Member postings for DiogenesII
Here is a list of all the postings DiogenesII has made in our forums. Click on a thread name to jump to the thread.
Thread: How do i machine this ( on the wonk)
15/02/2023 18:31:08
Posted by Ady1 on 15/02/2023 14:07:45:
You need a lathe with a curved bed
Funnily enough I once bought a 4-jaw chuck from a man on Ebay which would probably have made a breeze of this job. The swine.
..Anyway, just out of interest, what's the make of the grinder? - it seems like a bit of a complicated manufacturing solution to a simple problem.
Thread: DIY milling machine
11/02/2023 14:44:25
If you are serious then another 'food for thought' item are these pictures & descriptions of the of the origins of the BCA jig-borer; built like the Boley & Leinen with a plain compound table it doesn't get much simpler than this.
Lathes.co.uk - BCA Jig-Borer
Thread: Design help for Myford style saddle stop
10/02/2023 06:40:18
I wish I could claim my own ingenuity for that one, but I think it might have also have come from HH, or an article in MEW 'back in the day'..
Cutting the slot off-centre and using screws of different patterns are style innovations of my own however..
I'm afraid much of my own tooling is made 'for my eyes only'..
09/02/2023 19:37:24
Harold Hall Saddle Stop for the Lathe
09/02/2023 19:30:54
Another variation. Sorry 'bout the awful contrast.. ..a couple of collars so that you can insert calipers / pins / blocks between collar and body adds usefulness img_2073.jpgimg_2072.jpg
Edited By DiogenesII on 09/02/2023 19:31:44
Thread: Machining for the Brave!
17/01/2023 06:55:08
..if the lead is too large to comfortably drive the geartrain from the mandrel, drive it from the leadscrew..
Thread: Headstock taper turning
15/01/2023 18:41:37
Nice; I enjoy these little 'Pittler' interludes, a machine with some interesting features. Thanks for taking the trouble to post, it's appreciated..
Thread: Removing a stuck chuck.
15/01/2023 16:14:33
..never let the left hand engage the spindle drive before the right hand has told the brain that the chuck is fully home on it's seat..
Thread: BSO Dividing head
13/01/2023 18:38:53
Make a better one?
..the 'spring' action only has to retain it in the groove, so it isn't subject to rapid / repeated flexure..
..off the top of my head and without thinking to much about it, if I had to make one I might spend a couple of hours contemplating the concave base of an empty aerosol can..?
Thread: Face Milling Experiment
11/01/2023 06:56:20
Thanks all for taking the trouble; it's always informative to see what you don't have the resources to experiment with yourself.
Thread: Gauge Plate for Form Tools
10/01/2023 17:24:06
Try 'Conecut Taper Drill' as a search term.
Edited By DiogenesII on 10/01/2023 17:25:22
Thread: What has model/hobby engineering taught you? (other than the obvious of how to make stuff)
09/01/2023 17:56:10
Posted by bernard towers on 09/01/2023 15:43:35:
.. ..nice models by the way.. ...
+1 yes
Thread: Preparing for long period of disuse...
07/01/2023 07:46:49
..don't leave machine drive belts under tension..!
Thread: Propane regulator needle won't zero
06/01/2023 06:46:22
Maybe (Likely?) NPT - 27tpi?
Thread: Tom Senior light vertical motor swap
01/01/2023 22:04:46
Andrew, does your mill 'hammer' all the time whatever the cutter and conditions, or is it noticeably worse during some particular operations?
Does it ease up if you tweak any of the parameters?
Thread: Useful Boxes
01/01/2023 17:03:29
The sight of an Old Holborn tin brings back some fond memories..
Thread: Listening to my first AudioBook
01/01/2023 13:31:54
The 'Complete Ghost Stories of M R James' on CD in two volumes by Craftsman Audio.
Excellently read by David Collings - the clarity, pace, intonation, pronunciation, humour, & pathos are all that could be desired and could not in any way be bettered.
I winced at the price when I first bought mine but since then have listened to them over and over and over again; in this case the stories themselves and the way they are read provide such a nuanced whole that there is always something new to catch.. ..I've genuinely never got bored with them..
Thread: Stuart No 4
01/01/2023 08:01:47
bump
Thread: Accurate Colour Rendition for a graphic?
30/12/2022 10:23:39
Try searching 'Colour Picker' ..hope that's the sort of thing..?
Thread: Parallelism of carriage to spindle. Taper.
27/12/2022 14:03:01
It would help if you could explain your test method in a bit more detail, Cedric; symptoms may have more than one cause and it'd be useful to narrow down or discount some of the possibilities.
