Used Coacial Indicator inBoring head to centre spindle
Chris Mate | 29/08/2023 18:04:35 |
325 forum posts 52 photos |
Just for fun: I mounted the Insize Coacial Indicator not in a 10mm collet directly in spindle as usual, but mounted the Boring Head 1st, then the Coacial indicator in the boring head itself intended to be as one MT4 swop in spidle rather than two operations. See both pictures: |
old mart | 29/08/2023 21:00:43 |
4655 forum posts 304 photos | I have one at the museum and used it the other day for a similar boring job. I always try to get the axis of the bore lined up with the spindle by eye before selecting a suitable probe. The nylon ring is probably for storage, I'm in two minds whether to leave if off altogether. If your spindle speed can be reduced to under 150rpm, then under power is the best way to get the X and Y axes to the null point. A lot depends on the finish in the bore as a rough one will make the needle jump about badly and make accuracy difficult. You should not use the boring head to hold the coaxial indicator, it should be in a collet running true to the spindle. |
bernard towers | 29/08/2023 23:57:09 |
1221 forum posts 161 photos | In agreement with OM can't see the point of using headroom especially if you do not have much! |
Chris Mate | 30/08/2023 05:59:53 |
325 forum posts 52 photos | I was trying to illustrate that the offset movement of the Coaxcial Indicator when fitted to the boring head as oppose to a collet does not effect its working due to how it works and dependant surfaces, which I found interesting, and in my opinion its still moving around an arc from the spindle centre, similarly as if you not having a coaxcial indicator and using a boring bar/ insert tip to centre the thing either in a bore or around another circular feature visible after the bore was woreout and out of round and you want to bore it out but keep the original geometry of the mesching of the gears making a sleeve. So in this case a Coaxcial indicater would not be usefull, a case like I might be facing if my plan-A in restoring a bansaw & gearbox does not work, so basicly I am just thinking about all of this in all directions and thanks for all other opinions. So its just a theoretical thing, not to say you must do it this way. Edited By Chris Mate on 30/08/2023 06:02:29 |
