Tom senior light vertical milling machinr
ian j01/10/2013 20:53:25
337 forum posts
371 photos
I have the chance to buy a 1973 ex school Tom senior light vertical milling machine for approx £750. It's a metric 3 phase machine. with the S type head, I would have preferred imperial but I could fit a DRO to it. It appears to be in excellent condition with no damage to the table or back lash to the feed screws.
What is the general opinion on the £750 price?
Does any one know what the foot print is?
Thank You.
Ian
Andrew Moyes 101/10/2013 22:56:02
158 forum posts
22 photos
Ian, I have a Senior light vertical, metric, 3 phase ex-school machine from about 1976. It's an excellent machine. Condition is everything, I fully restored mine to as-new condition. If it's in decent condition, £750 seems very fair.
If you fit a DRO it won't matter that it's a metric machine. Curiously, while the X and Y feeds are metric, the Z feed is imperial on mine. Having a 3 phase motor is an advantage if it's dual 230/400 volt as it means you can fit a variable speed drive without having to buy a new motor if your supply is single phase.
The footprint of mine is 28" deep x 21" wide. The drip tray overhang increases that to 38" deep x 28" wide.
Andrew M
Edited By Andrew Moyes 1 on 01/10/2013 23:01:36
ronan walsh02/10/2013 02:19:35
546 forum posts
32 photos
I think the tom seniors are very well made machines and a nice size for home workshop use. Just one point i wanted to make about the footprint of these machines, the suds tray is often quite a bit larger than the area of the base, i was able to cut the back off the tray on mine and tig weld a piece of flat steel on the back. This allowed me to push the machine back a bit further against the wall to save space.
ian j02/10/2013 21:17:46
337 forum posts
371 photos
Thanks for the replies. I will have a closer inspection of the machine & if all appears o/k I will but it.
Andrew. You say you completely restored yours, is it fairly straight forward to dismantle? The reason I ask is because I only have 28" between the outside corner of the house & outside corner of the workshop so will have to partially dismantle the mill.
Ronan. After you reduced the size of the tray what is the front to rear dimension approx.
Thank you
Ian
Andrew Moyes 103/10/2013 09:01:45
158 forum posts
22 photos
Taking it apart was straight forward with standard tools except for the quill, for which I had to make a few special tools. Once you have disconnected the electrics and coolant pipes, the head slides out on its shaft as a complete unit. The table, saddle and knee come off. The column is very heavy and I needed a hand with that. Four screws release the drip tray to reveal the sump. Be prepared for a disgusting sight if it's like mine. I have tried to post some photos but for some reason they won't upload into an album.
David Clark 103/10/2013 09:19:12
3357 forum posts
112 photos
10 articles
Hi There
I would snap their hand off at £750.
I paid £1350 for mine.
Brilliant machine but you will probably need 3 of you to lift the column.
It is solid.
I have a complete set of photographs of how I fitted a DRO to mine.
The 3 phase is not a problem, the inverter is easy to fit and makes the motor virtually silent in use.
Easy to strip down and reasemble, just very heavy.
regards David
Andrew Moyes 103/10/2013 09:50:00
158 forum posts
22 photos
I agree with David that the price is good.
The original Brook Crompton Parkinson motor on my 1976 machine was 415v only. Standard inverters for a 230v single phase input give a 230v three phase output. You can get 230v single phase to 415v three phase inverters but they are not so common and are expensive. So I fitted a new TEC, flange mounted, 0.55kW dual voltage motor.
Russell Eberhardt03/10/2013 10:01:43
2785 forum posts
87 photos
Go for it quick before someone else snaps it up. Beats any Chinese machine for the same price.
Russell.
Andrew Moyes 103/10/2013 18:16:43
158 forum posts
22 photos
I have posted some photos into an album showing the machine disassembled.
dcosta03/10/2013 19:10:25
496 forum posts
207 photos
Hello Andrew. Good afternoon.
See your pictures of the Tom Senior.
Beautiful work on a very nice milling machine. I envy you...
Best regards
Dias Costa
Boiler Bri04/10/2013 07:45:53
856 forum posts
212 photos
Hello ian. If you need an invertor I have some slightly used ones. Cheep.
ian j06/10/2013 19:24:05
337 forum posts
371 photos
Hi all.
Thank you for your replies & advice.
I've had a proper look at the machine this morning & bought it, Spent the rest of the day partially dismantling it & transporting it home ( only 5 miles from where it was located) on my mates pick up. Yes it is heavy even when reduced to big lumps. I don't think I will be going for a total repaint just a good clean & then reassemble it. I'm sure I will be back with more questions.
First question !
It's fitted with a Clarkson collet chuck held in with a draw bar, To release the chuck do you unscrew the draw bar a few threads & tap/hit/belt it with a hammer. I've put some penetrating oil down & will leave it over night.
Off now for a hot bath to ease my back !!
Thanks again.
Ian
Andrew Moyes 106/10/2013 20:56:22
158 forum posts
22 photos
Ian - I'm pleased to hear you got it. My Clarkson Autolock collet chuck has a 'damping ring' that is backed up against the spindle in use to increase rigidity. You should be able to use it to extract the chuck using a tommy bar on the chuck and spanner on the spindle nose. Mine was well and truly stuck when I got the machine so I had to use some additional persuasion with a lead hammer as you describe. Not ideal but I planned to replace the bearings anyway. Eventually it came off. Make sure the down feed worm is disengaged first so you don't damage it.
Dias - thanks for your generous comments.
Andrew M
ian j06/10/2013 22:43:34
337 forum posts
371 photos
Andrew.
just had a look & yes my chuck has the "damping ring" will give it a try tomorrow ( to tired now!!) thanks for the advice about disengaging the down feed.
I will post some photos's when reassembled.
Ian
Dunc07/10/2013 00:24:46
139 forum posts
I think our Editor posted a how to use the Clarkson Autocollet chuck in a past issue of MEW. Worth a look at an index?
And a very nice find. I recall many articles on Tom Senior equipment and the high praise for the build quality.
ronan walsh07/10/2013 01:46:54
546 forum posts
32 photos
Ian here is a link to the Tom Senior manual on the Denford website. Don't know if you found it yourself.
ian j07/10/2013 09:09:03
337 forum posts
371 photos
Good morning.
Prepared for a battle to remove the chuck, a selection of various sized hammers at the ready !! but one sharp hit with average sized hammer did the job. It can only go down hill now for the rest of the day.
Andrew, where did you get your levelling feet from ?
Ian
Andrew Moyes 107/10/2013 17:56:22
158 forum posts
22 photos
Ian – I didn’t keep a note of the exact supplier but these would do: -
http://www.antivibrationcomponents.co.uk/en/catalog/mounts/machine-mounts/steel-machine-mounts/p2150
Mine were M12 studs x 90mm diameter. It’s worth the expense while the machine’s apart and the base is not too heavy to lift. As well as giving a solid base, it means you can easily set the table truly level in both planes to a precision spirit level. You can quickly set a workpiece level in the same way in the knowledge that it will be parallel to the table. A lot easier than clocking with a DTI in my opinion.
Andrew M
ian j07/10/2013 23:58:38
337 forum posts
371 photos
Brian.
I may take you up on cheep inverters. I've sent you a PM.
Ian
ian j09/10/2013 19:17:30
337 forum posts
371 photos
David C.
You say you have photo's of how you fitted a DRO to your mill, is it possible for you to put them in your album or should I PM you with my email address? Which scales did you use? I have a Sino SDS6-2V console which I bought at Chester's machine tools open day earlier in the year, It was labelled " X axis faulty Y axis working" when I opened it up it's all surface mount components so I thought no chance of me getting it working. When I was checking the continuity of the ribbon cables from the D type connector on the rear to the Molex PCB header I noticed that the 0 volts pin was displaced. when I refitted it into the Molex header the continuity was o/k. I Took it round to my mates to try it using his reading scales and it worked!!
I will be going to the Midland show next week so maybe I can get a good deal on some scales there.
Regards Ian
