a lot of weight acting in cantilever
I would try setting the gib-screws with the table unloaded.
[ or have you already done that ? ]
Edit:
It’s perhaps worth noting the proportions of this machine :
http://modelengineeringnorge.weebly.com/dore-westbury-mill.html
http://www.lathes.co.uk/dore-westbury/
Edited By Michael Gilligan on 23/10/2021 05:05:36
JasonB23/10/2021 07:15:47
25215 forum posts
3105 photos
1 articles
What's holding that bit of bar you have the clock running against? looks like it's just stood on top of the fixed jaw.
To take out some variables try it with the clock on the edge of the central tee slot.
Can you also confirm that when you say 0.005" movement you are talking of wobble or just the steady change in reading from one point to another.
I assume you are loosening the locknuts then adjusting teh gib screws before finally locking the nuts again? If they are making no difference then something is wrong as they should lock the table if done up too tight.
It's a large vice for that machine, at least consider taking it off the swivel base if for nothing else to regain some Z height.
Edited By JasonB on 23/10/2021 07:34:46
Edited By JasonB on 23/10/2021 07:39:13
Steve35523/10/2021 08:13:08
321 forum posts
235 photos
Posted by JasonB on 23/10/2021 07:15:47:
nothing, it was just an experiment to check it wasn’t imperfections in the surface of the cast iron on the vise. Same results.
wobble, it is “wobbling around a steady change” if you see what I mean
as Michael also suggested I will take the vise off and eliminate that as a variable.
Thanks!
John P23/10/2021 09:14:51
451 forum posts
268 photos
Bit a of a long shot this its 40 years since i built my Dore wesbury mill, the two steel flat bars that are fitted to the underside of the table one of which provides the narrow guide for the gib strip to run on and sit under the two steel strips which form the bearing surface for the table to traverse on ,all of these strips of steel are attached with countersunk screws ,the guide strip should have a a couple of hollow spring dowels to secure the strip to the table .It may be worth checking if the guide strip that is fitted to the underside of the table is still secure and the screws are still tight as if the strip moves about the table would wobble as you have described.
Steve35523/10/2021 10:18:55
321 forum posts
235 photos
Posted by John P on 23/10/2021 09:14:51:
John, you may just be a genius… certainly another line of investigation….
I have it apart again, the strips are all tight and seemingly in good nick. I am wondering about those spring dowels. I can’t seem to post pics of the drawings here, but I can’t find anything about them on the drawings except the holes in which they go.
see pic below, do you think that looks right? I can’t see the point of those holes myself, so Is something missing perhaps?
Steve35523/10/2021 10:21:20
321 forum posts
235 photos
Posted by Michael Gilligan on 23/10/2021 04:50:51:
dont know
Edit:
done it now, same result, now 0.002 wobble on DTI. 😢
Journeyman23/10/2021 10:38:12
1257 forum posts
264 photos
From your photo it looks like the spring dowel or 'roll-pin' is in place.
Dave Halford23/10/2021 10:59:50
2536 forum posts
24 photos
Going back to the gibs, does that locking screw (third hole) lock the table?
Not the pic journeymans reply smiley
Edited By Dave Halford on 23/10/2021 11:06:45
John P23/10/2021 11:03:26
451 forum posts
268 photos
That looks as if it is ok as noted previously by Journeyman , have you checked also the gib strip adjustment on the Y axis slide way, try the test with the Y axis lock tightened.
Steve35523/10/2021 11:03:42
321 forum posts
235 photos
Posted by Dave Halford on 23/10/2021 10:59:50:
No, it doesn’t seem to, and I can get them all as tight as they will reasonably go and the table will still move. Getting stiff, but it moves. I’m thinking perhaps the gibs are installed incorrectly.
Tony Pratt 123/10/2021 11:06:33
2319 forum posts
13 photos
Yes, from memory over 40 years ago when I made one. The OP said tightening the gib screws made no difference, they should certainly lock the table if snugged right up. The gib in my Dore Westbury was just a flat strip of metal so hard to make or fit incorrectly but possible?
Tony
Edited By Tony Pratt 1 on 23/10/2021 11:08:10
Steve35523/10/2021 11:19:29
321 forum posts
235 photos
Looking at the drawing, perhaps the gib is supposed to be “raised”, when I’ve installed it it just slots in and settles on the bed. It feels right, but according to the drawing it isn’t. I will have a go at that next.
Tony Pratt 123/10/2021 12:44:24
2319 forum posts
13 photos
Steve355, the gib screws & the locking screw should go into dimples in the gib strip.
Tony
Steve35523/10/2021 13:59:19
321 forum posts
235 photos
Posted by Tony Pratt 1 on 23/10/2021 12:44:24:
Tony
Yes indeed, but in this case it looks like they can sit in the dimples in two ways.
If the gibs sit on the bed, the gib screws will push the upper side of the dimple, and only the top inner corner of the gib will make contact with the slideway. Looks like that’s why the gibs weren’t locking the table.
if the gibs sit about 1mm above the bed, the screw fully engages in the dimple and the entire gib contacts the slideway, providing a lot more friction. I’ve now got it like this and the gibs can lock the table properly. I can also not move the table at all in the hoizontal plane.
But there is also a vertical component. I think I was turning the handle too roughly, which seems to flex the table - only very slightly, obviously. But it doesn’t take much to create a .002” movement on the DTI. The gauge plate I was using was very slightly off square to the table, so a slight vertical movement moved the DTI needle.
I think I’m getting there.
Steve
