Enlarging a hole in knurling wheels
John Hinkley06/07/2014 09:55:38
1545 forum posts
484 photos
I am making a caliper-type knurling tool for use in my lathe, using 3/4 inch diameter knurls from a source in Australia. The hole is 1/4 inch diameter and the intention is to use silver steel rod as the pivot. My problem is, now that the parts are all made, the silver steel rod passes through the caliper but steadfastly refuses to enter the knurl. Of course, the knurls are hardened and although my only 1/4 inch drill goes through, a hand reamer not surprisingly won't touch it. I don't have the facility to heat the knurl so I was wondering if I could buy some 3 mm grinding tools for my Dremel to open the hole up a gnat's. (Precision is not my middle name.) Unless someone can come up with a spiffing wheeze to get me out of the (undersize) hole in which I find myself.
Oompa Lumpa06/07/2014 10:06:01
888 forum posts
36 photos
This is going to get some fun answers I am sure.
You need a pack of those crappy grinding stones-on-a-stick for your dremel and a diamond dresser. Get the stone down to the size you want and have at it. It is not precision but it will get you out of jail.
The other (better) alternative is to use the correct diameter rod and make some bushings for the holes in the arms.
The best solution is to get the right diameter rod and make new arms and just suck it up.
The hole isn't really undersize, your holes in the arms are oversize!
graham.
Les Jones 106/07/2014 10:08:15
2292 forum posts
159 photos
Hi John,
I would just use emery cloth wrapped round some 1/8" or 3/16" rod. Put the knurl wheel in the lathe chuck (With some tape or thin aluminium sheet around it to protect it.) Run the lathe as fast as you can and run the rod with the emery cloth in and out until it is up to the size you want. An alternative would be to lap it out wit grinding past on an aluminium lap.
Les.
Fatgadgi06/07/2014 10:30:00
188 forum posts
26 photos
Hi John - I have sympathy, but those knurls are super hard.
Surely the best way is to grit teeth and modify the caliper, after all you will get pretty annoyed in the future having to open out every different knurl that you want to use.
Cheers - Will
_Paul_06/07/2014 11:44:00
543 forum posts
31 photos
I had a similar issue in the end I turned the pins to suit the size of the Knurling wheel and just ran with the pins being a couple of thou slack in the arms seems to work OK.
Paul
Tony Pratt 106/07/2014 12:01:05
2319 forum posts
13 photos
Hi John,
Make a copper lap [search Google] and open up the knurl wheel hole until your SS pin goes through. The pin, caliper & wheel are all 1/4" but with different tolerances.
Tony
Neil Wyatt06/07/2014 12:19:45
19226 forum posts
749 photos
86 articles
I used bronze pins, turned to size, for mine
Tony Pratt 106/07/2014 12:55:59
2319 forum posts
13 photos
Posted by Tony Pratt 1 on 06/07/2014 12:01:05:
Hi John,
Tony
As a follow up you don't want your SS pin turning in the caliper so fix the pin with a small grub screw, a flat on the pin would also be beneficial for the screw to tighten onto.
Tony
Hopper06/07/2014 13:00:47
7881 forum posts
397 photos
Make a bracket to mount your dremel tool on the lathe toolpost. Clamp knurl in lathe chuck and rotate slowly in back gear. Feed dremel in and out very slowly, taking tiny depths of cuts until the hole fits your pin.
I made such a bracket out of 12mm aluminium alloy, screw cut a thread in the one end for the nose of the dremel to screw into, at the rear end, just bored a hole in the ally plate to fit the body of the dremel, hacksawed it in half and used a couple of socket head cap screws to clamp it down onto the dremel. Works beautifully. Got my 75 year old three-jaw chuck back to half-thou accuracy again by grinding out the bellmouthed jaws.
Tony Pratt 106/07/2014 13:35:11
2319 forum posts
13 photos
Posted by Hopper on 06/07/2014 13:00:47:
You will find that the bore on the knurl wheel will not run true enough to make this a viable solution, have you a 4 jaw chuck?
Tony
Clive Hartland06/07/2014 14:35:41
2929 forum posts
41 photos
Some clever answers here, but, the Knurl wheels are hardened and as such deserve to be kept to size. The answer is to drill out the side plate holes and fit bushes, Bronze is best and work on from there. The knurls should be lubricated in use and the lube will get to the bushings .
John Hinkley06/07/2014 16:23:36
1545 forum posts
484 photos
Thanks to everyone for your useful and thought-provoking ideas. I will take them all into consideration and try them one at a time. Unfortunately, the design on which I have based my efforts (by Graham Meek, in EiM), means that the cheeks of the calipers either side of the knurls are only 2.5mm wide, so that rather precludes the use of bushing, but I may have to persue a similar route, if other solutions don't work. I could make some larger calipers but that would mean ordering some more material, involving a wait until September when I next expect to be in the UK, or horrendous postal charges!
The silver steel is spot-on 1/4 inch so the "fault", if such it is, lies in the manufacture of the knurls themselves.
I WILL get around this, somehow; just needed a bit of help. i'll post pictures in my album when it's sorted.
Gone Away06/07/2014 16:53:37
829 forum posts
Since it hasn't been suggested and it might be food for thought .... what about making the pin in two halves so that you can accommodate both the smaller knurl ID and the caliper larger holes and still assemble it? Probably key the two halves together with a counterbore on one and a shoulder on the other with a though screw to join the two halves of the pin (counterbored if you don't want any projection).
Thinking out loud ..
Edited By OMG on 06/07/2014 16:54:30
Neil Wyatt06/07/2014 17:28:14
19226 forum posts
749 photos
86 articles
i wouldn't consider A 0.250" shaft in a 0.250" hole a running fit.
Why not make a stepped bolt with a 1/14" shoulder and turn a small 1/4" diameter register on the nut?
frank brown06/07/2014 18:05:52
436 forum posts
5 photos
What seems to be missing is the magnitude of the problem, are the bores under size by 2 tenths or 5 thou?. If 2 tenths then emery or dremel should work. 5 thou needs some proper engineering. I would hold your shaft material in you lath chuck and reduce its diameter for wheel +side cheek length until wheel fits on it, part off with the extra full diam. cheek length on it. Get hold of caliper, put a ball on one of the side holes, smack it with a hammer, this will have drawn some material in and downwards making the hole smaller. Turn caliper over on to this side put in wheel and insert pin thin end first, finish with a hammer.
Frank
Michael Gilligan06/07/2014 18:43:29
23121 forum posts
1360 photos
Posted by John Hinkley on 06/07/2014 16:23:36:
The silver steel is spot-on 1/4 inch ...
John,
I'm not sure how much this helps, but:
There is an occasional defect with Silver Steel ... it sometimes turns out trochoidal in shape [three-lobed, like the rotor of a Wankel engine]: The "diameter" will measure correctly, but the "radius" varies [or the centre of the diameter moves, if you prefer]. This is a defect of centreless grinding, 'though I would struggle to explain how/why it occurs.
Ooops ... probably better to reference the Reuleaux Triangle, not the Trochoid [although they are related]
Edited By Michael Gilligan on 06/07/2014 19:02:52
John Hinkley06/07/2014 20:57:20
1545 forum posts
484 photos
You've all been very helpful. Thanks. Time now for a little quiet contemplation, methinks. I've formulated a solution in my own mind, now I've got to think it through before execution. " Measure twice, cut once" comes to mind!
Edited By John Hinkley on 06/07/2014 20:58:13
blowlamp06/07/2014 23:45:49
1885 forum posts
111 photos
If they are that close to size, then ten minutes work with a rat-tail diamond file of appropriate size should do the job. laugh
Martin.
blowlamp06/07/2014 23:49:22
1885 forum posts
111 photos
Posted by Michael Gilligan on 06/07/2014 18:43:29:
John,
This effect can be seen if you measure a 20p or 50p coin.
Martin.
John Hinkley08/07/2014 09:09:05
1545 forum posts
484 photos
Done it! The hole turned out to be only half a gnat's undersize. After a slight delay to proceedings to mend the ride-on mower, I found a local DIY shop that sold Dremel accessories and bought some 5.2mm diameter grinding wheels. I put each knurl in the lathe chuck in turn andwith the Dremel going at half speed, lightly ground the bore with the lathe on its slowest speed (170rpm - no back gear). Result - pins slip in nicely with no apparent slop and a beautifully smooth bore, to boot! Now I've just got to put it all together to see if it works!
With luck there should be a photo of the bits in my album and hopefully, later today, the finished article.
Thanks, once again to everybody for your interest and assistance.
