Chris Denton | 09/08/2014 18:47:56 |
275 forum posts | I've had several times this week aluminium 6082 plate (two different sources) which has pitted while on the mill. The first time it happened over night, today it happened in a couple of hours on a fresh piece of aluminium. The plate is clamped to the table with a piece of normal A4 paper underneath to raise it slightly off the table so the sides can be milled. Lubricant is Multi-Spec G at 25:1. It happens where the paper touches the aluminium. Even where I've used paper under the clamps it has pitted, but not as much. By chance I've used two different types of paper! Any ideas? |
Bazyle | 09/08/2014 19:21:41 |
![]() 6956 forum posts 229 photos | I think it is electrolytic corrosion where the paper is wet. Perhaps you can put an additional layer of tinfoil in so that corrodes instead, or clingfilm to break the circuit. I haven't looked up the spec of the aluminium to see if it contains copper that is a bit of a corrosion magnet. |
_Paul_ | 09/08/2014 19:23:09 |
![]() 543 forum posts 31 photos | I wonder if caustic soda is an element of the bleaching/whitening agents in your paper? Paul |
JasonB | 09/08/2014 20:08:36 |
![]() 25215 forum posts 3105 photos 1 articles | Most paper is acidic, thats why when mounting artwork you should use "acid free" or "neutral ph" paper and board |
Boiler Bri | 09/08/2014 20:24:38 |
![]() 856 forum posts 212 photos | Interesting, we mill a lot of aluminium for our label application machines and never have this problem. So we can assume that it is the paper? Our engineers never use paper to raise, or clamp surface protect and I never have a problem with their finishes, as I am the BOSS who has to be pleased before a machine leaves our factory. All our aluminium is anodised in either natural or red finish and again this always looks great. If your milling the edges as you say and raising the piece to clear the bed the paper your using must be very thick to achieve this, so why not use another piece of plate to raise it?
Just a thought
Bri
Andrew Johnston | 09/08/2014 20:47:53 |
![]() 7061 forum posts 719 photos | I've been using ordinary A4 copier paper under clamps for years with 6082 and never seen this problem. Given that the 6082 came from two sources and the paper was of two different types, the only common factor is the coolant? Regards, Andrew |
Max Tolerance | 09/08/2014 21:00:55 |
62 forum posts | Just a thought that the aluminium, paper, cast iron (presumably) bed and acidic coolant would make a reasonable battery so the effect could be electrolytic. |
Ian S C | 10/08/2014 11:43:19 |
![]() 7468 forum posts 230 photos | Try a multi meter across the aluminium, and the mill table, you might just find .5 volt approx. Maybe better to use kerosene/paraffin. Ian S C |
John McNamara | 11/08/2014 16:22:17 |
![]() 1377 forum posts 133 photos | Hi Chris I wonder if the clear semi rigid plastic A4 sheet as supplied by office supplies for ring binding would work as well as paper. Being plastic it would creep a little under compression but I doubt it would creep very much. It is not particularly slippery. With luck you will have an old manual or similar to use for a trial. Being an insulator electrolysis would be stopped. And no problem with the PH. Regards
jason udall | 11/08/2014 18:41:28 |
2032 forum posts 41 photos | Sounds very much like electrolysis. ..two dissimilar metals seperated ( paper) by an electrolyte. . (Coolant)...have seen it between galvanised tote trays and parts...we found glossy paper better than ordinary paper...but you can get it in minutes on a bad day... ( in our case high carbon steel and galvanised tote tray)... not funny when you lose 150 parts at a time......moved over to lining trays with heavy gauge poly bag.. ( don't know gauge but 0.1mm thick)... two layers for safety. .. In your case sorry but sure clamping will cut through the plastic...maybe change coolant from water based..... We used to wash parts immediately if ali.just to avoid this problem |
jason udall | 11/08/2014 18:43:58 |
2032 forum posts 41 photos | A further thought...waxed paper might help |
Chris Denton | 11/08/2014 23:31:15 |
275 forum posts | Some interesting replies, all of my multimeters are broken except one which I have left at work. I will try and measure voltage this week.
I've changed to using gauge plate under parts while they are on the milling machine now with masking tape on top. It's not happened since. Although I left last night the gauge plate with masking tape on top of the rotary table. The gauge plate was against the table and the masking tape on top of the gauge plate. The gauge plate had corroded under the masking tape. |
Neil Lickfold | 12/08/2014 07:15:37 |
1025 forum posts 204 photos | There is a couple of reasons, 1st to look at is the Ph of the coolant. If new coolant still does the same result, it could well be an electrical issue with you mill . A bad earth or insulation breaking down and creating electrolyses. Seen 1st hand what happens when a motor windings have the insulation breaking down. Even though you do not get an electrical shock, there is current running through it causing electrolyses. Neil |
Ian S C | 12/08/2014 11:16:57 |
![]() 7468 forum posts 230 photos | Is your machine earthed, it may appear so, but worth checking. Ian S C |
Chris Denton | 12/08/2014 21:00:11 |
275 forum posts | I will dig out the Megger and do some tests! |
