Member postings for Scott
Here is a list of all the postings Scott has made in our forums. Click on a thread name to jump to the thread.
Thread: Steam motorbike anyone?
14/04/2015 09:43:12
Interesting but I can't see meself trading in my GSX-R for it! dont know
Thread: Washers (History)
28/02/2015 17:12:28
It's not just the watch itself that is in bad taste. Romain Jerome used to have a big Titanic DNA poster up in Geneva airport that said something along the lines of "Celebrating the loss of the Titanic". Presumably they meant commemorating but a little more thought mightn't have gone amiss
Scott
Thread: Toolpost grinder tips?
27/02/2015 12:12:28
Hi Jon
Absolutely don't need it in the slightest. Was just messing around with the thing to see if I could get a decent finish
Cheers
Scott
27/02/2015 09:59:32
Thanks Steve. Tried various speeds this morning but not much improvement.
Ian, I was coming to the conclusion that, as you advise, I need a finer grit wheel to get the finish I'm looking for. I did dress the wheel but that didn't make much difference. Trouble is the wheels don't seem to be a particularly common size (80x10x20). The grinder is 250W (input) running at 6000rpm
Scott
26/02/2015 21:12:00
Evening all
Does anyone have any hints and tips for using a toolpost grinder. I've been messing about with a grinder for a mini-lathe but can't get a particularly good finish. The grinder has an 80 grit 80mm wheel. Is 80 grit too coarse for a smooth finish?
The photo is a blank arbor that I've ground first dry all the way along and then the outer 2/3 or so was ground with some lubricant which gave a slightly better finish. The lathe was running at 2500rpm and in the opposite direction to the grinding wheel.
I found a previous thread where Graham Meeks comments have disappeared and it never really came to any conclusion so any additional hints and tips would be welcome.
Cheers
Scott
Thread: Mini Lathe Owners - how do you fix your lathe? Or not?
22/01/2015 22:06:52
Mine is still on the rubber feet too
Thread: Suitable primer for painting aluminium?
02/11/2014 08:54:10
We used to use zinc chromate to prime galvanised handrails on ships. Haven't seen it for years
Thread: I/C crank pins & journals
10/09/2014 19:56:19
Just a quickie Jason - what grit would you go down to?
Cheers
Scott
05/09/2014 14:16:52
Thanks chaps!
Thread: What did you do today? (2014)
05/09/2014 14:14:11
Not using the Super Live app for your CCTV by any chance are you?
03/09/2014 09:18:02
Hello all
Just wondering if anyone has any tips for getting a good finish on crank pins and journals for I/C engines?
Thanks
Scott
Thread: Sieg C3 Chuck run out
22/05/2014 06:35:55
Hi Hopper
I'd be interested to see a pic of this "cloverleaf" plate if you're able to once PB is back up.
Cheers
13/05/2014 09:25:58
Lofty
I don't doubt that the training is far superior in "Grey Funnel Line" but sadly the same can't be said of the commercial side. I agree that there is little need for it on board these days and yes, it's definitely becoming a case of throwing new bits at it or getting a contractor in.
Our company is considering sending newly qualified engineers to a shoreside engineering company for six months hands-on experience of fitting and machining because the training they are given to get them through an MCA Certificate of Competency isn't equipping them for the practical aspects of the job. They're all good at filling in forms on computers though! smiley
13/05/2014 06:38:12
Posted by Bob Brown 1 on 12/05/2014 22:32:28:
Scott,
I have made precision parts on board a ship with the ships lathe, one was a pump shaft about 18" long with several different diameters two for ball bearings and a keyway (cut on the lathe) on one end and an assortment of other things. People on board said it could not be done so just to prove a point....
Fair play to you Bob. I've sailed with a lot of older engineers who used to use the lathe a lot more (screwcutting valve spindles and all sorts) and our lathe is actually reasonably accurate despite the abuse it gets. Unfortunately most of the younger generation of marine engineers these days don't have enough machine shop training and experience to really know what to do with a lathe and it's highly unlikely they would be worrying about the accuracy of the thing. As with most training these days the system is letting them down.
12/05/2014 20:11:03
Posted by Speedy Builder5 on 12/05/2014 19:54:29:
That said, they have lathes on board big ships !! So what do I know.
and trust me, there's absolutely no precision work done on them! smiley
Turning/threading screw-in zinc sacrificial anodes for jacket water systems is about all I see them used for these days. Not much else
11/05/2014 20:43:02
Posted by V8Eng on 11/05/2014 19:32:49:
I fixed up an extra CCTV camera to cover a blind spot on my existing set up.
Me too!
19/04/2014 18:30:44
Had a bit of a mooch around the Engineering Shop in A&P shipyard in Falmouth. Some antiques still in use there!
Thread: How to cope with a disaster
20/03/2014 17:09:09
A Doxford Clive??? That was neither today nor yesterday! wink I've been at sea 30 years and never heard of one that was still going!
Good advice about anchor cables though. Windlasses are designed to have the capacity to lift all of the chain in the locker if it's hanging vertically out of the hawse pipe but by the time they've seen a bit of use it's unlikely they would. Walking the cable out is a recognised technique for trying to influence the drift of a disabled ship in deep water though.
I've heard of ship's running to a more convenient port for repairs with one unit in the engine disabled but never seen it done myself.
Thread: Tool post grinder..... but not for now!
18/03/2014 07:07:22
Danny
Any vibration with yours? And how good is the finish?
Cheers
11/03/2014 10:09:18
Cheers Rik. Dressing it didn't do the trick so I think I'll bin it and get a decent one. It's a real scabby looking thing anyway. All moth-eaten round the edges.
