tony bastick | 15/04/2013 19:55:02 |
15 forum posts | Hi all, im making a new lathe chuck key from silver steel, im ok with the hardening but would welcome advice on the temperature that it should be tempered at. Thanks Tony |
Stub Mandrel | 15/04/2013 20:01:23 |
![]() 4318 forum posts 291 photos 1 articles | Hi Tony, As it's going to be subject to a lot of torque and will be dropped regularly(!) and it doesn't need any cutting attributes, I'd take it right down to blue. Neil |
Gary Wooding | 16/04/2013 09:11:03 |
1074 forum posts 290 photos | I've just made one, but I used ordinary mild steel and case hardened the business end, which is now glass hard. Cheaper than silver steel too.
Gary |
mark mc | 16/04/2013 16:03:02 |
92 forum posts 16 photos | I made one awhile back for my four jaw chuck so i could move two jaws at a time, never hardened it at all, just mild steel, works grand. Should i have hardened it? Edited By mark mc on 16/04/2013 16:03:24 |
Jo | 16/04/2013 16:51:31 |
198 forum posts | I have made numerous for mine out of mild steel and never hardened any. I would prefer to bend the key rather than the chuck. Jo |
Michael Gilligan | 16/04/2013 19:54:27 |
![]() 23121 forum posts 1360 photos | I cheated when I made one for a 4" Burnered 4-Jaw The square on the end of an old HSS Tap was just the right size. ... so I drilled & tapped the end of a mild steel rod for the body, and Loctited the tap in place. MichaelG. |
Ian P | 16/04/2013 20:42:57 |
![]() 2747 forum posts 123 photos | Michael Your chuck key worries me! In my experience, HSS taps are specially designed to break. When they do they leave jagged shards of steel that could injure you. Ian P
Michael Gilligan | 16/04/2013 20:56:39 |
![]() 23121 forum posts 1360 photos | Ian, No worries here ... The full diameter of the Tap Shank is counterbored into the body, and Loctited. [and, by the way, there is no reduced diameter "neck" on this particular tap] MichaelG. . Edited By Michael Gilligan on 16/04/2013 20:58:32 Edited By Michael Gilligan on 16/04/2013 21:12:07 |
John McNamara | 17/04/2013 07:30:12 |
![]() 1377 forum posts 133 photos | Hi Tony Bastic A while back I needed a key and all I could find at the time was a longish 12.5mm Hex cap screw. I cut of the head and ground four flats on the end. Then brazed the other end to a piece to mild steel to make a handle. (With key end protected in wet rag to stop the brazing heat affecting the temper). It lasted for at least ten years..... well at least until I sold my old flat belt change gear Colechester. Good quality cap screw steel is tough. and you don't have to harden it. It also machines rather nicely. Cheers John
