turning tungsten
Matts BitsNBobs10/07/2014 18:00:55
29 forum posts
Hi all,
As it says, any tips on speeds, tools-HSS or tip tools, lubricant etc.
A friend has asked me to turn a piece of bar apx 2in down, not got the sizes yet and I was hoping for a bit of advice. I will be using a super 7 if this helps for speed etc, any help would be much appreciated.
Regards Matthew
Oompa Lumpa10/07/2014 18:14:02
888 forum posts
36 photos
Frankly, sounds like you are in for a real treat. Oh, and he is no friend either.
graham.
Bob Brown 110/07/2014 18:29:55
1022 forum posts
127 photos
Try this **LINK**
JohnF10/07/2014 18:32:28
1243 forum posts
202 photos
Hi Matt, I turned some down to make some sample counter weights, it is tough but not so hard. I used a tipped tool but HSS will also cut it, the components I made had a 6m thread as well and the tap was a standard HSS tap but it was tough going. Lube well with a good quality cutting oil and you should be OK.
Many years ago the company I worked for made a lot of counter weights for aircraft and the material was called heavy alloy, it was largely tungsten , not sure of the other components but again there was no particular problem machining these with normal tooling.
regards John
Edited By JohnF on 10/07/2014 18:32:55
Bubble10/07/2014 20:54:37
75 forum posts
6 photos
Hi Matt
I used to help a friend out, turning tungsten alloy for darts bodies. I don't recall any problems, used HSS and including screwcutting the thread for the flights, probably 2 BA
Jim
Rik Shaw10/07/2014 21:05:37
1494 forum posts
403 photos
Hello Mathew - many years ago a dart playing enthusiast asked me to "thin" down the body of a set of tungsten darts. It was probably the easiest material I have ever turned - like butter with a HSS tool bit. Weirdest thing though is that the swarf came of looking golden - like bronze - but within seconds, oxidised and went grey.
Rik
Roderick Jenkins10/07/2014 23:38:02
2376 forum posts
800 photos
Matt,
Depends whether it is pure or one of the "alloys". I use the quotation marks because the heavy metal (as used in darts) is actually tungsten powder in a matrix of nickel and iron or copper and not a true alloy. Tungsten heavy metal turns like free cutting steel.
Pure tungsten is a different matter. This link may help.
If it's the latter - good luck!
Rod
Matts BitsNBobs11/07/2014 07:58:44
29 forum posts
Thanks everyone,
First I will see if I can talk him out of it, if not I will let you know how I get on.
Many thanks Matthew
Steve Withnell12/07/2014 18:35:29
858 forum posts
215 photos
Thanks for the explanation Rod - I've a piece of pure Tungsten bar, 1/4 inch diameter and my experience isn't of something that cuts like butter using HSS tooling!
Steve
Roderick Jenkins12/07/2014 21:28:13
2376 forum posts
800 photos
You're very welcome. If anybody has a source of heavy metal bar in small quantities I'd be glad to know of it. It's very good for balancing model i.c. engine crankshafts. 1/4", 6mm, 3/8" or 8mm would all be useful.
cheers,
Rod
Edited By Roderick Jenkins on 12/07/2014 21:28:29
Matts BitsNBobs18/07/2014 16:17:45
29 forum posts
Thanks again for all the help, just to let you know I talked him into using brass, but I am still keen to give the tungsten ago at some point just out of curiosity, if I do I will let you all know how bad it was.
Regards Matt
Versaboss18/07/2014 21:55:57
512 forum posts
77 photos
Posted by Roderick Jenkins on 12/07/2014 21:28:13:
Rod,
that's not too difficult. Over the big water they indulge in a strange sport called Pinewood Derby racing. This has developed into a hi-tech affair, and so they use Tungsten rods and balls to put as much weight as allowed into these cars. Search for Pinewood, and you will see it all.
I also bought some small off cuts of Tungsten in 4-6 mm dia. (iirc) on this famous 4-letter auction site.
I did not any turning tests with these, but if someone asks...
Regards, HansR.
