David Lawrence 2 | 22/02/2014 17:16:52 |
16 forum posts | Hi all, Just been machining a chuck backplate on my mini lathe, light cuts, the tool dug in into what i think is a stanless steel backplate, big noise and screms from the head stock. I think i must have stripped some gears as the backplate bearly rotates now. I see on the Arc euro site they sell all sorts of gears for these small latrhes. Question is has anybody had to replace some of these gears and how to do it. is it a 2 hour job or 2 days, thanks for looking |
Philrob27 | 22/02/2014 17:26:13 |
16 forum posts | Axminster tools can supply replacement gears they also have a diagram on there web site to show which gear you need |
JasonB | 22/02/2014 17:46:34 |
![]() 25215 forum posts 3105 photos 1 articles | ARC show how to strip the whole lathe here including the bits with the gears, time will really depend on how able you are and if you have the tools for the job. |
Scott | 22/02/2014 18:07:26 |
52 forum posts 10 photos | David Have you had the motor cover off? You might be lucky and it's just the toothed drive belt. Also not unknown for the drive belt pulley to come undone from the end of the shaft. From memory it's only a small screw that holds it on. It can make a good graunching noise if it comes off under load Good luck Scott |
John Stevenson | 22/02/2014 20:24:11 |
![]() 5068 forum posts 3 photos | If it's stripped the gears change the spindle gears for the steel ones and use the plastic one for the layshaft. Reason being it's easy to swap the plastic ones out without a massive strip down.
Buy two plastic ones so you have a spare because of the old adage if you have a spare the original one won't break.
By from ARC, not plugging ARC but they are the cheapest by far. If you don't believe me ring Warco on Monday. |
I.M. OUTAHERE | 22/02/2014 22:15:20 |
1468 forum posts 3 photos | Change the HI/LOW gear leaver to the other range to what you were using and see if you get some drive then . While I don't regard the replacement of the headstock gears as being difficult for me, I can't gauge anyone else's mechanical ability but if you follow the instructions from ARC and take your time you should be ok . I would replace both gears with steel ones and never have to worry about them again although you may notice that they are a little noisy . One thing that rarely gets mentioned is how do you lubricate the steel gears once the headstock is back on the lathe ? Ian
John Stevenson | 23/02/2014 01:50:09 |
![]() 5068 forum posts 3 photos | Problem is with the two steel gears is, for a rank beginner is they are not forgiving and you stand more chance of wrecking a motor or spindle board than a £5.41 plaggy gear. |
I.M. OUTAHERE | 23/02/2014 05:40:47 |
1468 forum posts 3 photos | Yes true it can sort of act like a safety devise although no guarantee that damage will not occur elsewhere ,I would have suspected the belt drive to be the next weakest link which is also cheap to fix but more accessible . Ian |
David Lawrence 2 | 23/02/2014 13:27:27 |
16 forum posts | Hi all, Update to the stripped gears. Thanks for all the advice, having removed some covers it looks like the news is good, the toothed drive belt has some teeth missing and the belt broke in half removing it. So a new drive belt may all thats needed, The drive shaft and layshaft seem ok, so it looks like it got off OK, The stainless steel chuck back plate lives to fight back another day. I have had the lathe for 12 years and its the frist time i have had any trouble like this. I should stick too what i know, Aluminium and Brass. David |
Neil Wyatt | 24/02/2014 20:17:20 |
![]() 19226 forum posts 749 photos 86 articles | Hi David, Don't fear turning iron and steel on a mini lathe. at 12 years your toothed belt was past it's best before by date Neil |
Keith Moat | 27/04/2018 13:17:11 |
16 forum posts | I have the Warco Super mini lathe, which has all steel gears and brushless motor and the belt seems to be the only fail safe on the machine in these situations. I've only had it a month and I've managed to damage a few teeth on the belt when the tool dug in, same thing, screaming from the head stock etc. Luckily it's still running ok, I think the belt was a bit loose and it's not totally taken out the teeth to the full depth. In the US they have an overload cut sensor out on some of their machines, which could save the belt (maybe ?) in these situations. Does anyone know if there is such a system available over here ? |
