barry | 26/08/2023 22:22:56 |
7 forum posts 1 photos | Hello, I have just bought a Myford ML2 I think. It came with a very old motor. The specifications on the motor are HP1/4, volts 220, amps 2.6, cycles 50, revolutions 1450. I do not like the look of the wiring so I have a spare motor rated at Amps 1.5, HP 1/3, revolutions 1420, HZ50, volts 230. Would this be a suitable replacement for the old motor?
Thanks |
Ady1 | 26/08/2023 22:40:27 |
![]() 6137 forum posts 893 photos | The newer motor is fine Your main challenge will be sorting out the lathe, use a slack belt to start with until you get some familiarity Edited By Ady1 on 26/08/2023 22:43:08 |
bernard towers | 26/08/2023 23:52:53 |
1221 forum posts 161 photos | Surely the wiring only goes to the terminal box? |
Tony Martyr | 27/08/2023 10:20:08 |
![]() 226 forum posts 45 photos | Faced with a failing motor on my 1962 Myford lathe I replaced it with a Newton Teslar CL400 variable speed drive and motor. A very easy direct replacement that has transformed my work on the lathe by being able to dial in any chuck speed for tapping, turning and polishing. |
Dave Halford | 27/08/2023 10:44:22 |
2536 forum posts 24 photos | Posted by barry on 26/08/2023 22:22:56:
Thanks Yes depending on the motor spindle size matching. |
old mart | 27/08/2023 21:51:28 |
4655 forum posts 304 photos | Lucky you, to have an ideal replacement, good turning. |
