How to get started with CAD/CAM for machining and engraving?
A newbie's plea for help
Dave Sawdon 108/04/2013 19:29:17
49 forum posts
4 photos
I've had a CNC mill (Denford Starmill) and Mach3 for quite a while but not had the time to do anything with them. Now, at last, I've got the time!
Most of what I want to do will be what I think is called 2.5D but I also want to be able to engrave surfaces with lettering and with patterns - what CAD/CAM software would people recommend? It looks as if Vectris vcarve might do the job but it's not cheap and I wonder if there is a cheaper solution, maybe draftsight, plus <what?> for CAM?
blowlamp08/04/2013 22:34:00
1885 forum posts
111 photos
CamBam is unbeatable for the money. Vectric VCarve is excellent for engraving text and other fairly shallow shapes, but seems to be aimed at the woodworking/signmaking market.
I use ViaCAD and MoI for drawing and CamBam for CAM work - I also have Ucancam which I use for VCarving and other bits and bobs that I sometimes do.
I think ViaCAD and CamBam would cover most things for you, including quite complex 3D work.
Martin.
GoCreate09/04/2013 00:02:35
387 forum posts
119 photos
Hi Dave
For cad I use Draftsight and Creo Ellements both free.
For Cam I use Vectric Cut 2d and for 3d Meshcam both easy to use and very low cost.
This website might be of interest
I have not used them yet but Micropath and Microcarve may be useful.
These were done using Vectric 2D.
Allchin hub with correct engraving\
Allchin hose brackets
Nigel
Edited By tractionengine42 on 09/04/2013 00:10:53
John Stevenson09/04/2013 00:18:57
5068 forum posts
Although this was cut on a laser all the artwork was done in VCarve pro ut it could have been done in Cut 2D
Dave Sawdon 109/04/2013 01:35:06
49 forum posts
4 photos
Thanks everyone - very interesting. I've been having a play with draftsight (looks amazing) but I hadn't realised that Cut2D would do that sort of work. I'll investigate the other packages that have been suggested.
Here are some examples of the things I want to machine and engrave (once I've managed to do a more simple S-shaped crank handle):
The top one is brass. The lettered area slopes back at about 10 degrees and the body has 3 horizontal tabs out of the back which are drilled to allow 10 square-topped leadscrews to operate on the lugs that you can see in the slots
The lower one is brass or bronze
Will draftsight and cut2D allow me to do these or would I need something like vcarve?
GoCreate09/04/2013 07:09:13
387 forum posts
119 photos
Hi Dave
I am no expert but for that type of work I think Martin has put you on the right track with Cambam, I am sure he will give you his comments. I have not used it so I am not qualified to recommend it.
Vectric 2D cut would not be suitable, my work is very much more mechanical than artistic. Vector 2D is good for profiling shapes, pocketing, drilling and engraving.
VCarve pro does look great but as you say pricey for hobby use.
I would be interested to hear what you finally decide and how you get on.
Nigel
Edited By tractionengine42 on 09/04/2013 07:10:52
Russell Eberhardt09/04/2013 08:14:10
2785 forum posts
87 photos
If you are looking for cheap engraving software have a look at F-Engrave. It comes free and does straightforward engraving plus a certain amount of V-carving.
For converting your draftsight files to GCode there is DXF2GCODE again free.
There are a lot of free CAD/CAM programs out there if you search. If you get into full 3D there is PyCAM as well.
Russell.
John Stevenson09/04/2013 08:57:38
5068 forum posts
Those examples you posted have 3D profiles on them, they are not flat.
Cut 2D or VCarve pro only works in 2.5D. Aspire, the flagship model will do these but if you think VCP is expensive then this is out of your range.
Unfortunately the more features you need the more expensive it is.
Perhaps Cambam is the answer I don't know, I do have a copy but to be honest I have never used it.
There are a few free / cheap 3D programs out there, many based on Linux as it's a free OS but from experience these usually have a very steep learning curve or are an unsupported work in progress.
Many of the ones I have looked at I have not managed to get working due to lack of documentation / tutorials or support.
Ennech09/04/2013 09:08:38
153 forum posts
143 photos
I use Sheetcam for 21/2 D work
Russell Eberhardt09/04/2013 10:48:13
2785 forum posts
87 photos
Posted by John Stevenson on 09/04/2013 08:57:38:
The three examples I mentioned are written in Python and thus work in both Linux and Windows. I agree that for a professional user there are better, paid programs but for the hobbyist who can't justify the expense these work well. Support is generally available either in forums (fora?) or directly from the authors.
Russell.
Edited By Russell Eberhardt on 09/04/2013 10:48:48
GoCreate09/04/2013 11:00:42
387 forum posts
119 photos
Hi
Meshcam may be worth a look, allot depends upon what cad formats you have available to put into your cam. Mesh can (and others) can create some 3d profiles from jpg images but I have not done this myself.
It's probably worth using free trial periods to try out different packages.
Nigel
Another JohnS09/04/2013 12:50:08
842 forum posts
56 photos
Here's two links from the LinuxCNC mailing list:
I'm just a (very) happy user of LinuxCNC. You can also have a peek at my blog: http://cnc-for-model-engineers.blogspot.com
Just start doing *something* with it every day, (like turning it on!) and before you know it, it will make more and more sense.
Another JohnS
Stub Mandrel09/04/2013 20:05:45
4318 forum posts
291 photos
More musicalia! Is that a late lute of some sort?
Dave Sawdon 109/04/2013 21:27:42
49 forum posts
4 photos
Thanks again for all the ideas - they've given me lots of homework.
JohnS:
would I be able to use Cut2D for the part shown in the first photo if I machined the front face (slots and engraving) then put it on a sine plate at 10 degrees to machine the angled face?
Neil: it's a type of 18thC Cittern known as an "English Guittar"
The rose shown in the second photo is a casting but I was hoping to find a way to machine them. Some 18thC luthiers made star roses from bone, ebony and box so that's my fallback if I can't find a way to copy the one in the picture.
John Stevenson10/04/2013 10:13:09
5068 forum posts
Dave,
Yes Cut 2D would do that but it justs engraves the letters.
Where VCP differes is that it can do vee carving, what this does is it uses a vee shaped engraving cutter with a tiny flat on the end. and cuts out as normal until it gets to the outer edge and then when it gets to a corner it automatically raises the tool until it reaches the corner then lowers it.
Even thought it's machines like a hill top with two valleys you only see the sharp corner, In Cut2D, Sheetcam and Cambam you will get the radius of the cutter showing in the corner.
Not the best picture in the world, zooming in hasn't helped but if you look at the W's and Y's you can seee a crisp serif.
I may have a cost effective viable alternative but need to check. Probably post later tonight.
Dave Sawdon 110/04/2013 20:34:17
49 forum posts
4 photos
In my ignorance I'd assumed that any engraving software would be able to replicate the hand-engraved look in my top picture (above) but now I understand the need for something a little more sophisticated. So much to learn - so little time!
blowlamp10/04/2013 21:56:39
1885 forum posts
111 photos
Dave.
My first choice for affordable and virtually bullet-proof CAM software is CamBam, and although it is able to engrave lines and curves in 3d for vcarving - provided you can supply such things, it isn't (at the moment) able to generate those curves itself. So with that in mind, as well as your rather specific needs, Ucancam might be a cheaper alternative to one of the Vectric products if engraving and vcarving is your main interest and can be bought on Ebay for around £140.
Ucancam can be a little quirky (chinese author smiley), but once learned can be very productive and is good to use.
Ucancam
If you want some simple(ish) CamBam or Ucancam g-code of something to machine, then just let me know.
Martin.
Edited By blowlamp on 10/04/2013 22:01:21
Edited By blowlamp on 10/04/2013 22:09:33
Bazyle10/04/2013 23:38:46
6956 forum posts
229 photos
I'm not into CNC but happened to read this recently.
The point being that the thread starter tries several bits of software and finds different results.
Russell Eberhardt11/04/2013 11:22:39
2785 forum posts
87 photos
Whether you spend your hard earned cash on commercial software or use some of the many free programs I think it's important first to learn Gcode and try hand coding a few simple parts. That way, if the CAM software doesn't do exactly what you expect you can correct the code.
Also hand coding can produce much shorter code than CAM programs if you make good use of subroutines - useful if you're using the evaluation version of Mach3.
Russell.
Stub Mandrel11/04/2013 12:19:05
4318 forum posts
291 photos
Dave,
Another option for you could be photo-etching, followed by hand piercing of the holes and some handwork to tidy up.
