Buying way bellows !!
Darren Heaver27/01/2013 07:04:08
3 forum posts
Hi I am in the process of rebuilding a Ajax AJT1 milling machine and I am after some bellows to cover the slides, the machine is similar to a Bridgeport just bit larger. I was wondering if anyone can suggest a supplier for these ? I have spoken to arceuro trade who sell a few but they could not help with what I want.
anyone got any other ideas ?
cheers Darren.
roy entwistle29/01/2013 09:53:02
1716 forum posts
Darren Put camera bellows in google They may be able to help
Roy
Douglas Johnston29/01/2013 11:01:02
814 forum posts
36 photos
I saw a website some time ago about making your own bellows, but can't remember the actual site. If you have some folding skills this may be a cheap way forward.
Doug
Les Jones 129/01/2013 11:04:03
2292 forum posts
159 photos
Hi Darren,
If you can't find any ready made bellows you could try making some yourself. I made some from damp proof course material for my X3 mill.
These have been in use for a couple of years now.
Les.
joegib29/01/2013 11:29:20
154 forum posts
18 photos
Here's a video illustrating the process.
Video
Joe
Niloch29/01/2013 11:37:36
371 forum posts
Is this any use to you?
Gray6229/01/2013 11:48:11
1058 forum posts
16 photos
On My AJT4, I used a piece of butyl type pond liner between the back of the be and the top of the column ways, been there for a couple of years and still ok. I've got some left somewhere if you want a piece for the cost of postage. PM me the size and I can sort some out for you.
cheers
Graeme
Bazyle29/01/2013 13:08:20
6956 forum posts
229 photos
I'm looking for someone to try these and report back. I think you can cut some to size.
It does seem to be a bit of a broken record as half the queries on here seem to end up pointing to this company but I can only assume it is because they actually take the trouble to work out what we hobbyists actually need.
Robert Dodds29/01/2013 16:49:21
324 forum posts
63 photos
Darren,
If you need to go for a custom made you might look at
http://www.beakbane.co.uk
They do many different styles, one I used in the past was from a dip plastic coating.
For 1offs the moulding former may make it expensive so one of their standard ones would be more cost effective if you can get one to suit.
Bob D
Darren Heaver29/01/2013 18:03:20
3 forum posts
Thanks I was looking at their web site a bit earlier may contact them tomorrow to see what they say !. Or I might just wait till I have the machine back together and see what the one's that Arceurotrade do look like, they do one that is bigger than the slides but it may work ok and help keep the dwarf off a bit more. Will keep you posted.
Cheers for the suggestions.
John Stevenson29/01/2013 21:14:41
5068 forum posts
Got the big set of bellows from ARC on my bridgeport, not fitted them just dropped them over the back.
impressions, keeps a load of crap off the ways but because they have not been cut and fitted stuff still get in at the corners.
My fault needs to be fitted correctly and it would stop that.
They are wearing well except for steel chips sticking to the bellows, not as bad as it sounds as they do brush off and are not buring thru but I do use this machine in anger, it's a paying workhorse and big cuts with decent inserted cutters are the norm.
Light cuts with steel brush off as does alloy etc. In a home shop I suspect the life span is a fair few years, in my industrial shop probably two years and they will start looking tatty.
Hope this is a truthful answer.
Michael Gilligan29/01/2013 21:34:15
23121 forum posts
1360 photos
Posted by roy entwistle on 29/01/2013 09:53:02:
Roy
"Camera Bellows" of Birmingham, appears to have been reborn as "Custom Bellows"
... haven't used them recently but, years ago they were excellent people to deal with.
Darren Heaver29/01/2013 21:48:03
3 forum posts
I have been look at the ARC ones and I think I might go with the same idea as John suggests to use the larger ones as the AJT1 is not that much different to the Bridgeport and fix then using a custom plate to the top of the colour and top of knee, then to the back of the main saddle in the same way might order a couple to have a play cheers
Darren
