Earth fault on lathe
Myford 254 has developed an earth fault
Chris Barry12/03/2014 15:44:39
43 forum posts
18 photos
Hi all,
My myford 254 has just started tripping the house RCD as soon as I plug it in, I've traced the fault to the 110v control system but that's the limit of my electronics knowledge.
I've tried removing all sections of the control system from the transformer and reconnecting them individually but it keeps happening.
So my questions are, anyone got a hint or tip on how to fix it of further fault find? Or anyone in the Manchester area, specifically urmston who could lend me a hand in exchange for tea and biscuits.
Thanks in advance
Chris
Engine Builder12/03/2014 16:04:10
267 forum posts
Have you tried disconnecting the supply to the 110v transformer. Could be the transformer that has the earth fault.
You need to remove both  the live and neutral as a N to E fault will also trip the RCD.
Edited By Engine Builder on 12/03/2014 16:09:34
Chris Barry12/03/2014 16:36:49
43 forum posts
18 photos
I've had the 110v connections to the circuit removed but with the transformer earth still connected and it doesn't trip out, when I connect the positive of the 110v system it trips it. It was working fine last week and has just started tripping it.
Thanks in advance
Neil Greenaway12/03/2014 16:42:13
75 forum posts
Hi All,
I have a Harrison M390 which has just started causing problems - tripping out the 3ph RCD on the generator we run it on - At first I thought it was dampness allowing earth leakage from some other electronic circuits also connected in the workshop (DRO's etc) so we ran a small heater to dry out the panels just in case - this has helped a little and allows it to run a little longer before tripping. I think the 110v supply might be part of the problem - it supplied the safety circuit and the brake caliper solenoid. The problem also started last week after a heavy downpour of rain - bit of a mystery but just need to get time to properly look into it.
Diane Carney12/03/2014 16:46:06
419 forum posts
11 photos
Someone I know had an earth leak on a lathe. He didn't know until he got a metal splinter in his thumb - then he knew! He didn't know he'd got a metal splinter in his thumb until he used the lathe either. surprise
Cabeng12/03/2014 17:59:13
86 forum posts
59 photos
Chris:
It is possible that the problem lies elsewhere, rather than on the 254. A 30mA RCD will trip when the TOTAL earth leakage current hits 30mA - and there are lots of sources of leakage current. Switched mode power supplies in computers, TV, wall warts, flourescent and CFL lights, wiring, workshop equipment (VFD's can be problematic) .... everything contributes a bit, there's always some of it around. Eventually something adds another piece of straw to the camel's back, and it trips. So something else could have caused an increase, brought the RCD near the limit, then when you plug the 254 in with its 'natural' leakage, the RCD decides to go home to mummy.
Of course, it might be a real problem with the 254, but it might be on some other piece of equipment around the house/workshop. Easy enough to check - disconnect everything else by removing ALL fuses except the one to the workshop, then unplug anything and everything left on that circuit, house & workshop. Including lighting!
Then plug the 254 in - if the RCD trips, you have a problem on the 254. If it doesn't, then you have the 'last straw' situation. Which could be more difficult to resolve!
I'll send you a PM later.
john fletcher 112/03/2014 18:00:47
893 forum posts
To help Chris along, has a reader got a copy of the lathe circuit diagram and who can publish it here, which will help. Chris have you a tradesman friend with a YELLOW 110 volt power tool transformer? If you have, then you can disconnect your 110 volt one and feed the circuit via your friends, which will eliminate the transformer. Alternatively if you have a friend with a MEGGER he will be able to test your transformer in situ. The same friend could check out the motor for earth faults. I’m not familiar with your lathe Chris, what electronic controls does it have? TedTo help Chris along, has a reader got a copy of the lathe circuit diagram and who can publish it here, which will help. Chris have you a tradesman friend with a YELLOW 110 volt power tool transformer? If you have, then you can disconnect your 110 volt one and feed the circuit via your friends, which will eliminate the transformer. Alternatively if you have a friend with a MEGGER he will be able to test your transformer in situ. The same friend could check out the motor for earth faults. I’m not familiar with your lathe Chris, what electronic controls does it have? Ted
Edited By John Stevenson on 12/03/2014 21:53:21
Chris Barry12/03/2014 18:33:31
43 forum posts
18 photos
Cheers everyone, john, I've got the wiring diagrams in the manual, will take a pic when at home and stick it up. Here
cheers cabeng for the tips, will have some fun tomorrow morning turning every thing off
thanks for the help so far everyone
FMES12/03/2014 19:17:36
608 forum posts
I would suggest checking the RCD itself, they do go soft especially if they have tripped a lot.
Les Jones 112/03/2014 22:25:43
2292 forum posts
159 photos
Hi Chris,
In your post today at 16:36 I am not clear on what you mean. I am assuming you mean that the secondary ( 110 volt) side of the transformer has been re connected and you have disconnected the 240 volt feed to the primary. In this condition it does not trip the RCD. When you then re connect the 240 volt live (Which you have called positive.) the RCD then trips. If this is the case then I am almost certain that the fault is with the transformer. A fault of any kind on the secondary side of the transformer should not cause the RCD to trip. (It could cause an over current fault which could possibly cause an MCB to trip.) The fact that it trips the RCD with just the live connected means there must be leakage from the primary winding to earth. As well as posting the wiring diagram a picture of the transformer with a ruler or other object to give an idea of its size would help in suggesting an source for a replacement transformer.
Les.
jason udall12/03/2014 22:40:52
2032 forum posts
41 photos
I
Don't know this machine.
That said I have had to fault find plenty without the wiring diagramms.
If the output of the 110 transformer has a fuse ( it should) isolate the output by removing it.
( ideally if you feel brave disconnect secondary 110 V side totally)..if unit?still "blows" rcd then?fault does not lie in 110V circuit.
Transformers can fail internally. .sorry but thats life.
If its the transformer then replace/repair.. ( repair depends on replacement cost obviously).but repair is not for the inexperienced. .think rewind....
But bearin mind simply removing the transformer might locate the stray connection... ( foreign matter say.).
Chris Barry12/03/2014 22:55:24
43 forum posts
18 photos
Just got home from work will get pictures tomorrow AM.
It's a new transformer from last year due to the primary coil failing, the lathe has only been used a handful of times up over the last couple of years due to me moving between rented accommodation, really hope it's not the transformer again.
Cheers
Richie M12/03/2014 23:35:10
8 forum posts
10 photos
Myford 254 wiring diagram 3Myford 254 wiring diagram 2Myford 254 wiring diagram 1
Richie M12/03/2014 23:37:59
8 forum posts
10 photos
Sorry I hope I haven't upset Chris!
Here are the 254 single phase diagrams.
if you need any other info please ask!
Cheers
Richie
Richie M12/03/2014 23:50:59
8 forum posts
10 photos
Drawing 98Another go at drawing 12898, hopefully a little bit clearer.
Ian S C13/03/2014 08:30:04
7468 forum posts
230 photos
I assume you have eliminated any dampness, condensation from all parts of the supply, and circuit boards, switch gear etc. At one time I had trouble with condensation in the centrifugal switch in the (single phase) motor, required modification of the insulation around the switch gear AOK now. Ian S C
Les Jones 113/03/2014 08:52:09
2292 forum posts
159 photos
Hi Richie,
Many thanks for posting the schematics. I have added them to my folder of Myford information.
Chris, If my understanding of the test you have done is correct the I am almost certain there is leakage between the transformer primary winding and earth. I suspect the transformer will be about 100 VA rating. This is a conservative estimate allowing for a 50 watt light on the 12 volt winding and 50 watts for the contactor coils. If there is space it may be cheaper to use a 12 volt lighting transformer for the light and a separate transformer for the 110 volts.
Les.
Chris Barry13/03/2014 11:10:34
43 forum posts
18 photos
Hi Guys, thanks very much,
Richie thanks for the pics, didn't upset me at all
Below is the picture of the transformer in a state that doesn't trip the power, as soon i connect the red wire to the 110v positive connection.
it is in a damp garage, nothing i can do about that at the moment so damp might be a problem.
is their a check over across the pins of the transformer?
really appreciate all the advise from everyone, sorry i'm not he best at explaining what the problem/i've done with it.
cheers
Cabeng13/03/2014 11:42:48
86 forum posts
59 photos
Hi Chris.
Dampness could have something to do with it. If you have an electric fan heater you could use it to warm everything up and drive out any dampness, see if that makes a difference.
Les Jones 113/03/2014 15:45:02
2292 forum posts
159 photos
Hi Chris,
My understanding of what you had had disconnected was wrong. I though you had disconnected the mains live from the primary of the transformer rather than the wire connected to the 110 volt secondary. This means that the fault is not the transformer. Can you confirm that it is an RCD that it tripping out rather than an MCB. An RCD trips because of leakage to earth. An MCB trips due to too much current. I do not see how anything connected to the secondary of the transformer can cause earth leakage. Can you try reconnecting the red wire to the 110 volt secondary and holding the stop button pressed in and getting someone else to switch the power on at the socket. If it still causes the power to trip then the fault is probably on the wiring to the interlock switches. Do you have a multimeter to do some further tests if required ?
Les.
