squeak, squeal and chatter
Lloyd Bowers25/02/2013 09:03:15
49 forum posts
Am i right in thinking these are general the same thing first, squeak/squeal is chattering? or are they different,
Im getting a squealing squeaky noice sometimes (tends to be when lightly cutting) while trying to cut a grove with a 3.5mm tip grove/parting tool. Ive centralised the tool. kept it sharp.
I dont want to cut too quickly/heavy as im taking my time and also dont want to a jam and damage my workpiece or tool.
is there something im missing to not doing right, or is it ok while cutting slowly?
Am i right in thinking it will squeak because its sliding against the surface of the workpiece with not enough preasure or should i be using cutting fluid to stop this, will the squeal cause any problems (apart for annoying anyone close?)
cheers
KWIL25/02/2013 09:18:53
3681 forum posts
70 photos
What are you cutting, what diameter and at what speed?
Lloyd Bowers25/02/2013 10:04:36
49 forum posts
Posted by KWIL on 25/02/2013 09:18:53:
im cutting an ofcut of steel, which is 18mm down to about 5mm.
speed....slowest (which isnt that slow) on my exe 3.5 super. i know thats not much help but i dont reall know the RPM. i have a 50mm pully of my motor turing at a guess 150mm. you could probably guess or guage it better from my pic's.
I guess thats one thing i should really know and work out. motor RPM and ratio's of pulleys.
thanks for your reply.
Edited By Lloyd Bowers on 25/02/2013 10:05:57
Edited By Lloyd Bowers on 25/02/2013 10:06:17
JasonB25/02/2013 10:12:54
I'd say its a high frequency chatter that sounds like a squeel, 3.5mm wide tip is asking quite a lot of that machine can you not use something narrower and take two bites or keep the load on teh cutter and feed constant
J
Edited By JasonB on 25/02/2013 10:20:11
Andrew Johnston25/02/2013 10:14:10
7061 forum posts
719 photos
Posted by Lloyd Bowers on 25/02/2013 09:03:15:
Same result but different causes. Chatter is a low frequency effect caused by the tool/workpiece/machine not being stiff enough and causing vibration. Chatter normally leaves an regular pattern of marks on the work. Squealing is a higher frequency effect normally caused by the tool intermittently rubbing and cutting rather than cutting cleanly.
I would say that your squealing is almost certainly caused by too low a feedrate. My standard parting tool is 3mm wide and I use an absolute minimum feedate of 4 thou/rev. One of the 'secrets' to successful parting or grooving is to keep the feedrate up; no half measures.
Edited By Andrew Johnston on 25/02/2013 10:15:07
Lloyd Bowers25/02/2013 10:44:23
49 forum posts
ok cheers, i guess feeding too fast and it jams, so get a nice inbetween? just enough to stop the squeeling?
will it cause any damage squeeling?
Ive tried a 1/8th parting tool (blade and holder) which did the same but again i am taking it easy, so maybe feed a bit quicker. - i notice that sometimes the 1/8th did start to wobble left/right and causing a slanted cut, could that also be too lean on feed speed?
Ady125/02/2013 10:52:55
6137 forum posts
893 photos
A great deal has already been said on this subject
Do a ME search for "parting" and "parting off"
Edited By Ady1 on 25/02/2013 10:57:10
Trevor Wright25/02/2013 13:05:00
139 forum posts
36 photos
Lloyd,
Have always parted off by hand feeding, you get a feel for the cut throught he handwheel.
Squealing usually occurs when the workpiece is spinning too fast - chatter when parting will usually wake the neighbours and look like a ploughed field.....
Keep the revs down, lots of lube (WD40 works well) and try hand feeding.
Trevor
Russell Eberhardt25/02/2013 13:30:46
2785 forum posts
87 photos
The pulley diameters you quote will give about 1500 rpm. OK for turning 18 mm but I would want to reduce the speed to about 1/4 of that for parting, especially on a small lathe. Yes a thinner blade should help - half the width = half the cutting force.
Russell.
Lloyd Bowers25/02/2013 14:11:20
49 forum posts
ok, thank you all, ill have to look at larger pulleys, or a back pulley system to lower the rpm. I only have hand feed, will try a few things and wd40..
thanks
Andrew Johnston25/02/2013 15:05:26
7061 forum posts
719 photos
Russell: I'm not sure how you arrive at 1500rpm? If I read the OP's post correctly he has a 50mm pulley on the motor driving a 150mm pulley, so a reduction ratio of 3. For a 2 pole motor running at nearly 3000rpm (in the UK) that gives 1000rpm at the spindle, for a 4 pole motor running at 1500rpm that gives 500rpm at the spindle.
Addendum: looking at the OP's pictures I'd guess the reduction ratio is a bit more than 3 to 1.
Russell Eberhardt25/02/2013 15:54:01
2785 forum posts
87 photos
Posted by Andrew Johnston on 25/02/2013 15:05:26:
Sorry, finger trouble again. I meant 500 rpm of course.
Russell.
Brian Wood25/02/2013 17:25:54
2742 forum posts
39 photos
Hello Lloyd,
Are we all missing something obvious? If tailstock support is in use on a hard centre, could the squeal be coming from that? It would vary with load and maybe more when lightly loaded.
Just a thought
Lloyd Bowers25/02/2013 21:23:04
49 forum posts
well that was better, having some confidence and using wd40 it was loads better.
thanks all. again!
