Turning an Elmers #25 crank disk
Jerry Cashman20/08/2013 05:10:29
21 forum posts
Hi guys,
I'm trying to plan the machining operations for an Elmers 25 wobbler.
The crank disk is a bit of mild steel, a bit less than an inch across. To make this, I have a length of steel bar the right thickness - I plan to mark it up, cut off a square length the right size - drill the crank-shaft hold in the middle, then mount it on an arbour and turn it down.
The bit I'm not sure of is if this will work :^)
What I will end up with is a square shape that I've got to knock the corners off to turn it round - but the mounting will be an bolt on an arbour held in a collet. I'm pretty sure this will spin in the arbour rather than cut as the tool hits the corners of the work piece...
Never having used (or made) an arbour before I've no idea how securely it will grip the work piece...
Is there a better way of making this piece that doesn't involve buying more material (round BMS rod of the right thickness)? (or am I making a problem for myself that $10 will solve
cheers. Jerry
JasonB20/08/2013 07:29:04
Use a bit of your square bar say 1.5" long, hold in your 4 jaw chuck and just turn it down to 11/16" dia, face the end and bore.
Take the 4-jaw off the lathe with the bar still in it and fix to the mill table to machine the shape and drill crankpin hole
Back to the lathe and part off
Edited By JasonB on 20/08/2013 07:31:14
Jerry Cashman20/08/2013 07:34:18
21 forum posts
Thanks Jason - yep, if I had square bar that's what I'd do... but I've got rectangular bar, the thckness of the crank disk and width enough to get 11/16th out of it...
Should I just put that back in the spares bin and go buy some rod?
Russell Eberhardt20/08/2013 07:49:14
2785 forum posts
87 photos
I would do as Jason suggests but start with 3/4 in dia round bar and use the three jaw chuck. Much quicker than starting with your rectangular bar and much less waste.
Russell.
JasonB20/08/2013 08:27:52
Whats the exact dimensions of your bit of bar.
Russel he is trying not to buy round bar but use whats to hand, we just need a better idea of what Jerry has. Sounds like a bit of 5/32 (or 4mm) flat stock or sheet
Jerry Cashman20/08/2013 08:32:31
21 forum posts
Yep, that's it, 5/32 flat (rectangular) bar...
but it sounds like I'm creating more work for myself - a bit of 3/4" BMS rod won't break the bank...
thanks guys
jason udall20/08/2013 09:16:05
2032 forum posts
41 photos
If you do intend to round up a square. .do youself a favour and start with an octogon
Stub Mandrel20/08/2013 20:08:06
4318 forum posts
291 photos
If you have a 4-jaw, you can holds a rectangular bit in it as easily as a square bar. But any bit of scrap bar will do for this sort of job. I've used old mooring pin, but my 'best' ones are made from some lovely free-cutting but medium carbon hex.
JasonB20/08/2013 20:31:36
Given the small dia of the part you should not have a problem with your method of drilling (preferably reaming) the 5/32" hole and then mounting on an arbor.
To make the arbor chuck a bit of say 3/8" (10mm) bar and turn down 1/2" of that to a good fit in your 5/32" hole, thread most of its length, M4 will do nicely and then you can slip your roughed out disc onto the arbor followed by a washer and nut and away you go.
Don't take massive cuts.
Edited By JasonB on 20/08/2013 20:32:22
clivel21/08/2013 07:09:28
344 forum posts
17 photos
I built an Elmer's 25 as a first project. Trying to make it as simple as possible I opted for a plain crank disc without the notches.
For the disc I used a 3/4" round bar. Chucked in the 3 jaw it was faced, centre drilled and then drilled the correct diameter for the crank shaft (deeper than the disc thickness). After turning to diameter the bar was removed and a slice cut by hand with a hacksaw. The crank shaft was fitted to this slice with a drop of loctite and then left to set for 24 hours.
I then proceeded to grasp the crankshaft in a collet chuck so that the disc could be faced to the correct thickness, thus ensuring that the crank-pin disc face and the shaft are perpendicular.
My original description if it is any help : Elmer's 25 crankshaft
Jerry Cashman21/08/2013 08:14:22
21 forum posts
Thanks very much Clive, and thanks for taking the time to document your build - I've already read it through several times and it's provided a great deal of confidence! Much appreciated
cheers. Jerry
