Leak from pressure pump area on paraffin blow torch
Mash Anscombe | 28/04/2023 22:23:46 |
7 forum posts | Hi there, I am new to this so forgive if needed. I am restoring an old blow torch, well 2 in to 1 and mostly going well, I have it burning now, but I have a leak coming from the pump nut area. There is no washer there but I don't think there should be? Someone I know said, just from a video I sent them, that the safety valve isn't working? The pressure release valve certainly works. Please advise, I am trying to sort this as a gift to my son as he wants to get a new canal boat with a Bolinder engine and a blow torch is how you get them started . Thank in advance for any suggestions offered. |
Dave Halford | 29/04/2023 11:12:42 |
2536 forum posts 24 photos | They meant the pump non return valve |
Mash Anscombe | 29/04/2023 11:22:44 |
7 forum posts | Ah, thanks, that makes sense. So I need a new washer bit in there? What would I make this from please or can I acquire one from somewhere? |
Dave Halford | 29/04/2023 11:27:58 |
2536 forum posts 24 photos | Take the pump unit out and see. |
Mash Anscombe | 29/04/2023 11:30:19 |
7 forum posts | It looks a little less than good, what alternative could I use please? |
Nick Hughes | 29/04/2023 11:50:05 |
![]() 307 forum posts 150 photos | Give Base-Camp a call or e-mail, to see if they can help. |
Mash Anscombe | 29/04/2023 12:19:01 |
7 forum posts | Thank you, I will do that |
john halfpenny | 29/04/2023 12:28:13 |
314 forum posts 28 photos | Is there a small one-way valve at the base of the pump tube? |
Bo'sun | 29/04/2023 12:34:28 |
754 forum posts 2 photos | Hi Mash, Another vote for Base Camp. |
Mash Anscombe | 29/04/2023 12:43:41 |
7 forum posts | Posted by john halfpenny on 29/04/2023 12:28:13:
Is there a small one-way valve at the base of the pump tube? Yes, the little pip, I think this may be perished |
Mash Anscombe | 29/04/2023 12:44:01 |
7 forum posts | Posted by Bo'sun on 29/04/2023 12:34:28:
Hi Mash, Another vote for Base Camp. Thank you |
Nigel Graham 2 | 01/05/2023 22:35:15 |
3293 forum posts 112 photos | Base Camp was my thought too, having overhauled a 'Vapalux' paraffin-vapour lamp with parts from them. A copy of the instructions too, vital as these lamps are operated in a way very different from most equivalents. |
duncan webster | 01/05/2023 22:56:14 |
5307 forum posts 83 photos | Posted by Nigel Graham 2 on 01/05/2023 22:35:15:
........ these lamps are operated in a way very different from most equivalents.
Go on then it looks just like a Tilley lamp, tell us more |
Nigel Graham 2 | 01/05/2023 23:59:01 |
3293 forum posts 112 photos | The .... "Lamp, High Pressure Paraffin No.1 (Vapalux - W.O. Cat. No. JA 5557), Lamp, Store, Type B Complete, A.M. Stores ref. No. 21C/2503" , as the instruction-card says it is, so now we know,..... .... is still a pressure-lamp and it is lit and extinguished in a fairly similar way to a Tilley Lamp, with a meths cup for pre-heating. Its trap for the unwary accustomed to Tilley Lamps, is a finger-attracting control that operates what looks like a flame-regulating needle-valve in the jet. It is not. The needle is an internal jet-cleaner and should be used only as in the instructions, including never for extinguishing the lamp.
They were made, by the way, by Willis & Bates Ltd, in Halifax.
Mash Anscombe | 02/05/2023 07:26:45 |
7 forum posts | Interesting, thanks. I have paraffin lamps but not a Tilley, and have watched videos on operating etc, so hopefully won't get my fingers burnt in a figurative or real way. |
Tim Stevens | 02/05/2023 18:17:54 |
![]() 1779 forum posts 1 photos | If you are seeking advice or parts in England, you will need to be clear whether your device is a blow-lamp - intended to provide heat (which has been overtaken by eg a propane torch), or a Tilley lamp (intended to provide light). They work on the same sorts of fuel, and in very similar ways. A piston pump pressurises the fuel tank, and the heat of the flame assists with vapourising it. The term 'blow-torch' is (in my experience) applied to more modern heat devices, usually with butane or propane gas in a separate tank, and no need to pump. And I admit that a blow-lamp should - from its name - be for lighting. But no. English is like that. Just don't get me going on carbon brushes ... Cheers, Tim Edited By Tim Stevens on 02/05/2023 18:19:05 |
Swarf, Mostly! | 02/05/2023 19:12:16 |
753 forum posts 80 photos | Tim, A quote: "Who but the English would write 'FIRE' on a bucket and then fill it with water?" Best regards, Swarf, Mostly! |
Nigel Graham 2 | 02/05/2023 21:33:59 |
3293 forum posts 112 photos | Well, if they didn't put water in the bucket labelled 'FIRE' it might be awkward if things go wrong around the Blow-lamp that is a lamp not for lighting, except for lighting. Three Huzzahs for eccentricity! . (Well, it makes valves work...) |
