Member postings for tony bastick
Here is a list of all the postings tony bastick has made in our forums. Click on a thread name to jump to the thread.
Thread: STAR DRILLING MACHINE, AKRON,OHIO,USA
13/05/2013 14:08:25
Hi, On a recent visit to South Africa I came across a couple of derilict steam powered drilling machine by the above company and thought what a wonderful model one of these would make. My question is ,does anyone know of the existance of any drawings for one of these engins in any scale or even full size.While i have the skills to build the model, i dont have the time or inclination to scale up from the photos that i took at the time so any info would be most welcoM. Thanks Tony.
Thread: new chuck key
15/04/2013 19:55:02
Hi all, im making a new lathe chuck key from silver steel, im ok with the hardening but would welcome advice on the temperature that it should be tempered at. Thanks Tony
Thread: small counterbores
14/04/2013 13:06:33
Hi again, should have said that they are for metal cutting not wood.Tony
14/04/2013 12:54:57
Hi all, does anybody know where you can get good quality (not cheap far easten rubbish) small counterbores in BA sizes, i know you could get them years ago but not seen any recently.Thanks Tony
Thread: setting up a vertical head
12/12/2012 22:22:39
Thanks all for your helpfull tips, but Nobby the Senior Mill has no quill or machined surface on the head.Thony
11/12/2012 21:58:46
I have a Senior M1 milling mc with a std vertical head and when set up to the markinge scribed on the mc it does not cut square to the table but is about 1/2 a degree out of plum. Does anyone know of a quick way to set up a vertical head accuratly?
Thread: Stuart Turner 10 Castings
30/08/2012 12:19:17
Hi you may be interested to know that the new STUART business is up and running, i have just bought some castings for a couple of referb projects and had a chat to them on the phone. It seem their long term plan is to progresively re introduce some of the engines that were discontinued and build up the stocks of depleated castings in fact i think the SIRUS is now available again as a set of castings .So good new all round.
STUART MODELS
GROVE WORKS, WEST ROAD, BRIDPORT, DORSET, DT6 5JT
01308 456859
Thread: I Think I Know Why Some Stuart Engines Don't Carry The "S"
30/08/2012 11:36:38
I have two No 4 engines one with reverse one without and both have the S cast in ?
Thread: Centreing a rotery table
12/08/2012 09:48:54
Hi all, thanks for all your tips, I now can choose a quick set up for a less acurate job or take a bit more time to get it spot on .Thanks again its easy when you know how.
11/08/2012 21:27:49
Hi all,what is the simplest way to centre a 3 jaw chuck mounted on a rotery table under a vertical milling head.Thanks Tony
Thread: three sided tool post
13/07/2012 22:54:31
Hi, thanks for your info guys, looks like it may have to be the diy holder but a quick change version is what i was realy looking for .Im surprised that the far eastern suppliers have not come up with one yet. I have a couple of extended holders but they do tend to chatter on average cuts due to the overhang.
13/07/2012 14:03:11
Hi does anybody know if and where i can get a triangular three position quick change tool post of a size to fit a myford I have a square one but its always in the way of the tailstock when doing small bits of work and it seems to me that a triangular one would be a much better design as it gives alot more clearance Thanks Tony
Thread: Tom Senior M1 Vertical Head unit
08/07/2012 23:49:50
Hi, guys thanks for your help, one further question, does anyone have the bearing codes for the two ball races or their sizes so i can get them prior to the strip down and save a bit of down time. Thanks Tony
08/07/2012 15:47:40
Hi, just been reading these threads as i was about to do an overhaul on my vert head to replace the bearings. Do i understand from the coments so far that we have a ball berring at the top and a thrust bearing on the vertical driven shaft? Also what is precession? Thanks Tony.
Thread: Bodmer’s Sliding Cylinder Engine
29/04/2012 23:00:15
Hi,iv just started the restoration and overhall on one of these engines, does anybody know how to set the valve timing? Tony
