How to remove oil from a boiler system?
Tim Stevens13/04/2014 16:50:01
1779 forum posts
I need help from an experienced boiler user - I have a car engine & radiator in which oil has been getting into the coolant. I think I have solved the leak, but I still have an engine etc which is coated internally with oil in all the wrong places.
The engine is all cast iron (yes, that old) and the water pump is quite separate, and tha radiator is brass, so the only 'vulnerable' parts are the water hoses which are silicone rubber. Should I fill with plain water, run the engine up, and add some Gunk to emulsify the oil, then drain and refill with distilled & antifreeze? Would this work? Or is there a better way?
Many thanks - Tim
PS its a 1932 Wolseley Hornet Special, just in case that helps ...
maurice bennie13/04/2014 17:13:32
164 forum posts
Hi Tim ,Why not use soap ,dish washer type.PS I was two when that was made and I love them.we had a three wheel 1934 BSA shed tears when that went Hope all goes well whatever you use
Maurice
alan-lloyd13/04/2014 19:45:25
183 forum posts
I had an old Volkswagen, it had a water cooled oil filter housing, which rotted through to the oil ways, because the oil is at a higher pressure it went into the water, I filled it a couple of times with degreaser, but didn't run it up, drained and filled with water, it was perfectly ok. After all what will a little oil harm in the coolant system.
Neil Wyatt13/04/2014 20:53:36
19226 forum posts
749 photos
86 articles
Some years ago, my stepson had a narrowboat with an A-series diesel engine in it. He had oil getting into the water and we spent a very cold (ice on the canal) day changing the head gasket. Horrible job - although it's better access than a car, when you drop a tool you have to fish around in ice-cold oily bilge water to find it
Put it all back together (and it worked!) but the leak was no better, probably worse. Discovered it was a soft-soldered brass oil cooler with cracked joints. Constructed like a small water-tube boiler Took about five minutes to fix it back in the nice warm workshop. Ho hum!
Interesting arrangement, for those unfamiliar with narrowboats, there's no radiator the water circulates through steel 'boxes' built into the sides of the hull..
Jens Eirik Skogstad13/04/2014 23:19:10
400 forum posts
22 photos
To remove oil in cooling system in the engine/radiator: Add 0.5 liter liquid soap + water then run engine to working temperture. Drain the cooling system and flush clean oil / water from the cooling system and refill coolant. The soap dissolves the oil and blends into the water, thus it is easy to remove from the cooling system by flushing with clean water.
stevetee14/04/2014 00:21:42
145 forum posts
14 photos
If you use something like dishwasher powder make sure you flush it well afterwards, it is very aggressive. I had a friend once whose brake shoes were contaminated with brake fluid, I suggested he boiled them up with washing powder. Eager to do a good job he boiled them up with dishwasher powder which destroyed the glue holding the lining on the shoes.
Ian S C14/04/2014 13:47:11
7468 forum posts
230 photos
One of our vintage tractor guys drove his old David Brown tractor to the A&P Show, about 10K, and found that the oil level in the sump was much higher at the end of the trip. We found that the block had a crack between the middle cylinders, and when the engine heated up, the crack opened, and the water leaked into the sump. Ian S C
Tim Stevens14/04/2014 16:29:28
1779 forum posts
Thanks chaps. So, I need half a pint of 'liquid soap' - so will washing-up liquid do?
Interesting for me as a newcomer to the forum - most of the responses were about related experiences but not really an answer to the problem. Such is life ...
cheers, Tim
Tim Stevens14/04/2014 16:45:44
1779 forum posts
In answer to the query 'what does it matter?' the problem is that the oil is likely to be an insulating layer, with a double effect. It reduces the heat flow from the engine, as well as the heat flow out of the radiator.
Tomorrow I will try the effect of running the engine with plain water until it gets to near boiling (no fan) and leave it like that for an hour or two to reduce the oil viscosity and hope that some of it will float to the top. Then I will overfill the rad so the oil overflows (rather than draining back over the internal surfaces). Then I will have a go with soap, and overfill again. Two or three of these treatments might be enough.
Of course, I have just rebuilt the engine and I hope to have found and cured the leak, but perhaps not ...
Cheers, Tim
Brian Wood14/04/2014 17:21:34
2742 forum posts
39 photos
Hello Ian,
I think the washing up liquid in a strong solution is probably favourite, but avoid stirring it too much with the water pump to reduce foaming.
Get it up to working temperature and leave it to stand for perhaps an hour or so before draining and flushing. Cold water is a better solvent for Fairy liquid, flush several times to get all you can out of the system. Then fill again with plain water and add about a pint of methalated spirit to 'kill' the remainder of the Fairy and act as a 'getter' for any remaing oil.
Get that up to temperature. I'd leave that mixture standing overnight before draining and flushing through again with clean water. Fill again with water, run the engine again to warm it up and see if any further oil appears in the header tank. If there is only a trace I would ignore it and make room for the normal coolant to be added.
Regards Brian
