Peter Simpson 3 | 12/01/2022 10:02:20 |
122 forum posts 2 photos | Has anybody moved a Harrison 250 if so. Would removing the lathe from the makers stand be a problem to ease the lifting and moving. My workshop in my garden so lifting the entire lathe from the drive would be rather difficult. Thanks Peter |
Andrew Johnston | 12/01/2022 10:18:52 |
![]() 7061 forum posts 719 photos | I understand that Harrison lathes were fitted to the stand and aligned at the factory. It would be regarded as an all round bad idea to split them. Andrew |
Richard Millington | 12/01/2022 10:53:29 |
101 forum posts 9 photos | I would certainly leave the bed attached to the stand, but when I moved my old Boxford BUD I removed the headstock, motor, saddle and tailstock so it was easy to get into a Berlingo. Maybe worth looking into for the Harrison. |
Spurry | 12/01/2022 13:46:19 |
227 forum posts 72 photos | Andrew's comment is correct regarding the factory alignment. My M250 was replaced by Harrisons when I bought it in 1986, because of a problem with the bed to stand joint. I would agree with Richard that you could remove such bits as the motor, tailstock, end cover and splashback, to make it a little lighter. Pete |
Richard - | 12/01/2022 13:47:00 |
62 forum posts 7 photos | Hi Peter, Have a look at Harrisonlathe.groups.io if you search there is lots of information. The manufacture process is the same for the M250 or M300. Single eyebolt through the bed is the correct method for lifting, I made a purpose built wheeled dolly to fit and made a path with shuttering ply as required. Best of luck, Richard |
Spurry | 12/01/2022 13:56:34 |
227 forum posts 72 photos | You could always mount on 5 wheels, which makes single-handed movement a doddle. Pete |
Peter Simpson 3 | 12/01/2022 14:07:27 |
122 forum posts 2 photos | Thanks for the replies. I'm torn between keeping my Boxford ME10 and getting a slightly bigger lathe. As stated my workshop is in my back garden. Between the gravel drive there is a gravel path and an 18" retaining wall to negotiate. When I put my Tom Senior milling machines and my laths into the workshop I stripped them down to smaller "lumps" me and her in doors managed it with a few cross words. The problem with a Harrison 250 is that it's probably 3 times the weight of the Bpxford and the Myford.. Gavel paths and drives are fine unless you want to shift heavy objects. Edited By Peter Simpson 3 on 12/01/2022 14:07:59 |
ega | 12/01/2022 14:38:13 |
2805 forum posts 219 photos | Spurry: How is that third wheel lowered, please? I can see what seems to be a short lever in your photo but presumably it needs to lift the considerable imposed load. |
Spurry | 12/01/2022 17:46:47 |
227 forum posts 72 photos | EGA If you have a look in my album, there are several pictures of the mod. (It is not my original idea BTW.) The actual raising and lowering action results from a cam action, so not much effort is required. The little odd-shaped piece is the auto lock. Pete |
Norfolk Boy | 12/01/2022 18:11:42 |
74 forum posts 18 photos | Hi Spurry, I have an M250 and they are quite low, so can see 2 benefits with that set up, gaining height and flexibilty. I will definitely use that idea. Where did you source the stout looking wheels? I am sure some may think it would affect ultimate accuracy but I would be more than happy with the trade off.
Alan |
JohnF | 12/01/2022 18:43:24 |
![]() 1243 forum posts 202 photos | "Gravel paths and drives are fine unless you want to shift heavy objects." Thick plywood sheets will help here, the least expensive types used as shuttering etc, you probably only need 2 and move along as you go using rollers or skates. If there is a slope then a block & tackle is useful to pull the lathe along, I/we loaded a large lathe onto an Ifor trailer via the ramps with a block & tackle plus some harness etc. Do remember though lathes in particular are top heavy so take care. John
Spurry | 12/01/2022 18:57:06 |
227 forum posts 72 photos | Posted by Norfolk Boy on 12/01/2022 18:11:42:
Alan Being 6'3", the increase in bed height does reduce the amount I have to bend. The ability to move the machine at will is a huge benefit too. I guess the wheels would probably have come from Ebay, paid by Paypal 16/6/2010, at cost of £42.50. Cannot recall the exact seller, sorry. Pete |
Gavlar | 13/01/2022 16:12:11 |
119 forum posts 1 photos | If you search ebay for 'pallet truck wheels' it will come up with wheels very similar with solid tyres and reletively high load ratiings at a reasonable price. Example; https://www.ebay.co.uk/itm/162999377535?hash=item25f3851e7f:g:EPgAAOSwgoNeYh24 I bought a pair just for this very purpose, to make a dolly for moving a heavy lathe single handed. |
Spurry | 13/01/2022 16:59:34 |
227 forum posts 72 photos | Gavlar These look like the ones I bought from Ebay 154566689162. They have been perfectly adequate for my M250, but you may have needed heavier duty. Pete |
