Has anyone here ever modified a capstan attachment to fit a regular centre lathe?
is this just a bad idea...
Jake Middleton-Metcalfe13/02/2023 09:24:03
14 forum posts
15 photos
Hello I was wondering if anyone could offer some advice for my problem:
I am in need of a capstan lathe but workshop space is tight and buying another lathe could be a problem. I have a warco centre lathe for which capstan attachments were never made - has anyone on here ever got a capstan attachment made for another lathe and made it fit their centre lathe either by making some sort of milled plate to make it taller or indeed machining down the base of the capstan and then perhaps boring the tool holes on the capstan to a larger size (to make certain they are central to your lathe spindle).
If anyone on here ever tried this ... is it something you would recommend or not? Is this just a horrible idea? Or is it a great idea which will help me save space by not having two lathes?
Best wishes and thank you for reading
Jake
Howard Lewis13/02/2023 09:35:22
7227 forum posts
21 photos
There used to be a Myford Tailstock Capstan attachment, so others have had this requirement previously.
There have been designs published, by model engineering afficianados, and marketed commercially (By Warco among othgers ) for Tailstock Capstan attacments.
They usually carried four or six tools (, Centre, Drill chucks Die Holders etc. )
Try looking at Warco, Chester, Axminster, or RDG; you might find what you want.
Robert Butler13/02/2023 09:55:53
511 forum posts
6 photos
The Arc attachment 2MT & 3MT? works well. Tooling needs to be designed incorporating its own stop.
Robert Butler
Ady113/02/2023 10:11:54
6137 forum posts
893 photos
Drummond did a big one Page 22
Michael Gilligan13/02/2023 10:13:29
23121 forum posts
1360 photos
There was even a [rather lovely] little capstan attachment for the Pultra 17/70
There will presumably be pictures of it on lathes.co.uk
John Haine13/02/2023 10:15:27
5563 forum posts
322 photos
Does Hemingway make aa kit?
JasonB13/02/2023 10:17:33
Downriver Tools used to do a few designs to make your own for various size lathes but their website seems to be down at the moment.
This minilathe one looks quite well done, build thread
noel shelley13/02/2023 10:56:50
2308 forum posts
33 photos
Myford made a proper capstan that was bed mounted, had it's own slide way, indexing and stops ! A beautiful if very expensive bit of kit. To fit it - for perfection the capstan was drilled to suit the centre height of the machine it was used on. The myford fitted with the lever or screw operated cross slide and its associated tool holders plus the capstan attachment with box cutters Etc became a proper capstan lathe. I supose that provided the centreheight was 3,5"  or greater one of these could be easily made to fit a larger machine.   Noel.
Edited By noel shelley on 13/02/2023 11:00:36
Edited By noel shelley on 13/02/2023 11:32:51
peak413/02/2023 11:10:26
2207 forum posts
210 photos
It's not a full capstan attachment, but Chester have THESE on offer at the moment, with a 30% discount coupon available.
https://www.chesterhobbystore.com/shop/tooling-accessories/tool-holding/multi-head-indexing-tailstock/
The MT2 version isn't particularly rigid, and unfortunately, they can't supply spare tailstock ends.
I bought that one, so I could use it in the Myford as well as the larger Warco gearhead.
Note that the various holders are primarily designed for metric sized dies etc, but obviously can be adapted or duplicated.
Bill
Andrew Johnston13/02/2023 11:31:09
7061 forum posts
719 photos
Depends what you want to do with it. I have a capstan unit for my lathe (Harrison M300) which has its uses, but it is not as useful as a proper capstan lathe. Also note that a capstan unit, or lathe, is useless without tooling. For quantity production I have a repetition lathe; far quicker and more versatile for small items than the capstan unit plus centre lathe.
Hopper13/02/2023 11:57:05
7881 forum posts
397 photos
What is it that you want to make on your capstan lathe, and in what quantity?
There may be other, better or easier, ways of doing it if more details can be given.
As others have said, capstan attachments can be somewhat limited in their abilities and are not the same thing as a full-on turret lathe. So again, it depends on what you want to make and how many.
Edited By Hopper on 13/02/2023 11:58:13
noel shelley13/02/2023 11:57:14
2308 forum posts
33 photos
Andrew is right about needing not only the capstan unit, BUT all the tooling and the lever operated collet chuck. A 1985 Myford publication shows an S7 set up with all the bits that make it a capstan lathe. All the bits cost more than the bare lathe. What is it that you want to make lots of ? Noel
JasonB13/02/2023 12:03:24
From previous posts I would think keys(finger buttons) for concertinas
If it is then this is one of the Downriver designs on a small Sherline lathe that could be adapted to the Warco 180
Edited By JasonB on 13/02/2023 12:18:45
duncan webster13/02/2023 12:34:53
5307 forum posts
83 photos
I think Radford had a design for a dovetail quick change arrangement for the tailstock so you could quickly swap drill chucks etc. In ME in the mists of time
Baz13/02/2023 12:47:35
1033 forum posts
All you need is a lump of cast iron or steel to make an adapter plate and you’re in business, I have seen a Myford capstan unit grafted on to a Colchester Chipmaster with great success.
Hopper13/02/2023 12:59:21
7881 forum posts
397 photos
Well, if it is just for that kind of small stuff on a mini lathe, a tailstock turret combined with a lever tailstock mechanism might be the easiest and cheapest option. You don't get the auto rotation/indexing like the proper turret in the video but for short run production jobs it would work OK.
There have been a number of designs for tailstock turrets over the years. From memory LH Sparey has one in his book The Amateurs Lathe" with drawings.  And ISTR there have been more recent designs in MEW. Plus of course these days you can buy them ready made.
Edited By Hopper on 13/02/2023 13:15:49
Hopper13/02/2023 13:01:45
7881 forum posts
397 photos
Posted by duncan webster on 13/02/2023 12:34:53:
It is in his book "Improvements and Accessories for your Lathe" which is still available.
DC31k13/02/2023 13:18:56
1186 forum posts
11 photos
Another option to consider, as an alternative to a traditional capstan, and if your parts suit its layout, is a gang-tool setup. A popular commercial one is Omniturn. They used to have lots of very useful ideas on their website.
Clive Foster13/02/2023 13:31:15
3630 forum posts
128 photos
Big disadvantage of a tailstock turret compared to a true capstan attachment is the lack of depth stops. Which make sit very difficult to do repetition jobs requiring identical sizes. Generally the tailstock breed is best for things like drilling several sizes of holes.
I have a good industrial quality one for my S&B 1024 which comes out for such things. Centre, centre drill, two drill sizes might be loaded. Worst point is teh porcupine effect with bits pointing in inconvenient directions. Avoiding interference between job, work and machine can be an issue.
The common import breed seem even more problematical. I've still got one that I bought 40 years ago and have never used!
What makes true capstan really useful is the ratchet tool rotation and lever feed. It may be that fixing a turret to the cross slide and using a multi-position bed stop will work adequately well.
Look at the Hardinge low profile capstan attachment used on the HC et al for inspiration.
Providing you remember to increment both for each stroke. Usually hard to miss a tool shift but easy to miss clicking to the next stop position. Which makes a right mess! With stepper motors being os cheap I wonder about automating the stops using a microswitch clamped to the bed actuated when the saddle is cranked back. Cut off is the difficult bit but a simple fixed slide probably isn't impossible to arrange.
noel shelley13/02/2023 14:10:15
2308 forum posts
33 photos
The myford has capstan station and stops linked ! Noel
