Pittler C3 lathe
vic newey | 15/01/2023 17:27:18 |
![]() 347 forum posts 173 photos | Unlike most lathes, the headstock on a Pittler lathe can be rapidly offset by as much as 20 degrees in either direction for fancy taper turning. Here is my first attempt on this 118 year old machine. Using the swivelling cross-slide I first turned a ball near the centre and then added tapers either side. The drive belt restricted me from moving the headstock much more than 7 degrees as it's not long enough to allow further without the belt slipping off. In a factory setting with a much longer belt from above then the full 20 degrees would easily be possible although probably not work between centres but held on a face plate or chuck. The headstock is fitted with one large bolt under the pulley and another smaller one above the degree scale.
old mart | 15/01/2023 17:38:03 |
4655 forum posts 304 photos | What a clever design, obviously specially for constant use in turning tapers. Is there a locating pin for zero, as the scale markings would never be better than +- 1/10 degree? |
Bazyle | 15/01/2023 17:52:44 |
![]() 6956 forum posts 229 photos | Another use I have seen it used for is for facing off the ends of clock plate pillars to ensure they are concave and thus ensure they seat without wobble. A cheaper feature to add to a lathe than a topslide which was not universally provided. |
Peter Cook 6 | 15/01/2023 17:54:18 |
462 forum posts 113 photos | Sherline lathes use a similar approach. They use a key to reset zero |
vic newey | 15/01/2023 18:27:34 |
![]() 347 forum posts 173 photos | Posted by old mart on 15/01/2023 17:38:03:
What a clever design, obviously specially for constant use in turning tapers. Is there a locating pin for zero, as the scale markings would never be better than +- 1/10 degree? No locating pin but takes one minute to set to zero and check alignment of both centre points |
Nigel Graham 2 | 15/01/2023 18:35:51 |
3293 forum posts 112 photos | I think the Drummond flat-bed lathes had a simple version of this, but from what I recall of the early 'B'-type I once owned, there did not seem a clear, positive way to re-align the headstock. |
DiogenesII | 15/01/2023 18:41:37 |
859 forum posts 268 photos | Nice; I enjoy these little 'Pittler' interludes, a machine with some interesting features. Thanks for taking the trouble to post, it's appreciated.. |
vic newey | 15/01/2023 19:07:09 |
![]() 347 forum posts 173 photos | Posted by DiogenesII on 15/01/2023 18:41:37:
Nice; I enjoy these little 'Pittler' interludes, a machine with some interesting features. Thanks for taking the trouble to post, it's appreciated.. Thanks, enjoy my Pittler website as well Vics Pittler website |
Emgee | 15/01/2023 20:52:41 |
2610 forum posts 312 photos | For readers information the Emco Unimat DB and SL have the same feature and use a 4mm pin to locate a truly aligned with bed setting. Emgee |
ega | 15/01/2023 22:05:21 |
2805 forum posts 219 photos | The Barker lathe (with geared head) will do this and has a pin for resetting. |
Neil Lickfold | 15/01/2023 23:25:06 |
1025 forum posts 204 photos | I had an early Drummond lathe, circa 1900 . It had the swivel head on it too. Great for cutting pipe threads. It came with some ball centres , for offset turning. One that went into the chuck of the headstock, and the other for the tailstock itself, a #1 morse taper from memory. It was a great little machine. I now regret that I sold it when I bought my S7 in 1987. Hindsight I should have kept it.
