Member postings for ron grimshaw
Here is a list of all the postings ron grimshaw has made in our forums. Click on a thread name to jump to the thread.
Thread: What did you do today (2015)
04/05/2015 07:49:04
Accounts all day such fun.
Thread: Field canon plans
03/04/2015 19:11:25
Lots of Civil War stuff if you look.
Hi Vic Thanks for quick response, Like what I see may try on of them ?.
03/04/2015 19:09:41
There's at least one book out there
Hi Ady1 Thanks for quick response, Not sure what era the book covers.
03/04/2015 19:06:34
What sort of period are you looking at - there is a huge difference between a 1940 field gun1940 and a 1490 cannon...
Hi Neil Thanks for your quick response,I was thinking of something from the first world war.
03/04/2015 12:57:56
Hi all I would like to make a model of any field canon, can any one give me any idea where best to get plans from that give has much info as possible as I am new to working from plans.
13/02/2015 17:23:21
Just stop cursing, broke my 3 jew Pratt chuck.
Thread: What did you Get Today
26/12/2014 22:01:16
stomach ache
Thread: 12 volt motor
19/01/2014 13:17:26
Hi
Lets start by saying I am not well up on electrics. I am a member of a air rifle club and have been asked could I make a system for moving the target about from the shooting position to the rear wall, to do this I will need some electrical motor that are reversible and we would like to use 12 volts, my first thought was wiper motors, but I would need instruction on the wiring.
1/ what other motors could I use.
2/ I would need wiring diagram.
Ron
Thread: Motor for Lathe
09/11/2013 16:21:29
Thanks for the info, Sorry for being a pest but (a little but) The info on the motor does not tell me the house power, the only info is
230 Volt, 50/60HZ, 4800RPM, 180 Volts.
Do you know if this is big enough. I have all the control off the treadmill with speed controls. I thought that I could use them just need to build box to fit them in.
The only other thing I would need some kind of rev counter.
Ron.
03/11/2013 21:02:03
Hi all,
I have a Myford SL7 Lathe and was thinking that I would like to fit variable drive motor. I have a treadmill that I no long use which as a variable drive motor and controls. I would have to make up boxes to fit controls and find a way of fitting the motor. My question is the motor is not 3 phase so what will it be and will I be able to make it work, what size should it be to drive the lathe.
Ron
Thread: 240/415 motor
14/07/2013 20:37:08
Thanks for that quick response
Ron
14/07/2013 20:15:19
Hi all
I have just been given a chop saw from a window frame company that as run on 3 phase the motor is a asincrono 1.5hp it state that its 240/415, does this mean that it can be run on single phase with just some wiring change.
I have no knowledge in electrics when it comes to motors, Would I need to get a convertor and if so which one and from where.
Ron
Thread: Myford tread cutting
15/04/2013 10:36:55
Hi all, I have a myford S7 with gearbox, which I used to cut imp theards what I would like to do is metric theards, could someone enlighten me on how to do this, do I need complete gear change or is there a single gear that would change the way the gearbox worked and if so how would would I know what pitch I was turning without having to cut test runs. By the way I am new to the world of lathes.
Ron
Thread: Tapping guide
14/04/2013 20:11:10
Hi try this site in utube Halligan142
Thread: How much gear do you need to start Model Engineering ????
26/02/2013 14:17:35
Ps whats cad.
26/02/2013 14:15:42
Paul which some one had told me that before I started. I now have most tools I believe I need then see something else. Got to have it no idea what it does. but then again will fit in with all my other tools well.
Thread: Which mag
16/01/2013 09:04:01
Is it worth getting both ME & MEW if not which one, I will be building static engines and I am vary new to Lathes and milling machines. I have a Myford S7 and a Warco turrit mill which I have just bought and need help in getting into using them.
Thread: drill sets
05/01/2013 20:48:51
I have always bought drills as needed for general use, Now I am getting into model making I thought it was time to buy a set of quality drill bits, looking round I thought dormer looked good but price seemed to vary a lot and some discreptions stated jobber drill ?. I was looking to get a AF set in 64ths increments.
What should I be looking for and where is the best place to buy.
Edited By ron grimshaw on 05/01/2013 20:59:09
Thread: Stuart water pump
04/01/2013 20:59:36
I have just become the owner of a stuart water pump in need of help. it has a broken shaft were the pully should be I think, I am looking for drawing. the pump as a Number on the casting 451994.
Thread: Speed control
30/12/2012 14:58:19
I would like to fit a speed control to Warco Turrit miii, It has a single phase motor fitted, if this can be done, using what and best to buy and how easy
Do I have to fit 3 phase motor.
