digital height gauge displays random numbers
Dismaldunc10/02/2013 09:59:04
91 forum posts
8 photos
Hi Chaps
I bought a digital height gauge from Allendale at the last Harrowgate show, It has been a joy to use and improved my accuracy no end. However this am when I went out to play (with an ambitious set of ideas in my head for a good 4 hour session) it just gives a bizzarre ever scrolling read out. I shall of course contact Allendale tomorrow but wondered if there is anything I can do to make it play nice ( I have changed the battery ) for the rest of the day.
Dunc
Engine Builder10/02/2013 10:03:11
267 forum posts
I have had this with mine. A new battery put it right. I would try another in case the one you fitted was a dud.
JasonB10/02/2013 10:04:50
You could bring it into the warm house and see if that improves things after a few hours. Was it a new battery you fitted or one you have had in the cold workshop for some time?
J
Alan Reed 110/02/2013 10:13:28
10 forum posts
I had a similar problem . Turned out to be radiation from a low energy lamp ( ie mini fluorescent ) that I was using in my work light.
Dismaldunc10/02/2013 10:29:27
91 forum posts
8 photos
Hi chaps
Thanks for the rapid replies, I have tried 2 new batterys but both were stored in a cold work shop, So I have brought the poor thing into the warm for a little TLC.
I will see if that helps
Dunc
Paul Lousick10/02/2013 10:48:55
2276 forum posts
801 photos
I have found that thse types of gauges do not like moisture. The DRO's on my mill sometimes have similar symptoms when it has been raining for a long period. They operated correctly after they have dried out.
NJH10/02/2013 11:06:05
2314 forum posts
139 photos
Hi Dunc
I too suspect the effect of cold on the batteries - I don't operate too well when I'm cold!
Another point to watch is the source of your batteries - going for the "bargain" ebay offers is usually not the best way forward.
N
colin hawes10/02/2013 11:22:51
570 forum posts
18 photos
I've had similar problems which,on very close examination, turned out to be caused by almost invisible (to my old eyes) corrosion .A little scrapeand a smear of oil on the battery worked fine on my 150mm vernier. Colin
Dismaldunc10/02/2013 11:44:54
91 forum posts
8 photos
well that seems to be sorted.. Brought it into the house for a warm and it now seems like a happy bunny. Righty then Tinas main bearings it is then!
Thanks Lads
Dunc
