Frank | 22/05/2013 16:11:43 |
13 forum posts | Reached a cross roads in my Budget planning for my new workshop. Given that I've got £1,000 to spend on machinery, I'm undecided between buying a lathe and milling machine or spend the lot just on a lathe? Bearing in mind that I'm a complete beginner and that I want to have a go at small engines/models, I assumed that buying a lathe and mill would be the way to go. However, based on User recommendations, I do like the look of the Sieg C4 lathe (which blows the budget on its own). I would like the lathe to have powered feeds, which I'm not sure the Chester Conquest lathe has got. Opinions/advice please? |
SteveW | 22/05/2013 17:26:13 |
![]() 140 forum posts 11 photos | Spend it on a lathe a bit bigger than you think you need, keep a little to buy any tooling, taps etc (say £150) and start saving for a mill. Steve W |
JasonB | 22/05/2013 17:31:41 |
![]() 25215 forum posts 3105 photos 1 articles | If you do go for just a lathe then make sure you can fit a vertical slide to it as this will allow you to use the lathe for light milling operations, Even if there is not a specific one for your chosen machine it is often possible to fit a decent Myford one, thats how I built the traction engine in my avitar - Emco lathe and Myford slide. Most of the small lathes are likely to have a powered longditudinal feed but its not until you get to something around the size of the Warco 250VF that you will get power cross feed. J |
GaryM | 22/05/2013 20:46:22 |
![]() 314 forum posts 44 photos | Frank, Arc Eurotrade have a special offer on the C6 at the moment including some of the accessories you'll inevitably need: Gary Edited By Gary Marland on 22/05/2013 20:47:21 |
Bazyle | 23/05/2013 00:52:54 |
![]() 6956 forum posts 229 photos | All the imports come with those accessories these days. It's like electric windows on cars. I think I'd prefer an AUD for that money. Accedemic anyway as Frank should have stapled his wallet shut for 3 months while he learns more. |
Ady1 | 23/05/2013 01:42:23 |
![]() 6137 forum posts 893 photos | Save yourself a HUGE amount of cash and hold out for a Drummond M series Then munch lots of metal and have 800 quid for all the other bits you'll need Try and get one with a 3 and 4 jaw chucks
Edited By Ady1 on 23/05/2013 01:55:22 |
Durhambuilder | 23/05/2013 09:15:35 |
77 forum posts 5 photos | this doesn't appear to be a bad buy, the basic lathe without accessories is nearly £3k new, with the stand and accesories probably nearer £4k worth.... http://www.lathes.co.uk/advertphoto/130410ceriani/ or for a little extra work and searching for the missing bits, an emco compact 10. http://www.thetoolbox.org.uk/late_arrivals/metalworking2.html Edited By Durhambuilder on 23/05/2013 09:21:38 |
Robbo | 24/05/2013 09:50:44 |
1504 forum posts 142 photos | There's an Emco Compact 8 advertised on homeworkshop.org.uk which may suit. Price £450 Contact John on 07847 621456, but be quick. Located in Walsall, so not far away Phil Edited By Robbo on 24/05/2013 09:51:27 |
