12 volt motor
ron grimshaw19/01/2014 13:17:26
40 forum posts
Hi
Lets start by saying I am not well up on electrics. I am a member of a air rifle club and have been asked could I make a system for moving the target about from the shooting position to the rear wall, to do this I will need some electrical motor that are reversible and we would like to use 12 volts, my first thought was wiper motors, but I would need instruction on the wiring.
1/ what other motors could I use.
2/ I would need wiring diagram.
Ron
Speedy Builder519/01/2014 13:51:39
2878 forum posts
248 photos
I think I would go for window winder motors (pancake type) easily reversible, doesn't have / need a park position, easy to put a simple pulley wheel onto it, plentifull and easy to get to. Also used in breadmakers.
As for wiring, you would need a microswitch at each end of the run to stop the motor and a fwd / reverse switch as used on the car. Perhaps put a fuse in the circuit for good luck. You may be lucky enough to strip the lot out of a scrap car wiring loom and all. Don't choose newer Renaults as all their electric bits run through a "Habitable unit". This allows thinner wires between switch and sensors and gets a bit complicated. Choose older cars where its all been kept simpler.
BobH
Kevin Bennett19/01/2014 14:02:54
193 forum posts
56 photos
hi a old cordless drill it runs on low voltage as forward and reverse, strip it out and fit in a box mount the motor with it's gearbox.
it is a cheep option and I am sure lots of members have old drills the battery is shot I have 3 in my workshop
ty kevin
JC Uknz 119/01/2014 19:32:01
54 forum posts
I acquired a number of 24 volt DC motors from the salvage/recycling of photocopiers which run well on 12 volt. The older models are better becuase they have less electronics. Lots of wiring in them, too ... a treasure trove for model engineers with rods, belts, cogs and gears galore, not to mention switches too. Unfortunately of less use were the step motors they also had for an electrics illiterate like me
Bazyle19/01/2014 20:04:11
6956 forum posts
229 photos
I know the world has become seriously lazy but couldn't you make a system that involves a person just winding a handle.
jason udall19/01/2014 20:18:18
2032 forum posts
41 photos
Bazyle..my thoughts..didn't like to say it..
But tbh most of the system is the same with or without the motor...pulleys string more pulleys winding gear ..handraulic or otherwise..
stevetee19/01/2014 23:12:50
145 forum posts
14 photos
I think you'll find it's not just Renault.....Just about everything after 2004 has a body systems interface, plc controllers and all that CANBUS stuff.
Michael Gilligan20/01/2014 09:36:56
23121 forum posts
1360 photos
Posted by ron grimshaw on 19/01/2014 13:17:26:
... a system for moving the target about from the shooting position ...
Bazyle / Jason
Wouldn't a mechanical version get rather unwieldly ?
Edited By Michael Gilligan on 20/01/2014 09:37:55
jason udall20/01/2014 09:37:53
2032 forum posts
41 photos
Mmm radio controlled car?
Michael Gilligan20/01/2014 09:38:58
23121 forum posts
1360 photos
Posted by jason udall on 20/01/2014 09:37:53:
Much better
Stub Mandrel20/01/2014 20:11:25
4318 forum posts
291 photos
The original question was the wiring.
Assuming a 12V or similar motor, you need a 2-pole changeover also known as a 2-pole double throw switch (2PDT).
This has six terminals, typically arranged as two rows of three:
1 2 3
4 5 6
A quick check with a multimeter (or a battery, bulb and bit of wire) will show that he effect of the switch is to short the middle pins (2 and 5) to either 1 & 4 or 3 & 6, depending on the direction of the switch toggle.
Connect battery + to 2 and battery - to 5
Connect one side of the motor to 1 and 6
Connect the other side of the motor to 3 and 4
The switch will now act to reverse the motor
An on/off switch in one of the battery leads will provide your on/off facility
If you want a limit switch to stop the motor at each end of its run the then fit one of these between 1 and the motor and the other between 6 and the motor.
Test the limit switches,and if the motor stops when heading away from them reverse the battery connections.
Ian S C22/01/2014 10:41:45
7468 forum posts
230 photos
The switch I made for the electric hoist above my lathe uses 4 micro switches, the hoist uses a 36V garage door opener motor(looks like a wiper motor, but with a sprocket sticking out the side of the gear box), I run it on 18V, mainly because that is the voltage of the workshop low volt supply, lifts my 8" chucks a lot easier than I can.
Ian S C
