Alan .204 | 23/04/2014 17:01:27 |
304 forum posts 14 photos | Hi chaps need some help with this one, came home from work and went into the shop to have a play as you do, started on the mill and with in a minute or so lost the table drive after a bit of investigation it became apparent the bronze socket the lead screw runs through had chucked out all of its threads, have removed the part and put a thread gauge on it and its 29 degree's by 10TPI question is what size should the bore be, have ordered a bit of Phosphor bronze from Noggin End Metals should be here by Friday, have done something similar before but can't remember how I worked it out, any help would be useful with working it out.
Al. |
Nobby | 23/04/2014 17:52:04 |
![]() 587 forum posts 113 photos | HI Al It depends on the outside diameter of the lead screw you have the TPI & thread form |
Alan .204 | 23/04/2014 18:32:38 |
304 forum posts 14 photos | Hi Nobby it's an Acme thread 29 degrees 10TPI the out side diameter if the lead screw is 0.624 thou, I've just been looking how to work it out but found nothing so far.
Al. |
Saxalby | 23/04/2014 19:00:03 |
![]() 187 forum posts 33 photos | Alan, This little chart may help - http://www.unionmillwright.com/2884.pdf Regards Barry |
_Paul_ | 23/04/2014 19:32:47 |
![]() 543 forum posts 31 photos | An alternative might be a home made Acetal nut if you have the space for it, Evanut |
Alan .204 | 23/04/2014 22:27:00 |
304 forum posts 14 photos | Been looking around at different sites and this is the ID I've come up with 0.5270 what do you think chaps.
Al. |
Keith Long | 23/04/2014 22:40:56 |
883 forum posts 11 photos | Al Perhaps I'm missing something, but you have the lead screw why not just measure it and make sure. The table I've got gives 60 thou as the depth of thread for a 10tpi acme which from your od of 0.624 would give you 0.504 as the core diameter rather than the 0.527 that you ask about. It's possible that it isn't a "standard" acme thread as I believe that a 0.625 od "standard" acme would be 8 tpi not 10 - that is certainly what Tracy tools list for a 5/8 acme tap either rh or lh. |
Alan .204 | 23/04/2014 22:48:12 |
304 forum posts 14 photos | Hi Keith the lead screw is of my Centec 2B mill its definitely 10TPI as I have an Acme thread gauge and the 10 blade fits perfectly, when you say just measure it I can only measure the OD of the lead screw as I have nothing to measure the thread depth, I think that's what you mean.
Al. |
Alan .204 | 23/04/2014 23:03:56 |
304 forum posts 14 photos | I got the ifo from Crank.com it's a link Jason B gave me on an older post.
Al. |
Alan .204 | 23/04/2014 23:04:07 |
Al. |
John Stevenson | 23/04/2014 23:24:17 |
![]() 5068 forum posts 3 photos | Depends of the fit of the thread.
0.625 x 10 at 2G fit has a core of 0.4844
0.625 x 10 at 3G fit has a core of 0.4954
0.625 x 10 at 4G fit has a core of 0.4981 |
Michael Gilligan | 24/04/2014 08:39:39 |
![]() 23121 forum posts 1360 photos | Posted by Alan .204 on 23/04/2014 18:32:38:
I've just been looking how to work it out but found nothing so far. Al. . Alan, This is probably of academic interest only ... it's orders of magnitude beyond my machining ability !! ... but [*] I think it's worth posting for reference. MichaelG.
[*] given that this discussion has already run from Taps, through moulded Acetal, to core diameters quoted in tenths of a thou. |
Russ B | 24/04/2014 11:20:13 |
635 forum posts 34 photos | my metallurgy isn't what it should be, but what affect do you think slowly heating to around 175-200° (270+ if you use nylon) and slowly cooling will have on the mechanical properties and accuracy of that screw? |
