ways protector for my mini lathe
Proecting ways from swarf
andrew lyner16/07/2023 22:11:28
274 forum posts
5 photos
Some while ago, I looked for and bought some 'accordion' strip to cover my mini lathe ways. It has never been satisfactory because it is too stiff and too light so it will not stretch / compress enough, whatever length I choose for it. It just rides up and the chuck hits it.
I have read that some people are over the moon with what they have bought and I need to source 'what they're having'. There's a lot of stuff available from China at a reasonable price but, from the images, it seems to be the same woven structure that I have already. If it is a bit flimsy, that doesn't matter as I can replace it every so often.
I'm sure some ME members must have the right stuff. Where did you all get it?
Cheers
Huub16/07/2023 23:18:49
220 forum posts
20 photos
I have tried a lot of stuff on my lathes.
On my mini lathe I use some old (new once are to stiff) jeans cloth bolted to the carriage and magnets on the head stock.
On my bigger lathe I have a piece of wood under the chuck mounted to the carriage using magnets. The cross slide is also covered by jeans bolted to the cross slide on one side and magnets on the other side.
Nigel Graham 216/07/2023 23:18:54
3293 forum posts
112 photos
The equivalent on my Myford vertical mill is just a sheet of butyl-rubber pond-liner, an offcut from making the pond.
It's held by aluminium strips and screws using the tapped holes that presumably once held the original shields. (The machine is second-hand.)
Andrew Johnston16/07/2023 23:22:43
7061 forum posts
719 photos
My CNC mill came with concertina way covers. None of my manual machines have way covers and I see no point in fitting them. Just something else to get in the way.
JasonB17/07/2023 06:47:41
I'm with Andrew my mainly used machines the WM280 and X3 don't have any covers and I don't feel the need for them, teh SX2.7 has one on the column and it make sit harder when cleaning down and ha shad to be removed a couple of times to fit large items items. CNC came with metal sliding covers but they don't get much swarf on them
Paul Lousick17/07/2023 07:58:27
2276 forum posts
801 photos
Link to a Youtube video on Blondihahacks showing how to add way covers to a lathe.
Trevor Drabble17/07/2023 09:20:45
339 forum posts
7 photos
Arceurotrade concertina covers.
Journeyman17/07/2023 09:40:56
1257 forum posts
264 photos
I just have a length of plastic DPC material on my WM250. It just bows up a bit if working very close to the headstock. Makes it a little easier cleaning up and stops most of the swarf getting under the saddle.
The bolts also serve to prevent swarf getting into the threaded holes for the travelling steady.
andrew lyner17/07/2023 10:57:09
274 forum posts
5 photos
Posted by Journeyman on 17/07/2023 09:40:56:
That's basically what I've ended up with - a short length of the concertina on the cross-slide. It's always in the best place to catch most ofd the swarf. I reckon it's definitely better than nothing so I'll stick with it.
As always, I appreciate the various views that ME always gives me.
PS you can't even put multiple quotes (it seems) on a post. Another drop-off. I'm amazed that ME members, of all people, aren't constantly bleating about the inadequacies of the forum mechanism. In a 'mechanical' context, they are all keen on making improvements but they are very conservative when it comes to software.
