Chris Goodwill | 25/06/2023 19:06:58 |
7 forum posts 3 photos | Hi I was Given an old record vice last year and have just got around to looking at it. After drilling out the sloted countersunk screws that hold the jaws on, I am having trouble identifying the thread. They could be a metric M8 x 1 fine thread or a 5/16 26tpi. The only other bolt on it is a 5/16 BSW. I have tried looking up 5/16 26tpi but this seems to refer to a bicycle thread. Anyone know what size these screw are suppose to be? |
noel shelley | 25/06/2023 19:17:35 |
2308 forum posts 33 photos | If it's an old record it will be BSW 5/16" bsw is 18tpi. 26tpi can be cycle or brass, whit form and ANY dia ! 1/4"BSF is also 26tpi. Good luck. Noel. |
Chris Goodwill | 25/06/2023 19:40:22 |
7 forum posts 3 photos | Just to add this bolt is 7.7mm dia and with my pitch gauge is ithere 26 tpi or 1 mm. I think i will thread a piece of bar M8 X 1 and see if it fits. |
old mart | 25/06/2023 19:43:17 |
4655 forum posts 304 photos | I would plump for the 5/16 x 26. When I bought the present house, there was a poor looking old vise in the garage. It turned out to be a 5" Record steel bodied model. The jaws were scrap and I had great difficulty getting the screws undone and the threads were 5/16 26 BSC. I made some new jaws and got a couple of suitable screws on ebay, cleaned up the leadscrew and the jaws are parallel to within 0.002". That makes up for my mistake in leaving my 4 1/2" Paramo behind when I sold my bungalow. |
peak4 | 25/06/2023 19:57:54 |
![]() 2207 forum posts 210 photos | It would seem that Record used 5/16" BSC on some vices, as The Viceworks makes them specially , but make sure you pick the correct countersink angle. Edited By peak4 on 25/06/2023 20:00:17 |
Fulmen | 25/06/2023 20:13:23 |
![]() 120 forum posts 11 photos | What do you mean by "old"? I could imagine a true Briton chewing on broken glass before using a metric thread to this very day
Besides nobody uses anything other than metric coarse (M8x1,25) unless they really have to. |
Chris Goodwill | 25/06/2023 20:17:46 |
7 forum posts 3 photos | Thank you everyone The vice is an old record 34 steel and I did wonder about the countersinks as the holes looked a bit odd, been 60 Deg makes a lot more sense |
peak4 | 25/06/2023 20:39:20 |
![]() 2207 forum posts 210 photos | Posted by Chris Goodwill on 25/06/2023 20:17:46:
Thank you everyone The vice is an old record 34 steel and I did wonder about the countersinks as the holes looked a bit odd, been 60 Deg makes a lot more sense According to the website, the 60° angle was used on 34/35/36 vices. |
Neil Lickfold | 25/06/2023 20:57:05 |
1025 forum posts 204 photos | I have recently done up an old Record vice. The thread is 60 deg 5/16x26 TPI. I found Tap that suited , and cleaned up the damaged threads with that tap. It was available here in NZ. it was called a Bicycle 5/16-26 tpi, different to the Brass being 55 deg pitch angle. I made the screws from long M8 capscrews. Cut the M8 thread off, trued the head diameters to the shank. Put in a small centre, and then held onto them from the head and a steady, and screw cut with a 26 tpi partial form 60 deg threading insert, until the diameter of the thread outer diameter was 8.87mm diameter. I couterbored the existing jaws, so the normal caphead screws would fit. I plan on makeing other jaw sets for this vice, so using a ball end hex key makes them easy to install.. Neil |
Trevor Drabble | 25/06/2023 23:29:41 |
![]() 339 forum posts 7 photos | Chris , Maybe worth having a word with Wilkes Engineering and Machinery, also know as The Vice Works . They manufacture replacement jaws for a number of British vices , so perhaps could supply you with the correct screws. Trevor . |
