Member postings for mike mcdermid
Here is a list of all the postings mike mcdermid has made in our forums. Click on a thread name to jump to the thread.
Thread: Need a CNC mill and lathe
16/06/2014 09:22:17
I used to work for dassault systemes as an applications guy 35k a year on software license??, is catia and large aerospace type of licence money for one seat , and it still doesn't bring the speed what a product like volumill does
we actually use NX and volumill as opposed to catia and volumill and thats where the speed comes from, that 7.5 k for volumill paid for itself in the first 6 months of owning it and it roughs material at 5mm stepover and 25mm depth in most cases the first time you press the button you think the life of the endmill will be measured in how fast it rapids to the job ,but to watch it is something to behold , https://www.youtube.com/watch?v=zrqlxk6Lflw
, im not teaching you to suck eggs here but 30-40 quid is not bad if your getting 30-40 parts out an hour ,obviously you wont be but the economics do work and this is how we had to start up our firm plus we had to make the product here in the UK for the same as the taiwanese whilst we reshored the product and brought it back home
we had ridiculous sums quoted for some of our bike parts and even at the lowest quotes of 25 quid a component the first 150 alone cost more than the machining centre we bought and there are 8 cnc machined parts in our assemblies the economics said BUY
Owning your own machine makes it so you have a specific freedom but then the design for manufacture also goes out the window as you get in the mindset of "itll only take a minute to do this and this and this" by the time your done its a part that wouldnt look out of place on the ISS
However a lot of CNC subcon companies will take on work based on what they can make in that hour and if a client will pay 65 quid an hour (which is the going rate around here) or a guy comes in and says ive been quoted 40 quid an hour they arent going to even bother quoting, let alone when you add in its not a long term thing or theres a few to be made etc etc ......their eyes just glaze over
16/06/2014 00:44:11
We machine 2.6kg of titanium to a part weighing less than 60g in less than 2 minutes that's about 20 components an hour done 1 at a time (not nested or fixtures) including faffage ,we use a cutter that costs 40 quid and our cam cost 7.5k
We had similar problems when we started making bikes but it's illusion all to think your going to machine titanium on purchased hobby CNc equipment and get any kind of monetary return or metal removal rateyou need a good two tons of rigidity to make a profit so I would budget 40k for a mill ,cad cam ,tooling and good carbide (not crap)as a minimum
alternately find a company like us that takes on precision jobs no one else does and is happy to take on unusual jobs most CBC shops want to make 1000 widgets at 5 quid than scrap a one off at 5k and we compete quite happily with the Taiwanese now we have production process
if you were making real parts you will quickly find the 5 or 6 an hour you make on your toy CNc would translate to many more if done by a company set to do work for you
Thread: Brazing
15/06/2014 00:16:28
You will need a special rod we use sifalbronze 32 normal sif 1 or 101 isn't interested and likes to behave in a similar capacity to a spitting cobra only with added fumes and flame
again with the silver even using tig but you must use a flux we buy it from thessco ,primarily I tig aluminium titanium and steel bicycles but ironically my actual oxy acetylene leaves far more to be desired than my tig welding skills, I find it easier to tig 0.5wall tubing than brazing it
i will try to post some pictures
Thread: Beaver mill
17/04/2014 23:20:43
We just ordered another cnc machine the rep pointed out they can deliver 20 machines a month and currently are at a backlog of 42 machines a month , at the mach show alone they sold 4.4 million quids worth in 3 days, machines some of which cost 400k each in terms of one manufacturer alone not bad and thats not a company like Haas which sells commodity cnc
Manufacturing has just changed its not dead
Thread: 3D printing seems to have gone quiet. Where are we all at?
09/03/2014 10:19:46
Posted by Ady1 on 09/03/2014 10:09:32:
The future possibilities are quite mind boggling once they sort the material strength/properties out
Print out a loco boiler in 24 hours and an entire Tich loco in a month !
The time saved with production will be put to better use, like new ideas methods and developments for models like steam powered units
Except you also then have to still machine in bores holes threads flats, just because its preinted you need to remember at this stage all you are effectively doing is printing a cast part in both terms of strength and finish the only real benefit at this point in time is the reduction in logistics time and tooling
of course also the new design engineer straight out of university will actually be able to design round the corner holes and not be dejected when you tell him to eff off back into the drawing office for being stupid
Thread: Bigger Lathe
02/02/2014 13:06:54
you could look on it for f 2-3k yoiu can kill a chinese machine in industry then buy another one next year
as it will have made its money ,for those odd jobs we dont cnc it costs 120 quid for half a day for our local turner i think is ok tbh but its nicer just to have the capacity to turn some bits as one offs without interrupting money makeing jobs on CNC machines
for a hobby am i really ever going to need an M300 or a chester crusader sized machine? i dont know but some then turn into the odd job man round the corner and do indeed need more machine
it almost becomes a classic car mentality restoring machines and slapping some pain ton..<----yes i did mean to writ it like that
Thread: Free CAD model library
02/02/2014 13:00:53
grabcad is also becoming a bit of a force in the 3d cad parts world
Thread: Diamond toolholder
01/02/2014 21:48:28
I recall having a conversation on here where i absolutely slated mine , I hated it , i switched to carbide inserts eventually and never looked back until
one day it got the better of me so i played with 2 different types of bit (this was when the lathe was cutting a 7 though taper towards the chuck)
one i ground and honed a .4 mm rad on one end the other 0.2
then also an old carbide endmill which had had its day was ground on the supplied jig
it turned magnificently the key was the little rad (correct feed per rev) and not the sharp point which would break down very quickly this also confirmed another thing ,the lathe was still turning straight but carbide tips break down quicker than you think, with coolant on SS it will give me a finish the same as the new HURCO cnc we have in the workshop
01/02/2014 21:33:32
We have a boxford st280
in fact we are selling our old one and its going in the classifieds cheap but that's not why i posted
We looked at a chinese crusader or something along those lines and thought do you know it will get us by however ,went and looked at the chesters and they just seemed naff once you got past the fact your looking at a new machine and its shiny!!!
niggly little fit and finish things kind of creep into your mind so we did actually buy a used 280 which looked tatty but turned fine
We actually thought there was something wrong with it recentley (tho old one ) however it seems as carbide tips wear they take more force to cut and hence changing the tip it was back to turning to 1/2 a thou over 8 inches but by then the decision had been made to get new
they are bombproof little machines and you can get every spare from boxford
A little known fact when i was at 600 in hecky the guy who designed the M300 went to boxfords where the X10 lathes( thats the newer boxfords) were born
which is why whilst it cost more to do we bought a new one from them ,purely based on the fact that the old one has never missed a beat the only niggle i have is as the crosslide nut wears it rocks in its mounting which is easily fixed
you show me a Harrison m300 that is less than a grand and isn't flogged to death unless you are one of the lucky school finders
the old machine we had thoughts of getting it reground and painted back to new spec boxford quoted 3k just to paint the thing and check it Brian caddy 700 quid to put the thing back to factory,we were going to do this but dont have the time ,but it would still be a far better machine than any import
Thread: lathe turning taper toward headstock
31/12/2013 22:54:38
It's a bison 125 mm
The spindle is spotless as is the seat
Concentricity on a ground 1 inch bar is about 2 thou over a foot
Can't figure it as the headstock sits on a vee and the bolts are still tight
Edited By mike mcdermid on 31/12/2013 22:55:28
31/12/2013 19:40:02
hi chaps its a boxford 280 industrial
brand new d1-3 chuck to be honest i had not noticed problems as i was using a 4 jaw and clocking everything
that got tiresome
spindle taper clocks at 0 if i put my finest clock on it and i probably am not as good as the clock
using a cheaper clock
i get runout on diameter of the chuck is less than 1/2 a thou
worst on face less than 1/2 a thou and if i put a
piece of bar in the chuck is 2 thou concentricity anything tighter i switch to the 4 jaw
if i shift the tailstock i can get ban on diameter over the length of 3"
even if i pu the old chuck on i get similar taper towards headstock
31/12/2013 18:39:51
Lathe has developed a habit of turning tapers
smaller at headstock end ,it did always cut 1 thou or so over 6 inch but was never bothered ,this seems to have grown to about 5 thou now over 3inches
doesnt matter wether using tailstock or not taper is the same which rules out the tailstock, in fact i can get a good result by setting over the tailstock to eliminate the taper
however its not the best option
any ideas
no crashes or bangs and wallops of late
Thread: need some of these making out of steels
09/12/2013 23:52:02
Stack them up and wire erode the square hole
Thread: Do suppliers ACTUALLY read their own web sites
09/12/2013 21:53:49
Cutwell?
Edited By JasonB on 10/12/2013 19:40:25
Thread: I'm sure one of you chaps will know???
30/11/2013 00:55:28
Find some of the little knurled speaker thumbscrews they use for holding wire on the speakers im sure richer sounds sell thm and they are m5 i once bought some that were missing off some speaker cabs
Thread: THIEL DUPLEX universal machines or bridgeport series 1
22/11/2013 19:55:24
Jason did you purchase the machine? Im in a similar quandry
Theres one on ebay at the moment but it seems there is a requirement to make the spindle adapters which im informed make it unusable for the time needed to make or buy them
Thread: 3D printers coming of age...?
18/11/2013 18:56:56
simple answer No not for anything you cold subjectively call useful 3D printing is not a close tolerance thing it does not produce a finished item when you get to precision engineering,in fact the gentleman who sells EOS DLMS machines in the UK will tell you this himself he stood in a room full of aerospace execs and pointed out at this level it wasnt ready yet
the Gun still had to have all the post machining operations you would traditionally apply to get the precision needed in a firearm the difference is that the metals etc were not forged or cast so no tooling etc was needed
there are also materials being produced now that would not lend themselves to being printed but outperform both metals and ceramics in many ways in this area and they are kind of pushing 3d printing aside based on their unique properties alone
there are however machines that laser powder mettalurgy and machine to tolerance size inside one convenient cabinet so it is advancing all the time rather than coming of age
Thread: Could Concorde ever fly again? No, says British Airways
26/10/2013 12:00:37
Posted by Bill Pudney on 26/10/2013 02:38:54:
In terms of structure and systems there is a quantum leap (literally) between the Vulcan and the Concorde. Both fantastic aircraft and a tribute to the people who designed, built, maintained and flew them, but very sadly both obsolete.
cheers
Bill
Respectfully Bill i will have to disagree re the quantum leap
Thread: Learning CAD
26/10/2013 11:21:31
rebekah
3d cad- learn a direct modeller like fusion 360 from autodesk you have an advantage and its paid for subscription £25 quid a month only as you use it or month by month on subs rather than 5-6k up front or an illegal download
Another otion sign up for a course at college get a  student card an purchase a student edition of one of the big vendors for much much less (hundreds) as opposed to thousands
i have used solidworks from 95 onward ,Unigraphics Catia Inventor pro e you will find they are dying the technology (though the sales pitch is magnificent when you hear the sales guys full parametrics( a load of crap i doubt you will use it for your uses) are of little use
nearly 20 years on im now classed in the cad world too set in my ways to change ,you can learn something and not be constrained by all these packages did it this way mentality which all of us now have because all 3d cad works the same and does the same just with different icons for the buttons
Secondly find one with free support or a large user base , it seems everyone has a seat of Catia with all the bells and whistles these days though i doubt its paid for in any way, and really as i demo for solidworks occasionally everytime i see a guy saying how do you do this on a seat of solidworks its obvious who is licensed and who isn't, i should be reporting it
Edited By mike mcdermid on 26/10/2013 11:22:45
Edited By mike mcdermid on 26/10/2013 11:25:04
Edited By mike mcdermid on 26/10/2013 11:26:35
25/10/2013 19:08:21
All the above has been said before re maintenance, skills etc they said that about another classic aircraft
theres a vulcan bomber flying around at the moment
Edited By mike mcdermid on 25/10/2013 19:10:30
