Member postings for Russell Eberhardt
Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: Unrecognised Acronym on ebay listings 'UKPL'
18/11/2018 10:42:49
United Kingdom Political Lunacy?
Russell
Thread: AF socket sets. Are they extinct
13/11/2018 10:35:30
Posted by Andrew Tinsley on 13/11/2018 10:17:36:
In the wilds of France, you can't call out the AA.
It's a different system in France. Most, if not all, car insurance includes roadside assistance and recovery. In the event of a breakdown you just call the insurance company and they will send out someone from the nearest approved garage. It seems to work well.
Russell
Thread: Er32 chuck for Fortis lathe
11/11/2018 16:31:52
I was thinking the same Clive. The nut should centre itself on the front of the collet, not on the thread.
Russell
Thread: Cheap 3D printers
11/11/2018 16:26:44
That looks to be the same as the Geeetech A10. I wonder who copied whom.
Russell
Thread: Lead Bearing Solder is Banned
11/11/2018 11:35:27
Posted by Vic on 11/11/2018 11:12:47:
I read just recently that modern camera lenses are no longer made with leaded glass and are the worse for it according to some.
There is an exemption to the EU Directive on lead relating to optical glass which reads, "lead in white glasses used for optical applications," (13(a) in EU 2017/1011 of July 2017).
Russell
Edited By Russell Eberhardt on 11/11/2018 11:36:41
11/11/2018 09:57:06
Posted by Speedy Builder5 on 11/11/2018 07:26:15:
Lead leaching back into the ground, where did lead come from in the first place ?
Would we be here if it wasn't present? Interesting article:
Russell
Thread: Evenings all
11/11/2018 09:51:08
Hi John,
Welcome from another (retired) martial artist, over 40 years of Aikido. Enjoy the learning and playing with the machines.
Russell
Thread: Model Electric Motors?
11/11/2018 09:43:08
Posted by Sam Stones on 10/11/2018 21:17:38:
Or, does it produce lots of radio interference and burnt out contacts?
Indeed, if Jason was building it for resale he would have to ensure that it complies with" EMC recast Directive 2014/30/EU" wink
Russell
Thread: Solution found to the World's biggest problem . . .
10/11/2018 17:00:45
Posted by Mike Poole on 10/11/2018 13:47:06:
Will the planet self regulate? As it warms up we will burn less fuel and nature will recover? Maybe?
Unfortunately not. Heating only accounts for a small proportion of fossil fuel use.
Russell
Thread: new member in france
10/11/2018 10:34:05
Following this thread has remided me to update my profile! Just done it.
Russell
08/11/2018 19:08:38
Posted by Bazyle on 08/11/2018 17:41:45:
Russell, what is the French name for Yorkshire fittings?
I've not seen solder loaded ones but the plain copper ones would be "raccords à souder". They are normally silver soldered here, hence the easy availability of oxy acetylene gear in DIY stores.
Russell
08/11/2018 15:21:57
Posted by CuP Alloys 1 on 08/11/2018 13:46:24:
It is not illegal to use lead bearing solder. The law prevents it from being sold or placed on the market - that means sampled or given away. It is very similar to the legislation forbidding the sale of cadmium bearing silver solders. After all, it emanates from the same European capital.
I wonder if this is really true or if it is mis-interpretation by the HSE. Lead bearing solder is still on sale here in France in DIY outlets, both 60/40 and 50/50 alloy. Here is an example sold under a well known brand name:
Russell
Thread: For discussing the merits of alternative 3D CAD programs.
08/11/2018 09:48:49
I'm surprised that nobody has mentioned Onshape. While it can be a bit slow for really complicated assemblies it has the advantage that it is free and, as it runs within a browser, it works on Windows, Linux, and OSX. It is produced by an ex Solidworks team and I find it very easy to use having first learned 3D CAD on Solidworks about 18 years ago.
Although I also have Fusion 360 installed Onshape is my goto program.
Any other views on it?
Russell
Thread: Fireworks Ban
07/11/2018 09:42:50
Posted by Mark Rand on 06/11/2018 23:19:09:. I now need to photocopy the rest of the forms, so I can buy an Explosives Precursors and Poisons license, to allow me to legally own and use the chemicals that I've had in the shed for the last 15 years...
Just had a read of the list in the regulations. Fortunately I live in France so I am not liable to 2 years in prison for possessing a lead acid battery in my car. It contains about 30% sulphuric acid.
At least three of the listed products are available at DIY outlets and many supermarkets here!
Russell
Thread: SX2P - Thrust Bearings??
07/11/2018 09:12:38
If you look at my thread on converting the SX2P to CNC you will see that adding thrust bearings is easy.
http://www.mycncuk.com/threads/4524-Sieg-SX2-Plus-build?highlight=russell
Russell
Thread: Another new member from France.
05/11/2018 09:28:10
here was another recent thread "new member in France" where there was a member based near Poitier. Did you see that?
Russell
Thread: Win 10 updates (again)
05/11/2018 09:22:27
Posted by Danny M2Z on 05/11/2018 04:31:37:
My old workshop P4 computer is still running Windows XP, it is not networked or ever connected to the Internet and it's sole task is to run Mach 3 which it does nicely (I have plenty of backups, spare drives and power supplies). Any updates or useful machining tips are transferred via a USB stick. As Mach 3 indicated, it is best run on a dedicated system.
Same here. It's been working fine for five or six years now with no updates.
Russell
04/11/2018 11:44:45
Just downloaded and installed the latest big W10 update on my dual boot laptop. It took a whole day to install after downloading at night. Five or six reboots required, each time it booted into by favourite OS rather than W10 so I had to reboot again. Finally W10 was updated and working but responded very slowly to the keyboard. Another reboot and everything seemed OK, at least until I fired up Fusion 360. It failed to start as the system time was wrong. It hadn't remembered my internet time server settings. Told it to use the European pool rather than the Windows time server, rebooted once more and all was well.
Why do MS make updates so difficult? When I update the Linux installation it takes minutes and works in the background with no reboots necessary.
Russell
Thread: An alternative to parting-off
04/11/2018 11:19:45
Posted by vintage engineer on 04/11/2018 09:41:17:
Never understood why people have problems with parting off. Now we have insert parting tools it's a doddle, as they are made for power feed parting off. I usually set the lathe speed to about 500rpm to 800rpm and a medium speed feed and let it go.
I have happily parted off 10" round bar with no problems.
No doubt on a Super Adept lathesmiley
Russell
04/11/2018 10:16:03
Posted by michael smith 23 on 03/11/2018 12:03:51:
! I live in the vienne about 30kms south of poitiers.Maybe it is modern day trend in leisure time that fewer people are hiding in sheds making things like they used to or is it a generation thing related to schools etc not teaching metalwork or similar skills for many a year?
A few years ago there was an association MODELEXPO based near you in Neuville de Poitou.
I think interests have moved away from pure metalwork to more general construction methods. There is a makerspace (FabLab) near us in Perpignan where non members can, for a small fee, use 3D printers, laser cutters, vacuum former, computers and an electronics lab. Not much metalwork other than hand tools.
Russell
