Er32 chuck for Fortis lathe
sean logie10/11/2018 17:12:24
608 forum posts
7 photos
Been a while since I've had time for my wee workshop ,so today I decided I would make the er32 chuck I've wanted for a while now ,so I used a chunk of stainless I had ,probably not ideal but it's what I had . It's not perfect but it's accurate where it matters . I put a tenths indicator on the inside of the collet taper and it barely moved which kinda surprised me a bit 😁 but I'll take it . The only negative is the cheapo collet set I bought have 0.002 run out ,I tested using three different sized carbide End mills in the collects. .
Martin Connelly11/11/2018 07:39:02
2549 forum posts
235 photos
ER chucks were developed for holding tooling and for most cases the runout you have would be fine. Home workshop users have started to use them for workholding and this may then give unacceptable results. If you have a 4 jaw independent chuck you can get the runout required for what you are doing if it needs to be lower and as a compromise, if you want to also use your ER collets, you can mount a collet holder in a 4 jaw chuck. A square ER32 collet chuck may be your next piece of tooling to make or buy. They are also useful for holding round parts in a vice for milling so not limited to one infrequent use.
Martin C
sean logie11/11/2018 09:03:48
608 forum posts
7 photos
The run out I have in the er32 collet is good enough for what I do . It's true that you get what you pay for . I do have a four jaw independent. I wanted to make er32 chuck to use/have and also as an exorcise to see if I could make something that had to be accurate ,up till now I've just been mucking about . 😊 I have a square block er32 holder which is a very handy piece to have .
Sean
Emgee11/11/2018 10:39:18
2610 forum posts
312 photos
Hi Sean
Have you modified the collet closing nut in some way as all of my ER collet nuts wrap around the front face of the collet which hinders working close to the collet face.
Does the nut still engage the slot in the collet to assist removal ?
Thanks, Emgee
Michael Gilligan11/11/2018 10:53:56
23121 forum posts
1360 photos
Well-spotted, Emgee
Whatever that modification might be, it could be useful !!
JasonB11/11/2018 11:04:39
Or more likely the nut has just been tightened down a bit on the empty collet which makes it stick out.
Same 12mm collet one with a cutter the other tightened down a bit by hand with nothing in it
Edited By JasonB on 11/11/2018 11:04:59
Michael Gilligan11/11/2018 11:12:26
23121 forum posts
1360 photos
crying 2
sean logie11/11/2018 13:28:58
608 forum posts
7 photos
Emgee I've not made any alterations to the nut ,the release of the collet works the same as the original. It pops out like it should 😉 . The collet is a beautiful fit .
Sean
ega11/11/2018 13:55:03
2805 forum posts
219 photos
sean logie:
For 'tis a jolly good lathe!
Here is my shop-made version showing also a GHT-inspired dividing attachment for use with milling and drilling spindle:
Not obvious in the photo but I have made the chuck body long enough to be able to work up close despite the gap.
sean logie11/11/2018 14:00:04
608 forum posts
7 photos
My old Fortis is a bit rough around the edges but it's accurate enough for me 😉
Sean
ega11/11/2018 14:28:01
2805 forum posts
219 photos
Posted by sean logie on 11/11/2018 14:00:04:
Sean
Tony Griffiths gives them a good write-up as you are no doubt aware.
Clive Brown 111/11/2018 14:31:53
1050 forum posts
56 photos
Don't necessarily put the run-out down to your "cheapo" collets. I made a similar ER25 chuck and at first had a few thou. run-out, similar for all my collets despite the taper running true. I thought that this might be due to making the screw-thread a wee bit too tight, so took off a shaving. Sure enough, the run-out reduced to less than a thou. at which I'm quite happy.
Edited By Clive Brown 1 on 11/11/2018 14:33:07
Russell Eberhardt11/11/2018 16:31:52
2785 forum posts
87 photos
I was thinking the same Clive. The nut should centre itself on the front of the collet, not on the thread.
Russell
sean logie11/11/2018 16:33:46
608 forum posts
7 photos
Food for thought gents .
Sean
ega11/11/2018 16:35:14
2805 forum posts
219 photos
Posted by Clive Brown 1 on 11/11/2018 14:31:53:
Interesting point; my Quick Step Mill with ER20 spindle came with a rather loose collet nut. The designer/manufacturer may have had the same idea in mind.
Emgee11/11/2018 17:47:52
2610 forum posts
312 photos
After checking further all Emco made ER25 collet chucks I use have the front of the nut extended to always be about 2mm in front of the collet face .
The other makes including Schaublin (RH front in pic) do allow almost flush facing if in the lathe.
Emgee
