Here is a list of all the postings _Paul_ has made in our forums. Click on a thread name to jump to the thread.
Thread: Thinking of buying a Bridgeport questions... |
14/08/2014 01:38:38 |
What type of Bridgeport? a J head? they are the most popular. Height around 7 foot, varies with motor type "pancake" motor being the shortest Weight around a ton, varies with table size and or other bolt ons Power between 1-1/2 to 2hp for a Varispeed. "4KW rotary phase inverter" do you perhaps mean "Convertor"? if so that should be fine, you can use an Inverter but then as the BP has more than one three phase motor.... Try to get a step belt head machine they are less problematical than the Varispeed version and cheaper to repair, generally watch out for spindle noise and bearing play a set of Abec 7 bearings could cost you > £300 Then it's the usual things: wear on the ways leadscrew wear fine feed mechanism faults etc, the list goes on. Skip across to the Bridgeport Forum on Practical Machinist lots of good info on what to look for when buying cheap BP's Paul
Thread: How to centre a boring bar |
13/08/2014 01:31:27 |
Clive I do like your optical centre height indicator I can think of a situations when that will be handy, I do have a question though when cutting the mirror to size is that classed as breaking said mirror and subject to the superstitious 7 years bad luck? Paul |
Thread: Fast corrosion of aluminium while milling. |
09/08/2014 19:23:09 |
I wonder if caustic soda is an element of the bleaching/whitening agents in your paper? Paul |
Thread: QCTP for 5" Boxford CUD |
08/08/2014 01:18:39 |
I use up to 16mm tooling in the holders I have for my 4-1/2" Model "A". Some of my holders are genuine Aloris/PhaseII and natively allow 16mm tooling, all my homemade one's are 16mm the far eastern imports have around a 13mm slot in them. (image courtesy of Shars Tool) Have a look at the Aloris Catalogue for some more sizes It's easy to vary the height of the holder by it's adjustable knurled ring and locknut for the amount of travel allowed by the toolpost block height it doesnt just sit at the bottom. Paul |
Thread: 3 phase motor running from single phase supply |
06/08/2014 22:17:39 |
Posted by ronan walsh on 06/08/2014 22:07:37:
Someone told me to try this idea of using capacitors across the lives to get a small coolant pump motor running on a colchester lathe. I didn't do it but apparently it works ok for small motors. Some will and some wont I have two 1/3 hp coolant pumps which are wired Delta but wont start or run on any capacitor setup yet will run quite happily on an Inverter... |
06/08/2014 22:13:44 |
I found the table in Jim's book to be a bit "off" and had to do as Neil says some experimentation with values to get the running voltage close to equal on all three legs. In another book in the Workshop Practice series the author Graham Asterbury uses a better formula for calculating the required capacitance, I found it gave more accurate results than the tables in Jim Cox's books. Paul Warning always discharge the caps before working on your circuit. |
06/08/2014 12:31:43 |
The only machining required to fit an AXA size QCTP is to machine a step into the supplied separate bolt base to suit your topslide slot. This particular pic is of a "Craftsman" lathe but shows the operation required. Paul
06/08/2014 10:52:09 |
I have two Aloris/PhaseII type AXA size on a 4-1/2" Model "A" Boxford one back and one front and make a lot of my own holders which are not too hard to manufacture unlike the Dickson type which are a little too intricate. Here is a UK supplier Arceurotrade Paul |
Thread: Springs |
28/07/2014 00:21:15 |
If its a 6F power feed these people are good to deal with Sorted spring prices dont seem too salty.
Paul |
Thread: Soba Vice Problem |
26/07/2014 11:18:34 |
Posted by John Stevenson on 26/07/2014 11:11:30:
Where's the Super Adapt thread when you need it ? lol
Thread: What did you do today? (2014) |
13/07/2014 12:00:58 |
You can never have enough of these, so made a couple more Paul |
Thread: Which ER32 Collett For a Myford ML7? |
12/07/2014 08:01:32 |
This diagram (courtesy of Sir John Stevenson) is for a Myford ER32 Chuck it gives you an idea of whats involved to make one.
By turning the chuck on the machine that you will be using it on should ensure that you will get the best concentricity your machine is capable of. They are not difficult to make but try to select some decent steel to make it from and probably the trickiest part is getting the taper right. Collet nuts as previously mentioned the ball bearing types have a greater clamping force and are quite reasonably priced at Arceurotrade that said it takes quite a bit of force for a standard nut to let the work slip. You will find a lot of info and help on the Homeshopmachinist forums heres a starter ER40 Chuck Regards Paul |
Thread: 3 ph motor conversion to VFD, any issues? |
11/07/2014 23:36:02 |
I have personally converted a quite a few 400/415v motors from Star to Delta by picking out the "Star points", and all work very well on 240 single to 240v 3 phase Teco inverters. If you feel qualified to do this yourself there are some good books on the subject in the Workshop Practice rage by Jim Cox, there is also in the same range a book by Graham Asterbury which again explains the process quite well. Please be aware though that these voltages can kill you, if unsure please consult a qualified electrician. Paul |
Thread: Enlarging a hole in knurling wheels |
06/07/2014 11:44:00 |
I had a similar issue in the end I turned the pins to suit the size of the Knurling wheel and just ran with the pins being a couple of thou slack in the arms seems to work OK. Paul |
Thread: Screw Thread Measurement Utility |
19/06/2014 01:13:25 |
Vista gives this error: Runtime error 339 Component 'tabctl32.ocx' not correctly registered: file missing or invalid. Paul |
Thread: Removal of staining and disclouration on lathe slideways |
01/06/2014 03:36:02 |
Try a drop of cellulose thinners. Paul |
Thread: descaling steel |
30/05/2014 23:30:05 |
Apologies for raising one of John's old threads from the dead but Toolstation have Cementone Brick & Patio Cleaner 5L on offer for £6.73 spend over a tenner and the delivery is free. Paul |
Thread: Bridgeport spindle problem |
26/05/2014 22:31:10 |
If the spacer is loose it looks like your bearings are dud, it's the bearings pressing on the outer spacer that gives them light preload. Both spacers should be the same length preload is provided by the bearing. Depending on how long yours has run loose these spacers may have now suffered some wear, thankfully they aren't that expensive to replace try "Sorted.co.uk" for prices. Bearings prices are a different matter £200 to £300 for something the correct Abec 7 spec 2MM207WIDUL is the Fafnir designation. You do occasionally see new old stock on Fleabay. Paul
26/05/2014 00:30:21 |
Nearly forgot to mention make sure you have the quill lock on as once you take off the stop knob and screw there is nothing to stop the quill coming right out other than the handle clock spring and if that is jiggered....out drops the quill in the process this will damage the quill skirt. Paul |
26/05/2014 00:21:43 |
You will be OK nothing else will drop off, the quill skirt is held on the quill by a couple of screws which you access from the top after taking the head off. As you only taking out the spindle this will not be affected. When disassembling the quill stop screw assembly what you may find and it’s quite common is the reverse trip ball lever is broken, all it takes is for the quill stop screw circlip to pop and the screw drops snapping the ball lever off, getting the remains out can sometimes be a pig. Regards Paul
