Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Poor quality drill bits |
04/09/2023 10:51:21 |
I still have stocks of Dormer/Esicut etc from 30+ years ago and am glad of it having heard of some of the offerings now available |
Thread: Diamond Inserts |
04/09/2023 10:22:04 |
Jason, I have been using mine dry for about 4years and there is no build up on the tip at all. for hobby use it seems that it has a very long life. |
Thread: Compressor question |
03/09/2023 20:48:03 |
Sounds like it has some sort of unloader valve. |
03/09/2023 20:24:33 |
FPerhaps you had better read my post again,just saying what size pcd I use Edited By bernard towers on 03/09/2023 20:25:24 Edited By bernard towers on 03/09/2023 20:25:51 |
Thread: Tom Lipton Bender |
03/09/2023 19:24:45 |
Surely if the penetration is good and regular the finish follows? |
03/09/2023 19:21:48 |
I use ccmt 0602 size on ally/brass and bronze, the finish on ally has to be seen. They work on materials without a ferric content. |
Thread: Bandsaw Blade Tension |
03/09/2023 10:24:08 |
Interesting to know that I am not the only one who looks at HMSC's site it has some interesting stuff. |
Thread: Machinery Handbook |
31/08/2023 09:15:20 |
problem is what's relevant to one may not be to the other! |
30/08/2023 14:54:49 |
I personally use a Newnes in the workshop as it’s much smaller and has most commonly needed info. |
Thread: New User Looking for Equipment |
30/08/2023 12:58:49 |
Look in All ads 4th to 7th june |
Thread: Insize Coacial Indicator used in Vertex Boring head |
29/08/2023 23:57:09 |
In agreement with OM can't see the point of using headroom especially if you do not have much! |
29/08/2023 18:35:46 |
look at the ads Matt |
Thread: Another Mystery Object |
27/08/2023 12:14:51 |
That was a good find! |
Thread: Help! Excessive machine marks! |
27/08/2023 12:12:48 |
Wouldn’t mind betting that the saddle gibs need adjusting if you are marking the material on the way back. |
Thread: Replacement motor for Lathe |
26/08/2023 23:52:53 |
Surely the wiring only goes to the terminal box? |
Thread: Brake line junction block. |
26/08/2023 23:51:33 |
My Bike banjos are fitted with dowry washers and are ok but having said that the fluid is fully synthetic. |
Thread: Clarke ML 300 speed control |
26/08/2023 23:49:08 |
looks like the arc ones are ok as they are 4k7 just choose with or without switch. |
Thread: Draper GD16/16c pillar drill drive belts |
26/08/2023 23:46:05 |
I should imagine it's seized in its socket ,the idea is that rocks to the correct place when the second belt is fitted. By the look of the machine mod no it is a 16 speed machine which is why the centre jockey pulley needs to float to accommodate several belt arrangements. |
Thread: Bell Metal - What is it good for? |
26/08/2023 23:36:59 |
went to a bell foundry in Italy that does founding for the Vatican and they still dig holes in the floor and line with clay and animal hair. Same set up for centuries. |
Thread: Myford ML10 single wheel knurling tool. |
26/08/2023 20:50:08 |
sorry Andrew but if you have Hemingway tool with diamond knurls why don't you buy a straight set from Hem and then you would have a tool able to do both patterns. I bought both sets when I made mine and as they are Industrial quality will do a fantastic job for a very long time in a home workshop environment possibly saving money in the long run(buy cheap buy twice)!!! |
