David Colwill | 23/02/2013 13:36:24 |
782 forum posts 40 photos | I have got a number of projects on which call for mechanisms of varying complexity. My question is are there any drawing packages ( the simpler the better ) that will allow me to draw linkages, levers and gearing in such a way that they can be moved to check clearances and operation. How do the more experienced designers on this forum go about the creation of such things. I'm tempted to get my stepfathers mecano out at the moment. Thanks in advance. David. |
Michael Gilligan | 23/02/2013 14:07:39 |
![]() 23121 forum posts 1360 photos | David, I'm sure there are plenty of [expensive ?] others, but Try SketchUp ... with the SketchyPhysics plug-in MichaelG.
A quick search on Google will find you plenty of videos to show what can be done. |
Ady1 | 23/02/2013 14:40:51 |
![]() 6137 forum posts 893 photos | There are line sketch geometry programs about but you will have to learn the syntax If you find a good one which is easy to learn quite a few people would be interested
I have used CASIO ClassPad Manager v3 (90 Day Trial) which is a computer emulation of a very high spec calculator but the syntax can take a while to get your head around Very handy for mobile geometry stuff though
David Jupp | 23/02/2013 16:29:56 |
978 forum posts 26 photos | Any 3D CAD package that supports assemblies will easily handle linkages and interferences - gears are much less commonly supported, but may be able to be 'fiddled', depending upon exactly what you want to check for. If just checking a basic concept, rather than taking the design through to real parts, there have been packages that allow you to do this with 2D sketches - though I'm struggling to find anything on the web at present. |
Gordon W | 23/02/2013 16:32:08 |
2011 forum posts | You could do what we did in the dark ages :- draw on a board and make levers , rods etc. out of card and drawing pins. Sounds crude but a lot can be done. Use simple maths to get exact dimensions after trying the card and string. |
Jimmeh | 23/02/2013 19:11:16 |
![]() 27 forum posts 12 photos | +1 for the Cardboard Aided Design. |
Michael Gilligan | 23/02/2013 20:56:34 |
Posted by Michael Gilligan on 23/02/2013 14:07:39:
A quick search on Google will find you plenty of videos to show what can be done. . Like this MichaelG. |
Paul Lousick | 23/02/2013 21:44:48 |
2276 forum posts 801 photos | Hello David, All CAD software can accurately draw levers and linkages. For layouts, draw the gears as circles using the PCD (pitch circle diameter). Drawing the shape of involute teeth is a bit more difficult. I use Solidworks and Autocad which can draw to an accuracy of 0.0000001 mm. There are many free packages like Draftsight or TurboCad which can be downloaded. Trial versions of professional packages like Autocad can also be downloaded and used for a limited time. As with all software there is a slow learning curve before you can use it properly. The more complex the software, the longer it takes to learn. |
M0BND | 24/02/2013 09:26:45 |
81 forum posts 9 photos | Draft sight - this may help ..... http://www.solidworks.com/sw/products/draftsight-fundamentals-flipbook.htm Andy. |
David Colwill | 26/02/2013 09:20:50 |
782 forum posts 40 photos | Many thanks for the replies. I will have a look and report back. David. |
