Here is a list of all the postings Alan Reed 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Ground flat stock supplier ? |
29/07/2013 11:14:36 |
This Ebay item may fit the bill
http://www.ebay.co.uk/itm/STARRETT-FLAT-STOCK-1-8-X4-X8-/321170392197?pt=UK_Trains_Railway_Models&hash=item4ac73f4485
Thread: digital height gauge displays random numbers |
10/02/2013 10:13:28 |
I had a similar problem . Turned out to be radiation from a low energy lamp ( ie mini fluorescent ) that I was using in my work light. |
Thread: stationary engine castings |
24/11/2012 17:58:49 |
Forrest Classics in the Uk stock PM Research engines if you are interested in small models.. http://www.forest-classics.co.uk/pm_research.htm |
Thread: Milling edge of Material |
13/08/2012 10:18:00 |
I use slot drills / end mills for cleaning up sawn material on my not very rigid Chester Cobra mill . This works OK but to get a reasonable finish I need to feed uphill , downhill produces a much poorer finish. Have you tried feeding in both directions ? |
Thread: Material finishing |
27/06/2012 08:24:53 |
I have sucessfully renovated several micrometers using " Rust-Oleum " Aged Iron aerosol paint .This is widely available, just google Rust - Oleum aged iron for UK stockists. |
Thread: piston rings or ptfe packing |
28/01/2012 09:35:32 |
My 10v works well with the oil grooves as per the Stuart drawing. |
Thread: Why won't my new computer work with this site |
28/11/2011 08:54:26 |
Just to reinforce what Les said , I also use Win 7 (64bit) and Firefox without any problems. |
Thread: Northumbrian Cylinder Ports |
08/11/2011 11:21:44 |
Pete, I think this will solve you problem http://www.model-engineer.co.uk/forums/postings.asp?th=36393 Rgds Alan |
08/11/2011 10:01:20 |
I think you are possibly referencing the wrong face . The bolting face referred to could be the face for the cylinder cover . The ports being at each end of the cylinder block with a small flat as per the Stuart 10V. |
Thread: Marking out fluid |
03/05/2010 10:54:24 |
Chronos sell 200ml bottles of Layout Blue www.chronos.ltd.uk |
