JasonB | 12/01/2014 16:20:42 |
![]() 25215 forum posts 3105 photos 1 articles | For a bit of Sunday afternoon fun as you may have seen in the "What did you do" thread I have been machining the cylinder liner for the ball hopper Monitor. This is supplied as a cored casting approx 2.75dia x 7" long with approx 1.25" core. This is the finished item, 1.808" average OD, 1.625" ID and 5.25" long
So who wants to take a stab at what percentage ended up as swarf? and for a bonus point the initial and final weights. No prizes except the fact everyone will think you are a know it all J |
Andrew Johnston | 12/01/2014 16:43:06 |
![]() 7061 forum posts 719 photos | I guess as follows: Weight of original casting - 3.8265kg Weight of final liner - 0.3005kg Percentage of original casting, by weight, into swarf - 92.15% Andrew |
Stub Mandrel | 12/01/2014 17:17:34 |
![]() 4318 forum posts 291 photos 1 articles | I guess 3.8 kg and 0.3kg. Percentage 92.1% * I think I'd have bought a bit of pipe and kept the casting in the useful pile Neil *OK I'm cheating - Andrew won't be spot on, and my guess is he's a bit high. If I use values very close to Andrew's and just a teensy bit lower, I have a good chance of being correct.** **I could never understand why contestants didn't use this strategy on the 'The Price is Right'.
blowlamp | 12/01/2014 17:47:25 |
![]() 1885 forum posts 111 photos | For 'typical' cast iron, I get it at 3.905kg for the starting weight and 0.307kg finished weight. Swarf is -92.138 EDIT. I'm cheating too - my result is straight out of ViaCAD Martin Edited By blowlamp on 12/01/2014 17:59:37 |
John Stevenson | 12/01/2014 18:05:34 |
![]() 5068 forum posts 3 photos | Well I get different figures. I get heavy, light and a lot.
It always amazes me that the swarf off a job is more than not more than the material you started out with.
Recently I made some unions out of some 2 1/4" hex brass bar, it came as a 3.1 metre long bar and the first job was to cut it into 50 pieces on the saw, that generated an ice cream tun full of chips. next job was to drill a 27mm hole thru each piece. That generated this.
That's one of those big bags of dog food and in this case it weighed 33kg.
The final operation, turning and threading generated another 22 kg in another bag. |
websnail | 12/01/2014 19:10:22 |
62 forum posts | Just be thankful it's not 100% |
David Colwill | 12/01/2014 19:27:53 |
782 forum posts 40 photos | Plastics seem to produce more weight in swarf than the original bar. I am thinking of farming Nylon for a living! David |
Chris Gunn | 12/01/2014 20:26:06 |
459 forum posts 28 photos | John, look on the bright side, that swarf will be worth about £140 CG |
Stub Mandrel | 12/01/2014 20:27:00 |
![]() 4318 forum posts 291 photos 1 articles | Nylon is hygroscopic, it's possible that it could pick up more water from humidity in the air air when freshly machined swarf from the drier inside of a bar is released. Do an experiment and write up a scientific paper - you could win an ig-nobel prize! Neil |
JasonB | 13/01/2014 18:56:42 |
![]() 25215 forum posts 3105 photos 1 articles | Three entries and three different winners. Percentage was 92.3% so Andrew was closest with 92.15% Weight of original was 3870g so Blowlamp was closest with 3905g Final weight was 298g so so Neil was closest with 300g. Neil it would have been better if they just supplied a length of 50mm CI bar plus it would have been nicer iron as this was quite grainy and hard. J |
Stub Mandrel | 13/01/2014 19:00:12 |
![]() 4318 forum posts 291 photos 1 articles | I'll settle for 1 out of 3 given that the only maths I did was comparing magnitudes
Neil |
jason udall | 13/01/2014 19:36:29 |
2032 forum posts 41 photos | Neil..as to techniques on price is right...the sort of people to enter that are the sort to watch it..neither would be accused of being analytical |
JasonB | 13/01/2014 19:40:53 |
![]() 25215 forum posts 3105 photos 1 articles | I think Neil's tactics would be more suited to Play Your Cards Right - Higher, Lower, Lower...... |
