Member postings for Ady1
Here is a list of all the postings Ady1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Vibrating parts polisher
17/02/2023 01:01:14
Looks a lot more civilised than sandblasting
Anyone got one?
Thread: Ward Lathe Clutch Help
16/02/2023 14:09:41
If you're doing a lot of awkward heavy lifts maybe a magnetic system would make life easier
There are various items on ebay
16/02/2023 10:31:49
That's a REAL lathe.
Can't be many still running now
If you give the model/type that may help, they made quite a few variants
Edited By Ady1 on 16/02/2023 10:34:37
Thread: Hello from Wales
15/02/2023 15:54:26
Ken swan did a kerr stuart 0-4-0 wren at some point, it may be similar with a different cab/saddle
Then there's the kerr stuart "victory", the bulldog may be a cut down version of that
arrangement
Edited By Ady1 on 15/02/2023 16:06:28
Thread: What next - plans
15/02/2023 15:22:02
I just saw your workshop and you're not hanging about are you...
Don't forget about CAD as an aid in your quest, it's very handy for when you're not doing "real work", can't get into the workshop, too knackered etc
GL
Thread: How do i machine this ( on the wonk)
15/02/2023 15:09:07
I didn't want to say "weld it" because that's talking dirty
15/02/2023 14:07:45
You need a lathe with a curved bed
Thread: Manning Wardle 0-4-0ST
15/02/2023 11:35:00
Happens a lot with me.
Anyone who uses older web building programs to build a site is a
"security risk ahead !" site
So the little one-man-band places get excluded
The big corporates don't want us to see the little peoples shops
(If you visit sex sites then... well it was always at your own risk anyway)
edit: I can get straight in no problem with my older Firefox software, looks like a pretty nice site
Edited By Ady1 on 15/02/2023 11:40:35
Thread: Myford Lever Action Tailstock Design and Build
15/02/2023 10:24:40
Nice one Hopper, well done you
You're now a social media star and can appear on I'm a celebrity and strictly come dancing
Thread: AVM MAS 140 lathe
15/02/2023 00:38:28
Well done you
And I would buy it with the DRO, they can save a lot of time/effort
(That's why they are so popular with so many users)
Edited By Ady1 on 15/02/2023 00:39:58
Thread: Finish when Milling with SX3
13/02/2023 23:25:04
Perhaps a very high speed finishing cut would sort it
(or a finishing cut on a bridgeport !)
I get the same effect on my home made mill but it's not very stiff/heavy
Edited By Ady1 on 13/02/2023 23:28:36
Thread: Should I use anti-vibration mounts under Boxford AUD cabinet?
13/02/2023 23:09:47
I've got a concrete garage and use a bit of scrap rubber mat under all my "bigger stuff" feet and it makes a huge difference, I do it before I even plug in a new unit now
The shaper in particular made the house rumble, probably more resonance noise than HP, but you noticed
Thread: Has anyone here ever modified a capstan attachment to fit a regular centre lathe?
13/02/2023 10:11:54
Drummond did a big one Page 22
Thread: How close have you got to a Darwin Award?
12/02/2023 03:11:17
My brothers pal jumping off one of those huge railway cutting walls for half a crunchie
Then lying there on the deck with a broken leg demanding his reward
12/02/2023 02:20:53
The best bang I ever heard was one of those railway detonators going off in the kids toilet at school
He'd been chucking it against walls and hitting it with half bricks until it was a mangled lump of metal but finally succeeded at setting it off around lunch
edit: Those big red empty calor gas canisters on a bonfire were always pretty entertaining
Edited By Ady1 on 12/02/2023 02:23:14
Thread: DIY milling machine
12/02/2023 00:06:55
I should add one caveat, you MUST use a collet to hold a milling cutter, a drill chuck simply won't hack it, the side forces mean your cutter will eventually wander into or out of the chuck jaws and mess the job up
11/02/2023 23:26:12
Posted by Sonic Escape on 07/02/2023 19:50:16:
unfortunately I underestimated the rigidity required to mill metal
If you can make a good strong accurate drill then you can do 80% of a lot of milling jobs, it's a lot cheaper on the tooling too, and faster, the drill swarf can really pile up compared to a light milling cutter because you can do up to 12mm and work it hard
Then swap tooling and finish with light accurate cuts with the 5-6mm milling tool
I suppose that's a good way to test an unknown drilling machine, stick a sharp 12mm drill into the chuck and see how it does with drilling through a 20mm mild steel block. If it's a doddle then you only need to add an X-Y table to give yourself a light milling machine
One on the bay at the moment that would get me excited if I was in the market
Edited By Ady1 on 11/02/2023 23:49:00
11/02/2023 10:28:31
...and once you start taking successful light cuts you realise that some jobs will take forever and you wish you could take heavier cuts so you can get on and do more stuff...
If you are going to do metalwork and you can afford and accommodate a chunky mill then it's actually a no-brainer to go for as-chunky-as-possible from the very start
Lathes are a lot easier because even a decent smaller lathe can do quite heavy work, but a decent smaller mill cannot do quite heavy work
Thread: Finally got a proper lathe
10/02/2023 23:49:51
Well done you
Welcome to the nuthouse, and have fun with your new pal
10/02/2023 23:17:40
I simply repurposed already capable kit, a Drummond M lathe with a good headstock and a 40 kg milling table so the hard work of decent accuracy and stability was already there, I simply bolted them together
and it still shakes if you take too big a bite, using only 6mm cutters mainly
Only a multi skilled machinist with good resources could make a decent mill from scratch in my opinion, because it needs to be very accurate when it does work, sub 0.5mm across the entire working plane, sub 0.1mm preferred, up/down left/right otherwise it's been a waste of effort
The table is moving horizontally over a dovetail?
The table is bolted "immovably" to the cross slide but can move up and down the lathe bed with the leadscrew
It's actually fabulous for big woodwork jobs because all the mess drops down out of the work zone
Edited By Ady1 on 10/02/2023 23:35:52
